    Select power supply. who can help?
    453
    • JoergS5undefined
      JoergS5 @deckingman
      @deckingman said in Select power supply. who can help?:
      @JoergS5 said in Select power supply. who can help?:
      ........................- 9 motors means high power requirement like in the range 500W
      How do you arrive at that statement? 200 Watts is more than adequate for my machine (excluding the bed heater) which has 13 stepper motors.
      I calculated Nema 23 = 4 A * 24 V = 100 W * 9 = 900 W maximum (minus Nema 17, but some Nema 23 have more than 4 A., They will not be active at the same time, so half the value, but some reserve to be sure, because I don't know the application). But you have far more experience, so you will be right.
      => calculation is incorrect, see below. There is also a good thread here to explain which I found now: https://reprap.org/forum/read.php?160,628636
      zaptaundefined duttiundefined 2 Replies Last reply Reply Quote 0
      • zaptaundefined
        zapta @JoergS5
        Steppers budget should be calculated by power not by current. A 4A stepper doesn't consume 4A from the power supply, only a small fraction of it.
        • JoergS5undefined
          JoergS5
          @zapta Thanks for explaining, I will change my recommendation.
            deckingman @JoergS5
            @JoergS5 Just to add that usually the rated current is also quoted at the rated voltage, which is typically something like 3.6 V. So in very simple terms, 4A at 3.6 V is 14.4 Watts ( multiplied by 9 motors =129.6 Watts) but in practice, the consumption is even less that this.
            JoergS5undefined duttiundefined 2 Replies Last reply Reply Quote 0
            • JoergS5undefined
              JoergS5 @deckingman
              @deckingman Thank you for the correction. Stepper usage (= printing cost) is less expensive than I thought...
                deckingman @JoergS5
                @JoergS5 No worries. By way of a bit of additional information, not long ago I fitted a 24V DC UPS with two small 12V 20AH "leisure" batteries wired in series to give 24V and which power just the printer motors, hot end heaters, and fans (but not the bed or any non-essential "accessories" such as lights). These are sufficient to run my beast of a printer for very many hours - possibly as much as a whole day and night or more.
                • JoergS5undefined
                  JoergS5 @deckingman
                  @deckingman I saw the thread when you described what you did and it was interesting. I thought about a flywheel solution with energy from solar modules, but flywheels loose energy very quickly, so I postponed the realisation. I still search for a low cost energy storage.
                  • duttiundefined
                    dutti @JoergS5
                    @JoergS5
                    I have a 85x85cm heatbed. That needs a lot of power.
                    Also I have 4 nema 23 and 7 other motors (some of then will be a nema23 with 3a / maybe).
                    After my calculation I think the following power supply is the right one.
                    Now, I prefer Meanwell HRP-600-24.
                    Can anybody just tell me if I have to connect the expansion board directly to the power supply or indirect via duet3 6h board?
                    Thank you all!!!!
                    • JoergS5undefined
                      JoergS5 @dutti
                      @barbarossa-cologne @deckingman is the better address to answer it, he has more experience. I would use one PSU for the printer itself with 200 W and a separate PSU for bed heater, controlled by a SSR. The heatbed is very big, so separation makes sense to not use current through the Duet, which must be cooled then, IMHO.
                      An idea for construction: myself I design a printer where I use different print beds: if I want to print a small object, I need only a small print bed, for a big one a big bed. So if you design to exchange to use a small bed if you print something small, you could spare a lot of power.
                      • duttiundefined
                        dutti @deckingman
                        @deckingman
                        Thanks. I did my calculation like you said.
                        Do you know to what I should give attention with the 2500 watt silicon heater?
                        I'm new in this world of printing and building printers.
                        Thanks for all answers!
