    Need help installing ustreamer
    135
    10.8k
    • luckyflyerundefined
      luckyflyer
      I copy and pasted, nothing else to do right?
        luckyflyer
        roger one moment
          luckyflyer
          ok colon now gone,
          pi@duet3:~ $ ls -al /etc/systemd/system
          total 76
          drwxr-xr-x 17 root root 4096 May 31 00:25 .
          drwxr-xr-x  5 root root 4096 May 19 06:26 ..
          -rw-r--r--  1 root root 1551 Apr  7 06:06 autologin@.service
          drwxr-xr-x  2 root root 4096 May 19 07:56 basic.target.wants
          drwxr-xr-x  2 root root 4096 May 19 06:36 bluetooth.target.wants
          lrwxrwxrwx  1 root root   42 May 19 06:38 dbus-fi.w1.wpa_supplicant1.service -> /lib/systemd/system/wpa_supplicant.service
          lrwxrwxrwx  1 root root   37 May 19 06:36 dbus-org.bluez.service -> /lib/systemd/system/bluetooth.service
          lrwxrwxrwx  1 root root   40 May 19 06:37 dbus-org.freedesktop.Avahi.service -> /lib/systemd/system/avahi-daemon.service
          lrwxrwxrwx  1 root root   45 May 19 06:26 dbus-org.freedesktop.timesync1.service -> /lib/systemd/system/systemd-timesyncd.service
          lrwxrwxrwx  1 root root   34 May 19 06:38 dhcpcd5.service -> /lib/systemd/system/dhcpcd.service
          lrwxrwxrwx  1 root root   35 May 19 07:58 display-manager.service -> /lib/systemd/system/lightdm.service
          drwxr-xr-x  2 root root 4096 May 19 06:26 getty.target.wants
          drwxr-xr-x  2 root root 4096 May 19 06:31 getty@tty1.service.d
          drwxr-xr-x  2 root root 4096 May 19 07:58 graphical.target.wants
          drwxr-xr-x  2 root root 4096 May 19 06:35 halt.target.wants
          drwxr-xr-x  2 root root 4096 May 25 20:04 multi-user.target.wants
          drwxr-xr-x  2 root root 4096 May 19 06:28 network-online.target.wants
          drwxr-xr-x  2 root root 4096 May 19 06:35 poweroff.target.wants
          drwxr-xr-x  2 root root 4096 May 19 06:38 rc-local.service.d
          drwxr-xr-x  2 root root 4096 May 19 06:35 reboot.target.wants
          drwxr-xr-x  2 root root 4096 May 19 06:36 remote-fs.target.wants
          drwxr-xr-x  2 root root 4096 May 19 08:03 sockets.target.wants
          lrwxrwxrwx  1 root root   31 May 19 06:36 sshd.service -> /lib/systemd/system/ssh.service
          drwxr-xr-x  2 root root 4096 May 19 06:36 sysinit.target.wants
          lrwxrwxrwx  1 root root   35 May 19 06:28 syslog.service -> /lib/systemd/system/rsyslog.service
          drwxr-xr-x  2 root root 4096 May 19 06:29 timers.target.wants
          -rwxr-xr-x  1 root root  217 May 30 12:24 ustreamer@.service
          pi@duet3:~ $
            A Former User @luckyflyer
            @luckyflyer said in Need help installing ustreamer:
            ok colon now gone,
            should help, do the daemon-reload and start stuff again?
            luckyflyerundefined 1 Reply Last reply Reply Quote 0
              luckyflyer
              Now,
              cat /etc/systemd/system/ustreamer@.service
              looks like,
              pi@duet3:~ $ cat /etc/systemd/system/ustreamer@.service
              [Unit]
              Description=UStreamer for %I
              [Service]
              Type=simple
              ExecStart=/usr/local/bin/ustreamer --exit-on-parent-death -r 640x480 --static /tmp/ -d /dev/%i --host=0.0.0.0 --port=8080
              [Install]
              WantedBy=multi-user.target
              pi@duet3:~ $
                luckyflyer @A Former User
                daemon-reload? Sorry 12:30 am I pretty dingy can't last much longer.
                  this post https://forum.duet3d.com/post/157829
                    luckyflyer
                    It took it all now rebooting
                      luckyflyer
                      Rebooted and logged on, went to http://192.168.0.181:8080/stream but no image. When I manually start pgm image is there.
