Need help installing ustreamer
@luckyflyer thats the same, its two commands, forum made it one line when i made it a quote. look for one that is two lines, i'm not gonna quote it again just to have the forum mess it up again
I copy and pasted, nothing else to do right?
roger one moment
ok colon now gone,
pi@duet3:~ $ ls -al /etc/systemd/system total 76 drwxr-xr-x 17 root root 4096 May 31 00:25 . drwxr-xr-x 5 root root 4096 May 19 06:26 .. -rw-r--r-- 1 root root 1551 Apr 7 06:06 autologin@.service drwxr-xr-x 2 root root 4096 May 19 07:56 basic.target.wants drwxr-xr-x 2 root root 4096 May 19 06:36 bluetooth.target.wants lrwxrwxrwx 1 root root 42 May 19 06:38 dbus-fi.w1.wpa_supplicant1.service -> /lib/systemd/system/wpa_supplicant.service lrwxrwxrwx 1 root root 37 May 19 06:36 dbus-org.bluez.service -> /lib/systemd/system/bluetooth.service lrwxrwxrwx 1 root root 40 May 19 06:37 dbus-org.freedesktop.Avahi.service -> /lib/systemd/system/avahi-daemon.service lrwxrwxrwx 1 root root 45 May 19 06:26 dbus-org.freedesktop.timesync1.service -> /lib/systemd/system/systemd-timesyncd.service lrwxrwxrwx 1 root root 34 May 19 06:38 dhcpcd5.service -> /lib/systemd/system/dhcpcd.service lrwxrwxrwx 1 root root 35 May 19 07:58 display-manager.service -> /lib/systemd/system/lightdm.service drwxr-xr-x 2 root root 4096 May 19 06:26 getty.target.wants drwxr-xr-x 2 root root 4096 May 19 06:31 getty@tty1.service.d drwxr-xr-x 2 root root 4096 May 19 07:58 graphical.target.wants drwxr-xr-x 2 root root 4096 May 19 06:35 halt.target.wants drwxr-xr-x 2 root root 4096 May 25 20:04 multi-user.target.wants drwxr-xr-x 2 root root 4096 May 19 06:28 network-online.target.wants drwxr-xr-x 2 root root 4096 May 19 06:35 poweroff.target.wants drwxr-xr-x 2 root root 4096 May 19 06:38 rc-local.service.d drwxr-xr-x 2 root root 4096 May 19 06:35 reboot.target.wants drwxr-xr-x 2 root root 4096 May 19 06:36 remote-fs.target.wants drwxr-xr-x 2 root root 4096 May 19 08:03 sockets.target.wants lrwxrwxrwx 1 root root 31 May 19 06:36 sshd.service -> /lib/systemd/system/ssh.service drwxr-xr-x 2 root root 4096 May 19 06:36 sysinit.target.wants lrwxrwxrwx 1 root root 35 May 19 06:28 syslog.service -> /lib/systemd/system/rsyslog.service drwxr-xr-x 2 root root 4096 May 19 06:29 timers.target.wants -rwxr-xr-x 1 root root 217 May 30 12:24 ustreamer@.service pi@duet3:~ $
@luckyflyer said in Need help installing ustreamer:
ok colon now gone,
should help, do the daemon-reload and start stuff again?
Now,
cat /etc/systemd/system/ustreamer@.service
looks like,
pi@duet3:~ $ cat /etc/systemd/system/ustreamer@.service [Unit] Description=UStreamer for %I [Service] Type=simple ExecStart=/usr/local/bin/ustreamer --exit-on-parent-death -r 640x480 --static /tmp/ -d /dev/%i --host=0.0.0.0 --port=8080 [Install] WantedBy=multi-user.target pi@duet3:~ $
daemon-reload? Sorry 12:30 am I pretty dingy can't last much longer.
this post https://forum.duet3d.com/post/157829
It took it all now rebooting
Rebooted and logged on, went to http://192.168.0.181:8080/stream but no image. When I manually start pgm image is there.
### When the Pi is back up, check the status of the service... $ sudo systemctl status ustreamer@video0
anyways, i've got to see a lighthouse about a dog.
It's see a man about a horse over here, anyway....
pi@duet3:~ $ sudo systemctl status ustreamer@video0 ā ustreamer@video0.service - UStreamer for video0 Loaded: loaded (/etc/systemd/system/ustreamer@.service; enabled; vendor prese Active: failed (Result: exit-code) since Sun 2020-05-31 00:35:26 MDT; 9min ag Process: 351 ExecStart=/usr/local/bin/ustreamer --exit-on-parent-death -r 640x Main PID: 351 (code=exited, status=203/EXEC) May 31 00:35:25 duet3 systemd[1]: Started UStreamer for video0. May 31 00:35:25 duet3 systemd[351]: ustreamer@video0.service: Failed to execute May 31 00:35:25 duet3 systemd[351]: ustreamer@video0.service: Failed at step EXE May 31 00:35:26 duet3 systemd[1]: ustreamer@video0.service: Main process exited, May 31 00:35:26 duet3 systemd[1]: ustreamer@video0.service: Failed with result ' pi@duet3:~ $
@bearer I'll pick up on it in 6 to 7 hours pretty worthless now, thanks again.
@luckyflyer @bearer Well, it looks like you guys made some progress anyway.
### Make sure ustreamer is where the service file thinks it is... $ ls -al /usr/local/bin/ustreamer ### In a separate terminal window, monitor the service. $ sudo journalctl -fu ustreamer@video0 ### Back in the other terminal window.... $ sudo systemctl start ustreamer@video0 ### What shows up in the monitor?
I did go see an actual lighthouse, anyways OT.
sadly the status output cropped all the interesting bits, but i suspect the issue is you haven't installed ustreamer to
and should change
Line 6
to
ExecStart=/home/pi/ustreamer/ustreamer --exit-on-parent-death -r 640x480 --static /tmp/ -d /dev/%i --host=0.0.0.0 --port=8080
or install it to
/usr/local
@bearer Now what are the odds that we'd post pretty much the same thoughts at exactly the same time after almost 7 hours?????
@gtj0 said in Need help installing ustreamer:
cant answer now on my way to buy lottery ticket
My goodness, I can't believe my bloodshot eyes IT WORKS.
Loaded the changes, rebooted and 192.168.0.181 popped up immediately.@bearer and @gtj0 I wish I could buy you guys your favorite beverage.
Thanks for staying with it till the end, I'm taking the rest of the day off. -
I may have spoken a little too soon. When I load @gtj0 's Duetlapse start command (I added the -dontwait so I don't need to start a print)
/DuetLapse.py -camera web -weburl http://localhost:8080/stream -duet localhost -seconds 2 -detect none -dontwait
I get,
Capturing frame 0 after 2.70 seconds elapsed. failed: Connection refused.
I played around with this a little yesterday. Duetlapse is not getting the image from
for some reason. Any thoughts on this?
use the force lucky
i.e. netstat and systemctl status
