    CR-10S Pro stepper recommendation
    862
      The Z axis doesn't get a lot of action so the specs don't need to be at the same level as x and y.
      • MartinNYHCundefined
        MartinNYHC
        That's true.
        Based on the availability in Germany I've choosen:
        2 x 17HM19-2004S1 for X/Y
        2 x 17HS13-0404S1 for Z
        1 x 17HS08-1004S for E
        Do you think that works satisfactorily?
          Yes those look ok provided the Z motor will fit. The E motor will be ok when using a geared extruder, but those tiny pancakes have limitations on torque that you will need to be aware of. I use those X Y motors on my corexy and have been happy with them.
            MartinNYHC
            I'm using a Bondtech BMG-M with Mosquito. I think that will work.
            Thanks for your help!
              MartinNYHC
              Good news is, that the steppers are attached to the printer. Bad news is, my printer is louder than before 😵
              Joking aside. Now i seem to have a Z axis problem. It makes a terrible very very loud noise when moving. Just found out, that the steppers are making noises when moving and the noise is transfered to the Z axis thread and will be boosted.
              Am I doing something wrong? Changed the currents in the config
              M906 X1600 Y1600 Z1600 E700 I50	                    	; set motor currents (mA) and motor idle factor in per cent
              I'm a little bit irritated now 😞
                MartinNYHC
                Here's a video without Z axis thread
                https://youtu.be/FYeSaApQHEA
                and with Z axis thread
                https://youtu.be/VqZP_wAFFvw
                  Yeah that's not right. Are those the new motors you replaced or the old ones?
                  Do they sound the same detached from the frame?
                  Are the motor phases matched?
                  https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases
                    MartinNYHC
                    That's the new ones! 😞 Yes, they are also quite noisy when detached. Already checked the phases. Also played around with the settings but without success. I have no idea what to do next.
                    My current settings are
                    M569 P0 S1                                          	; physical drive 0 goes backwards
                    M569 P1 S1                                          	; physical drive 1 goes backwards
                    M569 P2 S1                                          	; physical drive 2 goes forwards
                    M569 P3 S0                                          	; physical drive 3 goes backwards
                    M584 X0 Y1 Z2 E3 	                                 	; set drive mapping
                    M350 X16 Y16 Z16 E16 I1		                          	; configure microstepping with interpolation
                    M92 X80 Y80 Z400 E415.00			 	           		; set steps per mm
                    M566 P1 X1200.00 Y1200.00 Z12.00 E2000.00		      	; set maximum instantaneous speed changes (mm/min)
                    M203 X9000.00 Y9000.00 Z800.00 E5000.00			      	; set maximum speeds (mm/min)
                    M201 X500.00 Y500.00 Z20.00 E5000.00	        		; set accelerations (mm/s^2)
                    M906 X1600 Y1600 Z600 E700 I50	                    	; set motor currents (mA) and motor idle factor in per cent
                    M593 F31
                    ;M572 D0 S0.05		                                  	; set pressure advance
                    M84 S30                                             	; Set idle timeout
                      I would say something is wrong with the motor.
                      Test the Z motor on another driver just to be sure.
                      How fast are you trying to move the motor?
                        MartinNYHC
                        Both Z steppers have the same issue.
                        G91              ; relative positioning
                        G1 Z5 F3000	H1	 ; lift Z relative to current position
                        G90              ; absolute positioning
                        G1 X150 Y150 F6000 ; go to first probe point
                        G30              ; home Z by probing the bed
                          Does the model label on the motor match what you ordered?
                            MartinNYHC
                            Good hint. Yes, they match.
                              And what is the model? Maybe we can check the specs again.
                              Did you try the motor on a different driver to eliminate the Z driver? You're using both motors on the Z driver, correct?
                                MartinNYHC
                                https://www.omc-stepperonline.com/nema-17-bipolar-0-9deg-46ncm-65-1oz-in-2a-2-8v-42x42x48mm-4-wires-full-d-cut-shaft.html?search=17HM19-2004S1
                                Nope, didn't try a different driver. Just connected a Creality 42-34 and it works.
                                  You miss my point. I'm wondering how the motors will sound when wired to a seperate driver rather than the Z driver which is wired in series internally.
                                    MartinNYHC
                                    Ahhh...ok, sorry 😉 Will try it now.
                                      Well those motors are identical to those I use in my corexy and they do not sound like that at all. Something is amiss.
                                        MartinNYHC
                                        Same behaviour on X/Y drivers.
                                          Thanks for testing.
                                          At this point I'm not sure what to make of those motors. They sound awful to be sure. I would return them and get something else. Perhaps they aren't as advertised?
                                          17HM19-2004S1 is what you listed above for the X and Y axis. For Z you had listed 17HS13-0404S1, which are you using for Z?
                                            MartinNYHC
                                            For Z it's
                                            https://www.omc-stepperonline.com/nema-17-bipolar-1-8deg-26ncm-36-8oz-in-0-4a-12v-42x42x34mm-4-wires.html?search= 17HS13-0404S1
