    Need help installing ustreamer
    135
    10.8k
      A Former User @luckyflyer
      @luckyflyer said in Need help installing ustreamer:
      tried,
      pi@duet3:~ $ sudo mv /etc/systemd/system/ustreamer@.service: /etc/systemd/system/ustreamer@.service sudo chmod +x /etc/systemd/system/ustreamer@.service
      mv: target '/etc/systemd/system/ustreamer@.service' is not a directory
      pi@duet3:~ $
      forum messed the formatting, scroll up to where i posted it
      • luckyflyerundefined
        luckyflyer
        same,
        pi@duet3:~ $
          @luckyflyer thats the same, its two commands, forum made it one line when i made it a quote. look for one that is two lines, i'm not gonna quote it again just to have the forum mess it up again
            luckyflyer
            I copy and pasted, nothing else to do right?
              luckyflyer
              roger one moment
                luckyflyer
                ok colon now gone,
                pi@duet3:~ $ ls -al /etc/systemd/system
                total 76
                drwxr-xr-x 17 root root 4096 May 31 00:25 .
                drwxr-xr-x  5 root root 4096 May 19 06:26 ..
                -rw-r--r--  1 root root 1551 Apr  7 06:06 autologin@.service
                drwxr-xr-x  2 root root 4096 May 19 07:56 basic.target.wants
                drwxr-xr-x  2 root root 4096 May 19 06:36 bluetooth.target.wants
                lrwxrwxrwx  1 root root   42 May 19 06:38 dbus-fi.w1.wpa_supplicant1.service -> /lib/systemd/system/wpa_supplicant.service
                lrwxrwxrwx  1 root root   37 May 19 06:36 dbus-org.bluez.service -> /lib/systemd/system/bluetooth.service
                lrwxrwxrwx  1 root root   40 May 19 06:37 dbus-org.freedesktop.Avahi.service -> /lib/systemd/system/avahi-daemon.service
                lrwxrwxrwx  1 root root   45 May 19 06:26 dbus-org.freedesktop.timesync1.service -> /lib/systemd/system/systemd-timesyncd.service
                lrwxrwxrwx  1 root root   34 May 19 06:38 dhcpcd5.service -> /lib/systemd/system/dhcpcd.service
                lrwxrwxrwx  1 root root   35 May 19 07:58 display-manager.service -> /lib/systemd/system/lightdm.service
                drwxr-xr-x  2 root root 4096 May 19 06:26 getty.target.wants
                drwxr-xr-x  2 root root 4096 May 19 06:31 getty@tty1.service.d
                drwxr-xr-x  2 root root 4096 May 19 07:58 graphical.target.wants
                drwxr-xr-x  2 root root 4096 May 19 06:35 halt.target.wants
                drwxr-xr-x  2 root root 4096 May 25 20:04 multi-user.target.wants
                drwxr-xr-x  2 root root 4096 May 19 06:28 network-online.target.wants
                drwxr-xr-x  2 root root 4096 May 19 06:35 poweroff.target.wants
                drwxr-xr-x  2 root root 4096 May 19 06:38 rc-local.service.d
                drwxr-xr-x  2 root root 4096 May 19 06:35 reboot.target.wants
                drwxr-xr-x  2 root root 4096 May 19 06:36 remote-fs.target.wants
                drwxr-xr-x  2 root root 4096 May 19 08:03 sockets.target.wants
                lrwxrwxrwx  1 root root   31 May 19 06:36 sshd.service -> /lib/systemd/system/ssh.service
                drwxr-xr-x  2 root root 4096 May 19 06:36 sysinit.target.wants
                lrwxrwxrwx  1 root root   35 May 19 06:28 syslog.service -> /lib/systemd/system/rsyslog.service
                drwxr-xr-x  2 root root 4096 May 19 06:29 timers.target.wants
                -rwxr-xr-x  1 root root  217 May 30 12:24 ustreamer@.service
                pi@duet3:~ $
                  ok colon now gone,
                  should help, do the daemon-reload and start stuff again?
                  luckyflyerundefined 1 Reply Last reply Reply Quote 0
                    luckyflyer
                    Now,
                    cat /etc/systemd/system/ustreamer@.service
                    looks like,
                    pi@duet3:~ $ cat /etc/systemd/system/ustreamer@.service
                    [Unit]
                    Description=UStreamer for %I
                    [Service]
                    Type=simple
                    ExecStart=/usr/local/bin/ustreamer --exit-on-parent-death -r 640x480 --static /tmp/ -d /dev/%i --host=0.0.0.0 --port=8080
                    [Install]
                    WantedBy=multi-user.target
                    pi@duet3:~ $
                      luckyflyer @A Former User
                      daemon-reload? Sorry 12:30 am I pretty dingy can't last much longer.
