    Duet 2 Ethernet and SBC
    Beta Firmware
    29
    302
    34.2k
    • smoki3undefined
      smoki3
      I saw that the next release will support SBC on the Duet 2 Ethernet. This will be released in a seperate firmware file. Will there also another SBC Version requiered?
      I compiled the firmware well, but dont know how to connect SBC with Duet2
        A Former User @smoki3
        @smoki3 said in Duet 2 Ethernet and SBC:
        don't think this has been documented yet, but essentially you have to remove the ethernet module and connect the spi bus + interrupt line to the pi.
        (edit: pins you'll find between the sources and the schematic for the duet3)
        smoki3undefined 1 Reply Last reply Reply Quote 0
        • smoki3undefined
          smoki3 @A Former User
          @bearer Oh you think I have to disconnect the ethernet module? I thought it will work over a ethernet cable.
            @smoki3 it'll work the same as for the Duet 3, using the fast SPI bus, which is used for the Ethernet on the Duet 2 so yes.
            So some searching and you'll find plenty posts about it, its been a much anticipated feature. Removing the Ethernet module is simple enough, release the plastic snap in spacers and just lift it straight up out of its header and run some 0.1" dupont style wires to a raspberry pi.
            • smoki3undefined
              smoki3
              What is the TFR_RDY Pin? Dont find it on the Duet2
                @bearer said in Duet 2 Ethernet and SBC:
                (as in find the pin number in the duet3 source, and work backwards)
                  T3P3Tony administrators @A Former User
                  from @wilriker who did the test and firmware work for this:
                  This is the pins on the back of the Duet 2:
                  • SPI: MISO, MOSI, SPCK, NPSC0
                  • Data Ready: EDR -> TFR_RDY
                  • GND (for example next to NPSC0) to connect to the RPi.
                  These use the same pins on the RPI as Duet 3 uses:
                  Note that as a minimum protection you should connect these pins through a series resistor to limit max current. The resistor value is a compromise e.g. 470R will provide reasonable protection (7mA at 3.3V) but will slow down the SPI bus. 47R will allow for better bus speeds but with less protection.
                  This feature is experimental in Duet 2. We are considering a small hardware board to provide the physical interfacing and signal buffering.
                  smoki3undefined A Former User? 2 Replies Last reply Reply Quote 2
                    A Former User
                    (btw when i did the digging it seems the TRF_RDY pin on the wiring diagram is called SPI1_DATA_READY on the schematic, other than that straight forward enough to get from SPI1_DATA_READY -> PE2 -> LinuxTfrReadyPin for Duet3 and LinuxTfrReadyPin -> PD31 -> ESP_DATA_READY -> R17 -> EDR_CONN for the Duet2)
                    • Luke'sLaboratoryundefined
                      Luke'sLaboratory
                      Much of the conversation is about the D2 with Ethernet, can this be done with the WIFI version by what I assume would be desoldering the module off?
                      Luke
                      http://lukeslab.online
                      smoki3undefined A Former User? 2 Replies Last reply Reply Quote 0
                      • smoki3undefined
                        smoki3 @Luke'sLaboratory
                        @Luke-sLaboratory said in Duet 2 Ethernet and SBC:
                        Yes with desoldered wifi module it should work fine
                          A Former User @Luke'sLaboratory
                          it might be possible to just upload a custom wifi firmware that leaves the spi buss and interrupt line as high impedance inputs, and enters deep sleep (but such a firmware would need to be created tested from here)
                          edit: it totes works
                          edit: if anyone is to try this - update wifi firmware first, the sbc firmware does not accept M997 S1.
                          edit: either wifi needs to go or my hired hands messed up the wirng.
                          6/26/2020, 11:51:59 AM	Connection to Duet established
                          6/26/2020, 11:52:01 AM	Warning: Lost connection to Duet (Board is not available (no data response))
                          6/26/2020, 11:52:01 AM	Connection to Duet established
                          6/26/2020, 11:52:02 AM	Warning: Lost connection to Duet (Board is not available (no data response))
                          6/26/2020, 11:52:02 AM	Connection to Duet established
                          6/26/2020, 11:52:06 AM	Warning: Lost connection to Duet (Board is not available (no data response))
                          6/26/2020, 11:52:06 AM	Connection to Duet established
                          6/26/2020, 11:52:07 AM	M115
                          FIRMWARE_NAME: RepRapFirmware for Duet 2 + SBC FIRMWARE_VERSION: 3.02-beta ELECTRONICS: Duet 2 1.02 or later + SBC FIRMWARE_DATE: 2020-06-25b1
                          6/26/2020, 11:52:10 AM	Warning: Lost connection to Duet (Board is not available (no header))
                          6/26/2020, 11:52:10 AM	Connection to Duet established
                          6/26/2020, 11:52:11 AM	Warning: Lost connection to Duet (Board is not available (no header response))
                          6/26/2020, 11:52:11 AM	Connection to Duet established
                          • Dougal1957undefined
                            Dougal1957
                            Will the standard DSF system for the SBC remain the same or will we need a different image?
                            • smoki3undefined
                              smoki3 @T3P3Tony
                              @T3P3Tony so you recommend any resistor which was working fine in you tests?
                                @smoki3 maybe you'll find some clues if you look at the duet 2 and 3 schematics. i.e. the EDR_CONN already has R17 on the duet 2, and the duet 3 schematic show which values they used there
                                • smoki3undefined
                                  @bearer where do I find the schematic
                                    https://github.com/Duet3D/Duet3-Mainboard-6HC
                                    and
                                    https://github.com/T3P3/Duet/tree/master/Duet2/Duet2v1.04
                                    or just google it?
                                    smoki3undefined 1 Reply Last reply Reply Quote 1
                                    • smoki3undefined
                                      @bearer thanks!
                                      I googled for it but unter "duet 3 schematics" you don't get it 🙂
                                      In the duet3 schematics they use 100Ohm resistors.
                                      The duet 2 has for MOSI, MISO and SPCK 47 Ohm and for NPSC0 and EDR 2,2 kOhm
                                      @T3P3Tony NPSC0 and EDR have no influence on the speed, right?
                                      • wilrikerundefined
                                        wilriker @smoki3
                                        That's correct.
                                        I tested with no resistors and with 500R (two 1K in parallel since that's what I just had at hand at the time). The difference is significant but at the same time negligible. Without resistors you can get up to 25-27MHz. With 500R in series you "only" get 13.5-15MHz - but that's still plenty and most likely more than your ever need while at the same time providing you much more protection.
                                        @Dougal1957 DSF is absolutely the same. It does neither know nor care if it's a D3 or a D2 on the other end.
                                        Manuel
                                        My Tool Collection
                                        smoki3undefined A Former User? 3 Replies Last reply Reply Quote 0
                                        • smoki3undefined
                                          smoki3 @wilriker
                                          @wilriker
                                          Okay cool. I just ordered some experimental stripboards and the 26 pin connector. So I can test it next week.
                                          I will build up a small pcb with the resistors on it.
                                          So I will just add some resistors to the MISO, MOSI and SPCK pins. The 2.2kOhm on the two other pins should be enough.
                                          How fast is an ESP? Do they also reach the 25 MHz?
                                          • wilrikerundefined
                                            wilriker @smoki3
                                            The current configuration sets it to 26.7MHz. The ESP (clocked at 80MHz) can go up to at least 40MHz from what I can see in the source code comments.
                                            Manuel
                                            My Tool Collection
