Z-probe problems
hello,
thank you in advanced.
due the test runs im facing a problem with BLTouch z-probe on my Cartesian CR10S5.
it worked for the first time only. then no response although when i pull the trigger and push back it lits as it should.
please advice ..my config.g:
; Configuration file for Duet WiFi (firmware version 2.00)
; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat May 16 2020 18:12:05 GMT+0400 (Gulf Standard Time); General preferences
M550 P"Badr's CR10S5" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M350 X256 Y256 Z256 E256 I1 ; configure microstepping without interpolation
M92 X1280.00 Y1280.00 Z6400.00 E415.00 ; set steps per mm
M203 X9000.00 Y9000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
M906 X900 Y1200 Z800 E700 I50 ; set motor currents (mA) and motor idle factor in per cent
M208 X500 Y500 Z500 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; set endstops controlled by probe; Z-Probe
M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
M558 P9 H5 F120 R0.2 T6000 A5 B1 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X-38.2 Y0 Z3 ; set Z probe trigger value, offset and trigger height
M557 X40:440 Y40:440 S20 ; define mesh grid; Heaters
M140 H-1 ; disable heated bed
M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1
M106 P2 S1 I0 F500 H1 T45 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
ive tried changing gcode from here and there but no use .. still no response and hits the heatbed.
my deploy probe:
; deployprobe.g
; called to deploy a physical Z probe
; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat May 16 2020 18:12:05 GMT+0400 (Gulf Standard Time)M280 P3 S10 I1 ; deploy BLTouch
my retract.g :
; retractprobe.g
; called to retract a physical Z probe
; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat May 16 2020 18:12:05 GMT+0400 (Gulf Standard Time)M280 P3 S90 I1 ; retract BLTouch
homeall.g:
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat May 16 2020 18:12:05 GMT+0400 (Gulf Standard Time)M290 R0 S0 ; Reset babystepping
G91 ; relative positioning
G1 S2 Z5 F6000 ; lift Z relative to current position
G1 S1 X-505 Y-505 F3600 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 S2 X5 Y5 F6000 ; go back a few mm
G1 S1 X-505 Y-505 F360 ; move slowly to X and Y axis endstops once more (second pass)
G90 ; absolute positioning
M98 Pdeployprobe.g ; deploy mechanical Z probe
G1 X211.8 Y250 F6000 ; go to the bed centre and home Z
M98 Pretractprobe.g ; retract mechanical Z probe; Uncomment the following lines to lift Z after probing
G1 Z5 F100 ; lift Z relative to current position
G90 ; absolute positioninghomez.g:
; homez.g
; called to home the Z axis
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
G90 ; absolute positioning -
This post is deleted! -
from first fast look at files - you dont need to call retractprobe.g and deployprobe.g from homing files, assuming your probe type is defined P9, as you have. So delete those lines or comment them out.
@aidar thank you
will try now -
@aidar same .. no change .. still slams the bed
after changing files, did you reboot your duet? better to turn it off completely and then turn back on after few seconds to be sure...
I also reccomend to change G31 P value to 25 for BLTouch.
After those edits in your files, reboot your board and try from console if M401 and M402 works at all. -
@aidar did reboot .. same issue
changed : M558 P9 H5 F120 R0.2 T6000 A5 B1 ; set Z probe type to bltouch and the dive height + speeds
to : M558 P3 H5 F120 R0.2 T6000 A5 B1 ; set Z probe type to bltouch and the dive height + speeds
got a reading on the zprobe (18) but still slamed the bed, wnt back to :
M558 P9 H5 F120 R0.2 T6000 A5 B1 ; set Z probe type to bltouch and the dive height + speeds -
@b45666 are your deploy and retract filenames sys/deployprobe.g and sys/retractprobe.g ? You mention a different filename above.
@JoergS5 yes sir, deployprobe.g & retractprobe.g
@aidar changed P to 25 .. no change
no response to M401 / M402, although on the web interface it gives a check mark as sent -
If no response to M401/402, then check and doublecheck your servo signal wire connections - the one that is yellow or orange or similar and connected to Heater3 pin. Of course check all other connections to BLTouch as well. If you are using original cable, then its known as "not so good". I had similar problem with my first BLTouch, it was all about connections.
@aidar thank you so much .. bad connection .. solved & back in business
Glad you solved it.
