    Need help installing ustreamer
    135
    10.7k
    • Dougal1957undefined
      Dougal1957 @luckyflyer
      @luckyflyer I don't really know as I don't have one yet but am considering one with possible a wide angle lens on it not a cheap combination mind
      • mdevaevundefined
        mdevaev
        Sup. The ustreamer developer here. I am glad that you use my software, but just in case I want to warn those who want to use RPi CSI cameras: it doesn't work with ustreamer. The reason is that these cameras use their own specific non-v4l2 driver. It is possible to configure them as v4l2, but this requires research and I have not yet addressed this issue. So if you don't want any problems, use regular USB cameras.
        Quick answers to old questions:
        • 0.0.0.0 is a special address that means "listen all ipv4 interfaces". If you choose this option, you can connect to the streamer via the ip address of your network card or localhost (127.0.0.1).
        • You can't listen to port 80 unless you are root or have the CAP_NET_BIND_SERVICE capability (blah-blah-blah the network magic). If you want to run ustreamer via systemd on port 80 under non-root user, you need to add a parameter AmbientCapabilities=CAP_NET_BIND_SERVICE to the Service section
        • Use the HW encoder: almost all cameras support it.
        • If you're afraid that someone will see your video, use password authorization. It's better than nothing.
        PS: I was just passing by, so if you need any help, go to discord, the link is in the ustreamer repository on github.
          Dougal1957 @mdevaev
          @mdevaev Thank you very much for that info just saved me a ton of cash
          • luckyflyerundefined
            luckyflyer
            Wow, good to know.
              luckyflyer
              Still having trouble getting ustreamer to auto start as a service. I have entered @gtj0 revised entries which are,
              sudoedit /etc/udev/rules.d/80-ustreamer.rules:
              ACTION=="add", KERNEL=="video0", SUBSYSTEM=="video4linux", TAG+="systemd", ENV{SYSTEMD_WANTS}+="ustreamer@%k.service"
              ACTION=="remove", KERNEL=="video0", SUBSYSTEM=="video4linux", RUN+="/bin/systemctl --no-block stop ustreamer@%k.service"
              sudoedit /etc/systemd/system/ustreamer@.service:
              [Unit]
              Description=UStreamer for %I
              [Service]
              Type=simple
              ExecStart=/usr/local/bin/ustreamer --exit-on-parent-death -r 640x480 --static /tmp/ -d /dev/%i --host=0.0.0.0 --port=8080
              [Install]
              WantedBy=multi-user.target
              Then rebooted, but no image on pc which is http://192.168.0.181:8080 or on Duet pi
              http://0.0.0.0:8080
              I then tried to manually start the service with,
              sudo systemctl start ustreamer@video0.service
              and get,
              pi@duet3:~ $ sudo systemctl start ustreamer@video0.service
              Failed to start ustreamer@video0.service: Unit ustreamer@video0.service not found.
              pi@duet3:~ $
              @bearer mentioned this,
              *) edit: this assumes the default EDITOR environment variable is set to nano, but if you've changed it you probably know how to use the editor:)
              I wondered about this but Raspbian buster comes with nano as the default editor and since I haven't changed editors this shouldn't be an issue.
                A Former User @luckyflyer
                @luckyflyer said in Need help installing ustreamer:
                only relevant when using sudoedit (probably other times as well, but in this context, only for sudoedit) and the instructions for getting out of nano wouldn't work for other editors - but then again, if someone have changed the default I'd wager they know how to use it.
                  luckyflyer
                  Hmm, that is what I'm using,
                  should I use something else?
                    Hmm, that is what I'm using, should I use something else?
                    oh dear; that is the one question you do not ask the internett and live to talk about..
                    jokes aside, no and yes. occasional editing of small files on debian and derivatives nano is fine. but nano isn't always available when you wander outside the comfort zone, and there are fanatics who will tell you that you won't get into (insert happy after life place) if you use anything but their favourite editor etc.
                      luckyflyer
                      Lol can I buy you a plane ticket to the desert southwest, my guess is you you would have this sorted in about 2 minutes.
                      So
                      should work ok for me?
                        not so sure about the 2 minutes, systemd isn't my forte.
                        nor am I 100% sure about the usecase and proposed solution is the best match.
                        but yeah, the command to edit the files as root is fine, it does the same as sudo nano /etc/.... just without loopholes and it respects the EDITOR env variable for those who have customized their profile.
                        are you looking for a solution that will autostart when the camera is connected, or a solution that will autostart when the pi starts (with the camera always connected)?
                        my day is coming to an end, but i think the last bit there might clear up some misconceptions?
                          luckyflyer
                          I normally will keep the camera always connected so the autostart with camera connected would work for me. But either would work ok.
                            A Former User
                            (the template thing might do both, idk, if I fidn a camera tomorrow i'll play with it a little in the evening)
                              luckyflyer
                              Sounds good thanks.
                                luckyflyer
                                I notice that line 2 uses a upper case I and line 5 uses a lower case i Don't know if this is anything or not, thought I would mention it.
                                [Unit]
                                [Service]
                                Type=simple
                                [Install]
                                  thats intentional. %I gets escaped so it doesn't contain special characters, which is needed for the name (and i suspect gtj0 would have corrected it if I was mistaken:)
                                  • gtj0undefined
                                    gtj0 @A Former User
                                    @bearer said in Need help installing ustre sure the camera is plugged in.
                                    eamer
                                    Correct. It's just in the description anyway.
                                    @luckyflyer start simple...
