    Need help installing ustreamer
    135
    10.9k
    • luckyflyerundefined
      luckyflyer
      Wow, good to know.
        luckyflyer
        Still having trouble getting ustreamer to auto start as a service. I have entered @gtj0 revised entries which are,
        sudoedit /etc/udev/rules.d/80-ustreamer.rules:
        ACTION=="add", KERNEL=="video0", SUBSYSTEM=="video4linux", TAG+="systemd", ENV{SYSTEMD_WANTS}+="ustreamer@%k.service"
        ACTION=="remove", KERNEL=="video0", SUBSYSTEM=="video4linux", RUN+="/bin/systemctl --no-block stop ustreamer@%k.service"
        sudoedit /etc/systemd/system/ustreamer@.service:
        [Unit]
        Description=UStreamer for %I
        [Service]
        Type=simple
        ExecStart=/usr/local/bin/ustreamer --exit-on-parent-death -r 640x480 --static /tmp/ -d /dev/%i --host=0.0.0.0 --port=8080
        [Install]
        WantedBy=multi-user.target
        Then rebooted, but no image on pc which is http://192.168.0.181:8080 or on Duet pi
        http://0.0.0.0:8080
        I then tried to manually start the service with,
        sudo systemctl start ustreamer@video0.service
        and get,
        pi@duet3:~ $ sudo systemctl start ustreamer@video0.service
        Failed to start ustreamer@video0.service: Unit ustreamer@video0.service not found.
        pi@duet3:~ $
        @bearer mentioned this,
        *) edit: this assumes the default EDITOR environment variable is set to nano, but if you've changed it you probably know how to use the editor:)
        I wondered about this but Raspbian buster comes with nano as the default editor and since I haven't changed editors this shouldn't be an issue.
          A Former User @luckyflyer
          @luckyflyer said in Need help installing ustreamer:
          only relevant when using sudoedit (probably other times as well, but in this context, only for sudoedit) and the instructions for getting out of nano wouldn't work for other editors - but then again, if someone have changed the default I'd wager they know how to use it.
            luckyflyer
            Hmm, that is what I'm using,
            should I use something else?
              Hmm, that is what I'm using, should I use something else?
              oh dear; that is the one question you do not ask the internett and live to talk about..
              jokes aside, no and yes. occasional editing of small files on debian and derivatives nano is fine. but nano isn't always available when you wander outside the comfort zone, and there are fanatics who will tell you that you won't get into (insert happy after life place) if you use anything but their favourite editor etc.
                luckyflyer
                Lol can I buy you a plane ticket to the desert southwest, my guess is you you would have this sorted in about 2 minutes.
                So
                should work ok for me?
                  not so sure about the 2 minutes, systemd isn't my forte.
                  nor am I 100% sure about the usecase and proposed solution is the best match.
                  but yeah, the command to edit the files as root is fine, it does the same as sudo nano /etc/.... just without loopholes and it respects the EDITOR env variable for those who have customized their profile.
                  are you looking for a solution that will autostart when the camera is connected, or a solution that will autostart when the pi starts (with the camera always connected)?
                  my day is coming to an end, but i think the last bit there might clear up some misconceptions?
                    luckyflyer
                    I normally will keep the camera always connected so the autostart with camera connected would work for me. But either would work ok.
                      A Former User
                      (the template thing might do both, idk, if I fidn a camera tomorrow i'll play with it a little in the evening)
                        luckyflyer
                        Sounds good thanks.
                          luckyflyer
                          I notice that line 2 uses a upper case I and line 5 uses a lower case i Don't know if this is anything or not, thought I would mention it.
                          [Unit]
                          [Service]
                          Type=simple
                          [Install]
                            thats intentional. %I gets escaped so it doesn't contain special characters, which is needed for the name (and i suspect gtj0 would have corrected it if I was mistaken:)
                            • gtj0undefined
                              gtj0 @A Former User
                              @bearer said in Need help installing ustre sure the camera is plugged in.
                              eamer
                              Correct. It's just in the description anyway.
                              @luckyflyer start simple...
                              ### Move the rules file out of the way
                              $ sudo mv /etc/udev/rules.d/80-ustreamer.rules /root/
                              ### Reload systemd
                              $ sudo systemctl daemon-reload
                              ### Enable ustreamer@video0 to start on boot.
                              $ sudo systemctl enable ustreamer@video0
                              Created symlink /etc/systemd/system/multi-user.target.wants/ustreamer@video0.service → /etc/systemd/system/ustreamer@.service.
                              ### Make sure the camera is plugged in.
                              ### Reboot.
                              $ sudo systemctl reboot
                              ###  When the Pi is back up, check the status of the service...
                              $ sudo systemctl status ustreamer@video0
                                luckyflyer
                                @gtj0 Thanks for your help and sorry to be such a pain.
                                I enter each command and this is what I get.
                                pi@duet3:~ $ sudo mv /etc/udev/rules.d/80-ustreamer.rules /root/
                                pi@duet3:~ $ sudo systemctl daemon-reload
                                pi@duet3:~ $ sudo systemctl enable ustreamer@video0
                                Failed to enable unit: Unit file ustreamer@video0.service does not exist.
