    CR-10S Pro stepper recommendation
    911
      Limit your search to 34mm motors
      • MartinNYHCundefined
        MartinNYHC
        Yes, sure 😉 For 0.9 there are no results. For 1.8 there are four but the max. current is 1.33A. My intention was to hit the sweet spot 🙂
          The Z axis doesn't get a lot of action so the specs don't need to be at the same level as x and y.
            MartinNYHC
            That's true.
            Based on the availability in Germany I've choosen:
            2 x 17HM19-2004S1 for X/Y
            2 x 17HS13-0404S1 for Z
            1 x 17HS08-1004S for E
            Do you think that works satisfactorily?
              Yes those look ok provided the Z motor will fit. The E motor will be ok when using a geared extruder, but those tiny pancakes have limitations on torque that you will need to be aware of. I use those X Y motors on my corexy and have been happy with them.
                MartinNYHC
                I'm using a Bondtech BMG-M with Mosquito. I think that will work.
                Thanks for your help!
                  MartinNYHC
                  Good news is, that the steppers are attached to the printer. Bad news is, my printer is louder than before 😵
                  Joking aside. Now i seem to have a Z axis problem. It makes a terrible very very loud noise when moving. Just found out, that the steppers are making noises when moving and the noise is transfered to the Z axis thread and will be boosted.
                  Am I doing something wrong? Changed the currents in the config
                  M906 X1600 Y1600 Z1600 E700 I50	                    	; set motor currents (mA) and motor idle factor in per cent
                  I'm a little bit irritated now 😞
                    MartinNYHC
                    Here's a video without Z axis thread
                    https://youtu.be/FYeSaApQHEA
                    and with Z axis thread
                    https://youtu.be/VqZP_wAFFvw
                      Yeah that's not right. Are those the new motors you replaced or the old ones?
                      Do they sound the same detached from the frame?
                      Are the motor phases matched?
                      https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases
                        MartinNYHC
                        That's the new ones! 😞 Yes, they are also quite noisy when detached. Already checked the phases. Also played around with the settings but without success. I have no idea what to do next.
                        My current settings are
                        M569 P0 S1                                          	; physical drive 0 goes backwards
                        M569 P1 S1                                          	; physical drive 1 goes backwards
                        M569 P2 S1                                          	; physical drive 2 goes forwards
                        M569 P3 S0                                          	; physical drive 3 goes backwards
                        M584 X0 Y1 Z2 E3 	                                 	; set drive mapping
                        M350 X16 Y16 Z16 E16 I1		                          	; configure microstepping with interpolation
                        M92 X80 Y80 Z400 E415.00			 	           		; set steps per mm
                        M566 P1 X1200.00 Y1200.00 Z12.00 E2000.00		      	; set maximum instantaneous speed changes (mm/min)
                        M203 X9000.00 Y9000.00 Z800.00 E5000.00			      	; set maximum speeds (mm/min)
                        M201 X500.00 Y500.00 Z20.00 E5000.00	        		; set accelerations (mm/s^2)
                        M906 X1600 Y1600 Z600 E700 I50	                    	; set motor currents (mA) and motor idle factor in per cent
                        M593 F31
                        ;M572 D0 S0.05		                                  	; set pressure advance
                        M84 S30                                             	; Set idle timeout
                          I would say something is wrong with the motor.
                          Test the Z motor on another driver just to be sure.
                          How fast are you trying to move the motor?
                            MartinNYHC
                            Both Z steppers have the same issue.
                            G91              ; relative positioning
                            G1 Z5 F3000	H1	 ; lift Z relative to current position
                            G90              ; absolute positioning
                            G1 X150 Y150 F6000 ; go to first probe point
                            G30              ; home Z by probing the bed
                              Does the model label on the motor match what you ordered?
                                MartinNYHC
                                Good hint. Yes, they match.
                                  And what is the model? Maybe we can check the specs again.
                                  Did you try the motor on a different driver to eliminate the Z driver? You're using both motors on the Z driver, correct?
                                    MartinNYHC
                                    https://www.omc-stepperonline.com/nema-17-bipolar-0-9deg-46ncm-65-1oz-in-2a-2-8v-42x42x48mm-4-wires-full-d-cut-shaft.html?search=17HM19-2004S1
                                    Nope, didn't try a different driver. Just connected a Creality 42-34 and it works.
                                      You miss my point. I'm wondering how the motors will sound when wired to a seperate driver rather than the Z driver which is wired in series internally.
                                        MartinNYHC
                                        Ahhh...ok, sorry 😉 Will try it now.
                                          Well those motors are identical to those I use in my corexy and they do not sound like that at all. Something is amiss.
                                            MartinNYHC
                                            Same behaviour on X/Y drivers.