                                    ### Move the rules file out of the way
                                    $ sudo mv /etc/udev/rules.d/80-ustreamer.rules /root/
                                    ### Reload systemd
                                    $ sudo systemctl daemon-reload
                                    ### Enable ustreamer@video0 to start on boot.
                                    $ sudo systemctl enable ustreamer@video0
                                    Created symlink /etc/systemd/system/multi-user.target.wants/ustreamer@video0.service → /etc/systemd/system/ustreamer@.service.
                                    ### Make sure the camera is plugged in.
                                    ### Reboot.
                                    $ sudo systemctl reboot
                                    ###  When the Pi is back up, check the status of the service...
                                    $ sudo systemctl status ustreamer@video0
                                      luckyflyer
                                      @gtj0 Thanks for your help and sorry to be such a pain.
                                      I enter each command and this is what I get.
                                      pi@duet3:~ $ sudo mv /etc/udev/rules.d/80-ustreamer.rules /root/
                                      pi@duet3:~ $ sudo systemctl daemon-reload
                                      pi@duet3:~ $ sudo systemctl enable ustreamer@video0
                                      Failed to enable unit: Unit file ustreamer@video0.service does not exist.
                                      I have followed the previous steps exactly and several times using copy and paste. I'm using nano3.2 and do ctrl X Yes then enter to save and then reboot. I do this for both of the files. I'm at a loss to for why the service does not exist.
                                      One thing I've noticed is when I go back into the editor the text that I previously entered
                                      and
                                      [Unit]
                                      [Service]
                                      Type=simple
                                      [Install]
                                      are still there, is this normal? I have the feeling that the files are not being saved. I'm wondering if I don't have permissions set correctly but get no error stating that I don't. Doing research to understand about permissions.
                                      • gtj0undefined
                                        gtj0 @luckyflyer
                                        @luckyflyer Are you sure the ustreamer@.service file is located in /etc/systemd/system and that it's named exactly that?
                                        Try ls -al /etc/systemd/system then cat /etc/systemd/system/ustreamer@.service
                                          luckyflyer
                                          @gtj0
                                          pi@duet3:~/ustreamer $ ls -al /etc/systemd/system
                                          total 76
                                          drwxr-xr-x 17 root root 4096 May 29 22:30 .
                                          drwxr-xr-x  5 root root 4096 May 19 06:26 ..
                                          -rw-r--r--  1 root root 1551 Apr  7 06:06 autologin@.service
                                          drwxr-xr-x  2 root root 4096 May 19 07:56 basic.target.wants
                                          drwxr-xr-x  2 root root 4096 May 19 06:36 bluetooth.target.wants
                                          lrwxrwxrwx  1 root root   42 May 19 06:38 dbus-fi.w1.wpa_supplicant1.service -> /lib/systemd/system/wpa_supplicant.service
                                          lrwxrwxrwx  1 root root   37 May 19 06:36 dbus-org.bluez.service -> /lib/systemd/system/bluetooth.service
                                          lrwxrwxrwx  1 root root   40 May 19 06:37 dbus-org.freedesktop.Avahi.service -> /lib/systemd/system/avahi-daemon.service
                                          lrwxrwxrwx  1 root root   45 May 19 06:26 dbus-org.freedesktop.timesync1.service -> /lib/systemd/system/systemd-timesyncd.service
                                          lrwxrwxrwx  1 root root   34 May 19 06:38 dhcpcd5.service -> /lib/systemd/system/dhcpcd.service
                                          lrwxrwxrwx  1 root root   35 May 19 07:58 display-manager.service -> /lib/systemd/system/lightdm.service
                                          drwxr-xr-x  2 root root 4096 May 19 06:26 getty.target.wants
                                          drwxr-xr-x  2 root root 4096 May 19 06:31 getty@tty1.service.d
                                          drwxr-xr-x  2 root root 4096 May 19 07:58 graphical.target.wants
                                          drwxr-xr-x  2 root root 4096 May 19 06:35 halt.target.wants
                                          drwxr-xr-x  2 root root 4096 May 25 20:04 multi-user.target.wants
                                          drwxr-xr-x  2 root root 4096 May 19 06:28 network-online.target.wants
                                          drwxr-xr-x  2 root root 4096 May 19 06:35 poweroff.target.wants
                                          drwxr-xr-x  2 root root 4096 May 19 06:38 rc-local.service.d
                                          drwxr-xr-x  2 root root 4096 May 19 06:35 reboot.target.wants
                                          drwxr-xr-x  2 root root 4096 May 19 06:36 remote-fs.target.wants
                                          drwxr-xr-x  2 root root 4096 May 19 08:03 sockets.target.wants
                                          lrwxrwxrwx  1 root root   31 May 19 06:36 sshd.service -> /lib/systemd/system/ssh.service
                                          drwxr-xr-x  2 root root 4096 May 19 06:36 sysinit.target.wants
                                          lrwxrwxrwx  1 root root   35 May 19 06:28 syslog.service -> /lib/systemd/system/rsyslog.service
                                          drwxr-xr-x  2 root root 4096 May 19 06:29 timers.target.wants
                                          -rw-r--r--  1 root root  217 May 30 12:24 ustreamer@.service:
                                          pi@duet3:~ $ cat /etc/systemd/system/ustreamer@.service
                                          cat: /etc/systemd/system/ustreamer@.service: No such file or directory
                                          Looks like the first one is there, but not the second.
                                          I think it's something with my editor but don't know how to check to see.
                                            @luckyflyer maybe try making it executable?
                                            sudo chmod +x /etc/systemd/system/ustreamer@.service
                                            (long shot)
