    Need help installing ustreamer
    135
    11.2k
      A Former User @luckyflyer
      not so sure about the 2 minutes, systemd isn't my forte.
      nor am I 100% sure about the usecase and proposed solution is the best match.
      but yeah, the command to edit the files as root is fine, it does the same as sudo nano /etc/.... just without loopholes and it respects the EDITOR env variable for those who have customized their profile.
      are you looking for a solution that will autostart when the camera is connected, or a solution that will autostart when the pi starts (with the camera always connected)?
      my day is coming to an end, but i think the last bit there might clear up some misconceptions?
      • luckyflyerundefined
        luckyflyer
        I normally will keep the camera always connected so the autostart with camera connected would work for me. But either would work ok.
          A Former User
          (the template thing might do both, idk, if I fidn a camera tomorrow i'll play with it a little in the evening)
            luckyflyer
            Sounds good thanks.
              luckyflyer
              I notice that line 2 uses a upper case I and line 5 uses a lower case i Don't know if this is anything or not, thought I would mention it.
              [Unit]
              Description=UStreamer for %I
              [Service]
              Type=simple
              ExecStart=/usr/local/bin/ustreamer --exit-on-parent-death -r 640x480 --static /tmp/ -d /dev/%i --host=0.0.0.0 --port=8080
              [Install]
              WantedBy=multi-user.target
                thats intentional. %I gets escaped so it doesn't contain special characters, which is needed for the name (and i suspect gtj0 would have corrected it if I was mistaken:)
                • gtj0undefined
                  gtj0 @A Former User
                  @bearer said in Need help installing ustre sure the camera is plugged in.
                  eamer
                  Correct. It's just in the description anyway.
                  @luckyflyer start simple...
                  ### Move the rules file out of the way
                  $ sudo mv /etc/udev/rules.d/80-ustreamer.rules /root/
                  ### Reload systemd
                  $ sudo systemctl daemon-reload
                  ### Enable ustreamer@video0 to start on boot.
                  $ sudo systemctl enable ustreamer@video0
                  Created symlink /etc/systemd/system/multi-user.target.wants/ustreamer@video0.service → /etc/systemd/system/ustreamer@.service.
                  ### Make sure the camera is plugged in.
                  ### Reboot.
                  $ sudo systemctl reboot
                  ###  When the Pi is back up, check the status of the service...
                  $ sudo systemctl status ustreamer@video0
                    luckyflyer
                    @gtj0 Thanks for your help and sorry to be such a pain.
                    I enter each command and this is what I get.
                    pi@duet3:~ $ sudo mv /etc/udev/rules.d/80-ustreamer.rules /root/
                    pi@duet3:~ $ sudo systemctl daemon-reload
                    pi@duet3:~ $ sudo systemctl enable ustreamer@video0
                    Failed to enable unit: Unit file ustreamer@video0.service does not exist.
                    I have followed the previous steps exactly and several times using copy and paste. I'm using nano3.2 and do ctrl X Yes then enter to save and then reboot. I do this for both of the files. I'm at a loss to for why the service does not exist.
                    One thing I've noticed is when I go back into the editor the text that I previously entered
                    ACTION=="add", KERNEL=="video0", SUBSYSTEM=="video4linux", TAG+="systemd", ENV{SYSTEMD_WANTS}+="ustreamer@%k.service"
                    ACTION=="remove", KERNEL=="video0", SUBSYSTEM=="video4linux", RUN+="/bin/systemctl --no-block stop ustreamer@%k.service"
                    and
                    [Unit]
                    [Service]
                    Type=simple
                    [Install]
                    are still there, is this normal? I have the feeling that the files are not being saved. I'm wondering if I don't have permissions set correctly but get no error stating that I don't. Doing research to understand about permissions.
                    • gtj0undefined
                      gtj0 @luckyflyer
                      @luckyflyer Are you sure the ustreamer@.service file is located in /etc/systemd/system and that it's named exactly that?
                      Try ls -al /etc/systemd/system then cat /etc/systemd/system/ustreamer@.service
                        luckyflyer
                        @gtj0
                        pi@duet3:~/ustreamer $ ls -al /etc/systemd/system
                        total 76
                        drwxr-xr-x 17 root root 4096 May 29 22:30 .
                        drwxr-xr-x  5 root root 4096 May 19 06:26 ..