                        A Former User @gtj0
                        ###  When the Pi is back up, check the status of the service...
                        $ sudo systemctl status ustreamer@video0
                        anyways, i've got to see a lighthouse about a dog.
                          luckyflyer
                          It's see a man about a horse over here, anyway....
                          pi@duet3:~ $ sudo systemctl status ustreamer@video0
                          ā— ustreamer@video0.service - UStreamer for video0
                             Loaded: loaded (/etc/systemd/system/ustreamer@.service; enabled; vendor prese
                             Active: failed (Result: exit-code) since Sun 2020-05-31 00:35:26 MDT; 9min ag
                            Process: 351 ExecStart=/usr/local/bin/ustreamer --exit-on-parent-death -r 640x
                           Main PID: 351 (code=exited, status=203/EXEC)
                          May 31 00:35:25 duet3 systemd[1]: Started UStreamer for video0.
                          May 31 00:35:25 duet3 systemd[351]: ustreamer@video0.service: Failed to execute
                          May 31 00:35:25 duet3 systemd[351]: ustreamer@video0.service: Failed at step EXE
                          May 31 00:35:26 duet3 systemd[1]: ustreamer@video0.service: Main process exited,
                          May 31 00:35:26 duet3 systemd[1]: ustreamer@video0.service: Failed with result '
                          pi@duet3:~ $
                            luckyflyer
                            @bearer I'll pick up on it in 6 to 7 hours pretty worthless now, thanks again.
                            • gtj0undefined
                              gtj0 @luckyflyer
                              @luckyflyer @bearer Well, it looks like you guys made some progress anyway. šŸ™‚
                              ### Make sure ustreamer is where the service file thinks it is...
                              $ ls -al /usr/local/bin/ustreamer
                              ### In a separate terminal window, monitor the service.
                              $ sudo journalctl -fu ustreamer@video0
                              ### Back in the other terminal window....
                              $ sudo systemctl start ustreamer@video0
                              ### What shows up in the monitor?
                                I did go see an actual lighthouse, anyways OT.
                                sadly the status output cropped all the interesting bits, but i suspect the issue is you haven't installed ustreamer to /usr/local/bin/ustreamer
                                and should change
                                Line 6 ExecStart=/usr/local/bin/ustreamer --exit-on-parent-death -r 640x480 --static /tmp/ -d /dev/%i --host=0.0.0.0 --port=8080
                                to ExecStart=/home/pi/ustreamer/ustreamer --exit-on-parent-death -r 640x480 --static /tmp/ -d /dev/%i --host=0.0.0.0 --port=8080
                                or install it to /usr/local
                                • gtj0undefined
                                  gtj0 @A Former User
                                  @bearer Now what are the odds that we'd post pretty much the same thoughts at exactly the same time after almost 7 hours????? šŸ™‚
                                    A Former User @gtj0
                                    @gtj0 said in Need help installing ustreamer:
                                    cant answer now on my way to buy lottery ticket šŸ˜‰
                                      luckyflyer
                                      My goodness, I can't believe my bloodshot eyes IT WORKS.
                                      Loaded the changes, rebooted and 192.168.0.181 popped up immediately.
                                      @bearer and @gtj0 I wish I could buy you guys your favorite beverage.
                                      Thanks for staying with it till the end, I'm taking the rest of the day off. šŸ‘ šŸ¤™ 😁
                                        luckyflyer
                                        I may have spoken a little too soon. When I load @gtj0 's Duetlapse start command (I added the -dontwait so I don't need to start a print)
                                        /DuetLapse.py -camera web -weburl http://localhost:8080/stream -duet localhost -seconds 2 -detect none -dontwait
                                        I get,
                                        Capturing frame     0 after 2.70 seconds elapsed.
                                        failed: Connection refused.
                                        I played around with this a little yesterday. Duetlapse is not getting the image from
                                        for some reason. Any thoughts on this?
                                        A Former User? gtj0undefined 2 Replies Last reply Reply Quote 0
                                          use the force lucky
                                          i.e. netstat and systemctl status
                                          • gtj0undefined
                                            gtj0 @luckyflyer
                                            @luckyflyer
                                            You're running DuetLapse, ustreamer and DuetSoftwareFramework all on the same Pi yes?
