    CR 10 5s
    My Duet controlled machine
    743
    • Thunderundefined
      Thunder
      sorry here is it :
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri May 01 2020 16:13:33 GMT+0200 (Srednjeevropski poletni čas)
      G90                                     ; send absolute coordinates...
      M83                                     ; ...but relative extruder moves
      M550 P"CR10 5S"                         ; set printer name
      M918 P1 E4 F2000000                     ; configure direct-connect display
      M569 P0 S0                              ; physical drive 0 goes backwards
      M569 P1 S0                              ; physical drive 1 goes backwards
      M569 P2 S1                              ; physical drive 2 goes forwards
      M569 P3 S0                              ; physical drive 3 goes backwards
      M584 X0 Y1 Z2 E3                        ; set drive mapping
      M350 X32 Y32 Z32 I0                     ; configure microstepping without interpolation
      M350 E16 I1                             ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z4000.00 E420.00      ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00     ; set maximum instantaneous speed changes (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00     ; set accelerations (mm/s^2)
      M906 X1680 Y1680 Z1680 E800 I50         ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                 ; Set idle timeout
      M208 X0 Y0 Z0 S1                        ; set axis minima
      M208 X500 Y500 Z500 S0                  ; set axis maxima
      M574 Z1 S0                              ; set active low and disabled endstops
      M574 X1 Y1 S1                           ; set active high endstops
      M558 P0 H5 F120 T24000                  ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:215 Y15:195 S20                ; define mesh grid
      M305 P0 T100000 B4092 R4700             ; set thermistor + ADC parameters for heater 0
      M143 H0 S150                            ; set temperature limit for heater 0 to 150C
      M305 P1 T100000 B4092 R4700             ; set thermistor + ADC parameters for heater 1
      M143 H1 S275                            ; set temperature limit for heater 1 to 275C
      M106 P0 S0 I0 F500 H-1                  ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T45               ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F500 H1:0 T45             ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1 F0                        ; define tool 0
      G10 P0 X0 Y0 Z0                         ; set tool 0 axis offsets
      G10 P0 R0 S0                            ; set initial tool 0 active and standby temperatures to 0C
      Thanks 🙂
      • NitroFreakundefined
        NitroFreak
        You have a 400 steps/rev stepper, the original are 200. You need to double your steps/mm for every axis that you switched the steppers out
        • PaulHewundefined
          PaulHew
          @Thunder said in [CR 10 5s]
          Did you use the RRF Config Tool (Click the link)
          My First glance is your M906, some of your values are high.
          My suggestion
          M906 X1400 Y1700 Z1400 E800 I50 ; set motor currents (mA) and motor idle factor in per cent
          I am guessing In regards to your M92, you can try it, I am not saying it is right!
          M92 X400 Y200 Z4000.00 E420.00 ; set steps per mm
          Make sure if you move 10mm in any axis from DWC it has physically moved that distance,
          Also I would start with this, then tweak later.
          M350 X16 Y16 Z16 E16 I 0 ; set 16x microstepping for axes & extruder, without interpolation
          As I said, not 100%, but it might get you on the right path.
          Paul.
            Phaedrux Moderator @Thunder
            @Thunder said in CR 10 5s:
            Z4000.00
            4000 steps per mm on the Z axis is unlikely. 400 perhaps?
            • ziggymanpopoundefined
              ziggymanpopo
              I did somthing simular to a cr10 s what is the pich on your screw 5 or 10 mm. Kersy manufacturing Has a u tube video that might be very helpful it was for me. He goes thrie the whole process
              • Thunderundefined
                Thunder
                Ok. Long time no write. I have made the printer move. And now I have another problem. I have a titan aero extruder with a Vulcano hotend. And now I struggle with the top layer and the edges. I get a bit deformed left corner.
                Hope anybody will see this thread. 😛 Z is the top layer
                Here is my config file.
                ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun May 24 2020 20:05:38 GMT+0200 (Central European Summer Time)
                M550 P"My Printer"                                 ; set printer name
                M551 P"GoBevk"                                     ; set password
                M552 S1                                            ; enable network
                M586 P0 S1                                         ; enable HTTP
                M586 P1 S0                                         ; disable FTP
                M586 P2 S0                                         ; disable Telnet
                M569 P3 S1                                         ; physical drive 3 goes forwards
                M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
                M92 X160.00 Y80.00 Z800.00 E809.00                 ; set steps per mm
                M84 S50                                            ; Set idle timeout
                M574 X1 Y1 Z1 S1                                   ; set active high endstops
                M307 H3 A-1 C-1 D-1                                ; disable heater on PWM channel for BLTouch
                M558 P9 H5 F120 T24000                             ; set Z probe type to bltouch and the dive height + speeds
                G31 P500 X-66.4 Y-10.2 Z2.15                            ; set Z probe trigger value, offset and trigger height
                M557 X15:495 Y15:495 S20                           ; define mesh grid
                M305 P0 T100000 B4138 R4700                        ; set thermistor + ADC parameters for heater 0
                M143 H0 S120                                       ; set temperature limit for heater 0 to 120C
                M305 P1 T100000 B4138 R4700                        ; set thermistor + ADC parameters for heater 1
                M143 H1 S280                                       ; set temperature limit for heater 1 to 280C
                ![6_1590644526968_IMG-4002.JPG](Uploading 100%) ![5_1590644526967_IMG-4001.JPG](Uploading 100%) ![4_1590644526967_IMG-3999.JPG](Uploading 100%) ![3_1590644526966_IMG-3998.JPG](Uploading 100%) ![2_1590644526965_IMG-3997.JPG](Uploading 100%) ![1_1590644526965_IMG-3996.JPG](Uploading 100%) ![0_1590644526959_IMG-3995.JPG](Uploading 100%)
                Any suggestions ??:)
                • Thunderundefined
                  Thunder
                  Ok and now the pictures :
                  https://ibb.co/8MpQxcJ
                  https://ibb.co/NN1n4zJ
                  https://ibb.co/q9rRb3G
                  https://ibb.co/vHDkSY9
                  https://ibb.co/SnsXfHZ
                  https://ibb.co/GRvZFQ1
                  https://ibb.co/1z8SLzX
                  The nozzle is 0.8mm
                    ziggymanpopo
                    You might find it interestin but i put linear rails/ballscrew and with a pich if 10mm if you are interested in knowing the effort was worth it .
                    all the gosting is gone completely. It was a lot of work please feel free to ask me anything you like
                    I have not experienced the same issues with my top layers but im only running a .4 nozzle...
                    Just chainging the board out is enough of a challenge my hats off to you! 😁 knowing whats to be done!! i call it the fankenprinter!!!
                    My next step is to strip the x carrage completely
                    I thought i would use both an end stop for the z axes and the z probe. I kbow its possable seen a couple of posts
                    Reasoning behind is after the upgrade there will be no more give on the hotend thus as a safety precaution, i have run my hotend carriage into my build platform several times
                    Hemera direct drive extrude upgrade to come
                    Thunderundefined 1 Reply Last reply Reply Quote 0
                      ziggymanpopo
                      By the way its not a cr-10s5 anymore
                      Same thing i started with.
                      • Thunderundefined
                        Thunder @ziggymanpopo
                        @ziggymanpopo Thanks. I also upgraded the z-axis and the x-axis to linear rails. Still have to upgrade the x-axis. Why did you decide to change the ball screws? Thanks for the compliment :).
                        What do i call it ?
                          ziggymanpopo
                          I nsmed my printer frankenprinter as a joke almost all of the original parts are gone just the frame left
                          I found out that almost all of my settings needed tweeking after the d.w.c. change
                          I used the 10 pitch,, much faster ball screw.