                                I have followed the previous steps exactly and several times using copy and paste. I'm using nano3.2 and do ctrl X Yes then enter to save and then reboot. I do this for both of the files. I'm at a loss to for why the service does not exist.
                                One thing I've noticed is when I go back into the editor the text that I previously entered
                                and
                                [Unit]
                                [Service]
                                Type=simple
                                [Install]
                                are still there, is this normal? I have the feeling that the files are not being saved. I'm wondering if I don't have permissions set correctly but get no error stating that I don't. Doing research to understand about permissions.
                                • gtj0undefined
                                  gtj0 @luckyflyer
                                  @luckyflyer Are you sure the ustreamer@.service file is located in /etc/systemd/system and that it's named exactly that?
                                  Try ls -al /etc/systemd/system then cat /etc/systemd/system/ustreamer@.service
                                    luckyflyer
                                    @gtj0
                                    pi@duet3:~/ustreamer $ ls -al /etc/systemd/system
                                    total 76
                                    drwxr-xr-x 17 root root 4096 May 29 22:30 .
                                    drwxr-xr-x  5 root root 4096 May 19 06:26 ..
                                    -rw-r--r--  1 root root 1551 Apr  7 06:06 autologin@.service
                                    drwxr-xr-x  2 root root 4096 May 19 07:56 basic.target.wants
                                    drwxr-xr-x  2 root root 4096 May 19 06:36 bluetooth.target.wants
                                    lrwxrwxrwx  1 root root   42 May 19 06:38 dbus-fi.w1.wpa_supplicant1.service -> /lib/systemd/system/wpa_supplicant.service
                                    lrwxrwxrwx  1 root root   37 May 19 06:36 dbus-org.bluez.service -> /lib/systemd/system/bluetooth.service
                                    lrwxrwxrwx  1 root root   40 May 19 06:37 dbus-org.freedesktop.Avahi.service -> /lib/systemd/system/avahi-daemon.service
                                    lrwxrwxrwx  1 root root   45 May 19 06:26 dbus-org.freedesktop.timesync1.service -> /lib/systemd/system/systemd-timesyncd.service
                                    lrwxrwxrwx  1 root root   34 May 19 06:38 dhcpcd5.service -> /lib/systemd/system/dhcpcd.service
                                    lrwxrwxrwx  1 root root   35 May 19 07:58 display-manager.service -> /lib/systemd/system/lightdm.service
                                    drwxr-xr-x  2 root root 4096 May 19 06:26 getty.target.wants
                                    drwxr-xr-x  2 root root 4096 May 19 06:31 getty@tty1.service.d
                                    drwxr-xr-x  2 root root 4096 May 19 07:58 graphical.target.wants
                                    drwxr-xr-x  2 root root 4096 May 19 06:35 halt.target.wants
                                    drwxr-xr-x  2 root root 4096 May 25 20:04 multi-user.target.wants
                                    drwxr-xr-x  2 root root 4096 May 19 06:28 network-online.target.wants
                                    drwxr-xr-x  2 root root 4096 May 19 06:35 poweroff.target.wants
                                    drwxr-xr-x  2 root root 4096 May 19 06:38 rc-local.service.d
                                    drwxr-xr-x  2 root root 4096 May 19 06:35 reboot.target.wants
                                    drwxr-xr-x  2 root root 4096 May 19 06:36 remote-fs.target.wants
                                    drwxr-xr-x  2 root root 4096 May 19 08:03 sockets.target.wants
                                    lrwxrwxrwx  1 root root   31 May 19 06:36 sshd.service -> /lib/systemd/system/ssh.service
                                    drwxr-xr-x  2 root root 4096 May 19 06:36 sysinit.target.wants
                                    lrwxrwxrwx  1 root root   35 May 19 06:28 syslog.service -> /lib/systemd/system/rsyslog.service
                                    drwxr-xr-x  2 root root 4096 May 19 06:29 timers.target.wants
                                    -rw-r--r--  1 root root  217 May 30 12:24 ustreamer@.service:
                                    pi@duet3:~ $ cat /etc/systemd/system/ustreamer@.service
                                    cat: /etc/systemd/system/ustreamer@.service: No such file or directory
                                    Looks like the first one is there, but not the second.
                                    I think it's something with my editor but don't know how to check to see.
                                      @luckyflyer maybe try making it executable?
                                      sudo chmod +x /etc/systemd/system/ustreamer@.service
                                      (long shot)
                                        luckyflyer
                                        tried it,
                                        pi@duet3:~ $ sudo chmod +x /etc/systemd/system/ustreamer@.service
                                        chmod: cannot access '/etc/systemd/system/ustreamer@.service': No such file or directory
                                          luckyflyer
                                          @gtj0 @bearer
                                          Been reading up on the cat command, was wondering if that would be a good way to create and save the missing file?
                                          A Former User? 2 Replies Last reply Reply Quote 0
                                            hmm, does the filename have a : at the end?
                                            sudo mv /etc/systemd/system/ustreamer@.service: /etc/systemd/system/ustreamer@.service