                        this post https://forum.duet3d.com/post/157829
                          luckyflyer
                          It took it all now rebooting
                            luckyflyer
                            Rebooted and logged on, went to http://192.168.0.181:8080/stream but no image. When I manually start pgm image is there.
                              A Former User @gtj0
                              ###  When the Pi is back up, check the status of the service...
                              $ sudo systemctl status ustreamer@video0
                              anyways, i've got to see a lighthouse about a dog.
                                luckyflyer
                                It's see a man about a horse over here, anyway....
                                pi@duet3:~ $ sudo systemctl status ustreamer@video0
                                ā— ustreamer@video0.service - UStreamer for video0
                                   Loaded: loaded (/etc/systemd/system/ustreamer@.service; enabled; vendor prese
                                   Active: failed (Result: exit-code) since Sun 2020-05-31 00:35:26 MDT; 9min ag
                                  Process: 351 ExecStart=/usr/local/bin/ustreamer --exit-on-parent-death -r 640x
                                 Main PID: 351 (code=exited, status=203/EXEC)
                                May 31 00:35:25 duet3 systemd[1]: Started UStreamer for video0.
                                May 31 00:35:25 duet3 systemd[351]: ustreamer@video0.service: Failed to execute
                                May 31 00:35:25 duet3 systemd[351]: ustreamer@video0.service: Failed at step EXE
                                May 31 00:35:26 duet3 systemd[1]: ustreamer@video0.service: Main process exited,
                                May 31 00:35:26 duet3 systemd[1]: ustreamer@video0.service: Failed with result '
                                pi@duet3:~ $
                                  luckyflyer
                                  @bearer I'll pick up on it in 6 to 7 hours pretty worthless now, thanks again.
                                  • gtj0undefined
                                    gtj0 @luckyflyer
                                    @luckyflyer @bearer Well, it looks like you guys made some progress anyway. šŸ™‚
                                    ### Make sure ustreamer is where the service file thinks it is...
                                    $ ls -al /usr/local/bin/ustreamer
                                    ### In a separate terminal window, monitor the service.
                                    $ sudo journalctl -fu ustreamer@video0
                                    ### Back in the other terminal window....
                                    $ sudo systemctl start ustreamer@video0
                                    ### What shows up in the monitor?
                                      I did go see an actual lighthouse, anyways OT.
                                      sadly the status output cropped all the interesting bits, but i suspect the issue is you haven't installed ustreamer to /usr/local/bin/ustreamer
                                      and should change
                                      Line 6 ExecStart=/usr/local/bin/ustreamer --exit-on-parent-death -r 640x480 --static /tmp/ -d /dev/%i --host=0.0.0.0 --port=8080
                                      to ExecStart=/home/pi/ustreamer/ustreamer --exit-on-parent-death -r 640x480 --static /tmp/ -d /dev/%i --host=0.0.0.0 --port=8080
                                      or install it to /usr/local
                                      • gtj0undefined
                                        gtj0 @A Former User
                                        @bearer Now what are the odds that we'd post pretty much the same thoughts at exactly the same time after almost 7 hours????? šŸ™‚
                                          A Former User @gtj0
                                          @gtj0 said in Need help installing ustreamer:
                                          cant answer now on my way to buy lottery ticket šŸ˜‰
                                            luckyflyer
                                            My goodness, I can't believe my bloodshot eyes IT WORKS.
                                            Loaded the changes, rebooted and 192.168.0.181 popped up immediately.
                                            @bearer and @gtj0 I wish I could buy you guys your favorite beverage.
                                            Thanks for staying with it till the end, I'm taking the rest of the day off. šŸ‘ šŸ¤™ 😁
