    Just updated FW to 3.1.1. Now i get failed to enable endstops.
    Firmware installation
    663
      A Former User
      Just updated FW to 3.1.1. Now i get failed to enable endstops. I used the online configurator but still not working
      • hmortensenundefined
        hmortensen
        You have to describe the problem a bit better and post your config file.
          A Former User
          I upgraded my firmware from firmware 2.x.x to 3.0 and then to 3.1.1 but now when I hit homeall the z just moves up about 25mm and then down 25mm and thats it. I tried homing each axis on its own and the exact same thing happens. The z goes up and down. Im not getting an error today but it obviously isnt doing what its supposed to. Ive read the update notes about 3.1.1 and from what I can tell everything seems right.
          ; generated by RepRapFirmware Configuration Tool v3.1.1 on Sun Jun 07 2020 22:37:37 GMT-0600 (Mountain Daylight Time)
          M550 P"RED Rodriguez Black Widow" ; set printer name
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P2 S0 ; physical drive 2 goes backwards
          M92 X80.53 Y80.27 Z11589.87 E420.00 ; set steps per mm
          M203 X9960.00 Y9960.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
          M906 X1100 Y1100 Z1100 E650 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X370 Y241 Z395 S0 ; set axis maxima
          M950 S0 C"exp.heater5" ; create servo pin 0 for BLTouch
          M558 P9 C"zprobe.in+zprobe.mod" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X11 Y57 Z1 ; set Z probe trigger value, offset and trigger height
          M557 X25:345 Y25:222 S20 ; define mesh grid
          ; Custom settings
          T0 ; select first tool
            @chichirod said in Just updated FW to 3.1.1. Now i get failed to enable endstops.:
            What sort of endstops are they? The above lines will work for normally-closed microswitches. If you have normally-open switches, use:
            M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin xstop
            M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin ystop
              A Former User @dc42
              @dc42 said in Just updated FW to 3.1.1. Now i get failed to enable endstops.:
              Ok that fixed my X and Y endstops, Thank you but my BLtouch is not working.
                Phaedrux Moderator @A Former User
                What exactly doesn't work?
                For starters try this M558 P9 C"^zprobe.in" H5 F120 T6000
                What do you have in your deploy and retract macro?
                  A Former User @Phaedrux
                  @Phaedrux
                  The line you gave didnt work, but thank you for trying.
                  My DEPLOY:
                  M558 P1 C"zprobe.in+zprobe.mod" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
                  My RETRACT:
                  M280 P3 S90 I1
                  • JoergS5undefined
                    JoergS5 @A Former User
                    @chichirod you can check https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_RepRapFirmware_Num_3 steps 2+3 and 6 to change your M558 command in config.g and the deployprobe.g file. Adding the ^ and removing the +zprobe.mod and in the deployprobe.g removing the M558 and adding the M280 command.
                    • mikep419undefined
                      mikep419
                      I’m no expert on the BL Touch. Had one for about 2 days and tossed it in a return envelope. But I did just finish upgrading to 3.1.1 so I’ll try to help.
                      Change the M574 Z1 S2 to M574 Z0 ; no z endstop
                      You are attempting to use the probe as the endstop correct? So you will need to call the probe with a G30 command to probe the bed and set the position. G29 will also call the probe for leveling.
                      Not sure what the +zprobe.mod is for? From what i read that’s for maestro...try removing that.
                      Also as mentioned the M558 command I dont think should be in your deployprobe.g it should be an M280 command.
                        A Former User @mikep419
                        @mikep419 said in Just updated FW to 3.1.1. Now i get failed to enable endstops.:
                        M574 Z0
                        I tried your suggestion and then attempted a homing all and the machine made a high pitched squel and it seemed like the print head wanted to move but couldnt. I have played with so many things now I think I may have messed something up in my config file.
                        ; generated by RepRapFirmware Configuration Tool v3.1.1 on Mon Jun 08 2020 14:03:23 GMT-0600 (Mountain Daylight Time)
                        M92 X80.53 Y80.27 Z401589.87 E425.00 ; set steps per mm
                        M566 X300.00 Y300.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                        M574 Z0 ; configure Z-probe endstop for low end on Z
                        M558 P1 C"zprobe.in^" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
                        G31 P500 X-11 Y57 Z1 ; set Z probe trigger value, offset and trigger height
                        ; Custom settings
                        mikep419undefined 2 Replies Last reply Reply Quote 0
                        • mikep419undefined
                          mikep419 @A Former User
                          @chichirod the ^ should be at the beginning ^zprobe.in
                          Have you tried deploying and retracting probe with M401 and M402?
                          • Simonjbundefined
                            Simonjb
                            You are missing defining a pin with M950 for the servo on the the BL Touch. My config.g for a Hypercube reads -
                            M950 S0 C"exp.heater7"                             ; assign heater7 for bltouch
                            M558 P9 C"^zprobe.in" H5 F120 T6000 A30 S0.02      ; Set Z probe type to bltouch and the dive height + speeds
                            G31 P500 X28 Y0 Z0.812                             ; set Z probe trigger value, offset and trigger height
                            M557 X45:300 Y5:295 S40                            ; define mesh grid
                            Have a look here https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch
                            Anet A8 (lots of mods...). Hypercube Evolution with DuetWifi and 5" PanelDue
                              If it's a BlTouch it should be P9 and the ^ in front of the zprobe.in
                              Please post your homing files as well and tell us where your endstops are physically located.
                              • mikep419undefined
                                @chichirod I don’t know what effect it would have but I dont see a M669 defining the kinematic type of printer in your config.g
                                  Phaedrux Moderator @mikep419
                                  The default is cartesian.
                                    @Phaedrux I did your changes but unfortunately still not working. Here are the homing files.
                                    ; homex.g
                                    ; called to home the X axis
                                    G91 ; relative positioning
                                    G1 H1 X-375 F1800 ; move quickly to X axis endstop and stop there (first pass)
                                    G1 H2 X5 F6000 ; go back a few mm
                                    G1 H1 X-375 F360 ; move slowly to X axis endstop once more (second pass)
                                    G1 H2 Z-5 F6000 ; lower Z again
                                    G90 ; absolute positioning
                                    ; homey.g
                                    ; called to home the Y axis
                                    G1 H1 Y-246 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                                    G1 H2 Y5 F6000 ; go back a few mm
                                    G1 H1 Y-246 F360 ; move slowly to Y axis endstop once more (second pass)
                                    ; homez.g
                                    ; called to home the Z axis
                                    G1 X36 Y-32 F6000 ; go to first probe point
                                    ;G91 ; relative positioning
                                    ;G90 ; absolute positioning
                                    ; homez.g
                                      Black Widow
                                      I assume this is a Tevo Black Widdow cartesian printer?
                                      You've posted your homez twice, but not your homeall.
                                      This doesn't seem like a good place to probe the bed. Instead you should move the probe so that it's in the enter of the bed.
                                      Compare your bltouch config to the one posted by @Simonjb
                                      A Former User? 2 Replies Last reply Reply Quote 0
                                        @Phaedrux Sorry about that.
                                        ; homeall.g
                                        ; called to home all axes
                                        G1 H1 X-375 Y-246 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                                        G1 H2 X5 Y5 F6000 ; go back a few mm
                                        G1 H1 X-375 Y-246 F360 ; move slowly to X and Y axis endstops once more (second pass)
                                        G1 X36 Y-32 F6000 ; go to first bed probe point and home Z
                                          @Phaedrux Yes it is a Tevo Black Widow Cartesian Printer