                        -rw-r--r--  1 root root 1551 Apr  7 06:06 autologin@.service
                        drwxr-xr-x  2 root root 4096 May 19 07:56 basic.target.wants
                        drwxr-xr-x  2 root root 4096 May 19 06:36 bluetooth.target.wants
                        lrwxrwxrwx  1 root root   42 May 19 06:38 dbus-fi.w1.wpa_supplicant1.service -> /lib/systemd/system/wpa_supplicant.service
                        lrwxrwxrwx  1 root root   37 May 19 06:36 dbus-org.bluez.service -> /lib/systemd/system/bluetooth.service
                        lrwxrwxrwx  1 root root   40 May 19 06:37 dbus-org.freedesktop.Avahi.service -> /lib/systemd/system/avahi-daemon.service
                        lrwxrwxrwx  1 root root   45 May 19 06:26 dbus-org.freedesktop.timesync1.service -> /lib/systemd/system/systemd-timesyncd.service
                        lrwxrwxrwx  1 root root   34 May 19 06:38 dhcpcd5.service -> /lib/systemd/system/dhcpcd.service
                        lrwxrwxrwx  1 root root   35 May 19 07:58 display-manager.service -> /lib/systemd/system/lightdm.service
                        drwxr-xr-x  2 root root 4096 May 19 06:26 getty.target.wants
                        drwxr-xr-x  2 root root 4096 May 19 06:31 getty@tty1.service.d
                        drwxr-xr-x  2 root root 4096 May 19 07:58 graphical.target.wants
                        drwxr-xr-x  2 root root 4096 May 19 06:35 halt.target.wants
                        drwxr-xr-x  2 root root 4096 May 25 20:04 multi-user.target.wants
                        drwxr-xr-x  2 root root 4096 May 19 06:28 network-online.target.wants
                        drwxr-xr-x  2 root root 4096 May 19 06:35 poweroff.target.wants
                        drwxr-xr-x  2 root root 4096 May 19 06:38 rc-local.service.d
                        drwxr-xr-x  2 root root 4096 May 19 06:35 reboot.target.wants
                        drwxr-xr-x  2 root root 4096 May 19 06:36 remote-fs.target.wants
                        drwxr-xr-x  2 root root 4096 May 19 08:03 sockets.target.wants
                        lrwxrwxrwx  1 root root   31 May 19 06:36 sshd.service -> /lib/systemd/system/ssh.service
                        drwxr-xr-x  2 root root 4096 May 19 06:36 sysinit.target.wants
                        lrwxrwxrwx  1 root root   35 May 19 06:28 syslog.service -> /lib/systemd/system/rsyslog.service
                        drwxr-xr-x  2 root root 4096 May 19 06:29 timers.target.wants
                        -rw-r--r--  1 root root  217 May 30 12:24 ustreamer@.service:
                        pi@duet3:~ $ cat /etc/systemd/system/ustreamer@.service
                        cat: /etc/systemd/system/ustreamer@.service: No such file or directory
                        Looks like the first one is there, but not the second.
                        I think it's something with my editor but don't know how to check to see.
                          @luckyflyer maybe try making it executable?
                          sudo chmod +x /etc/systemd/system/ustreamer@.service
                          (long shot)
                            luckyflyer
                            tried it,
                            pi@duet3:~ $ sudo chmod +x /etc/systemd/system/ustreamer@.service
                            chmod: cannot access '/etc/systemd/system/ustreamer@.service': No such file or directory
                              luckyflyer
                              @gtj0 @bearer
                              Been reading up on the cat command, was wondering if that would be a good way to create and save the missing file?
                              A Former User? 2 Replies Last reply Reply Quote 0
                                hmm, does the filename have a : at the end?
                                sudo mv /etc/systemd/system/ustreamer@.service: /etc/systemd/system/ustreamer@.service
                                  luckyflyer
                                  @gtj0 said,
                                  I noticed that in
                                  that in line 29 it is
                                  ustreamer@.service:
                                  With a colon, instead of
                                  ustreamer@.service
                                  Is this a problem?
                                    luckyflyer
                                    They say great minds think alike................ maybe, I don't know lol.
                                      @luckyflyer said in Need help installing ustreamer:
                                      well, you can use cat and heredoc to create files like so
                                      cat << EOF > /tmp/yourfilehere
                                      These contents will be written to the file.
                                              This line is indented.
                                      EOF
                                      but redirects and sudo gets messy so you'd need something like
                                      cat << EOF | sudo tee /tmp/yourfilehere
                                      EOF
                                      but you'll have to deal with escaping on the command line etc. i to use it from time to time, but its not always the best option.
                                        luckyflyer
                                        How would I get rid of the :
                                          sudo mv renames it
                                          edit thats better.
                                            luckyflyer
                                            tried,
                                            pi@duet3:~ $ sudo mv /etc/systemd/system/ustreamer@.service: /etc/systemd/system/ustreamer@.service sudo chmod +x /etc/systemd/system/ustreamer@.service
                                            mv: target '/etc/systemd/system/ustreamer@.service' is not a directory
                                            pi@duet3:~ $
