BLTouch does not deploy for a print
Here is the whole config.g that you requested in case there is something in here. I had everything working with an IR sensor before I switched to the BLTouch, so perhaps I missed something when I changed the Z probe type.
Duet 3 Send code... Status Idle Mode: FFF Tool Position X 0.0 Y 0.0 Z 458.10 Extruder Drives Drive 0 0.0 Drive 1 0.0 Speeds Requested Speed 0 mm/s Top Speed 0 mm/s Sensors Vin 24.9 V MCU Temperature 40.0 C Z-Probe 0 Tools Extra Control All Tool Heater Current Active Standby Primary T0 - PLA Heater 1 active 24.8 C 0 0 Secondary T1 - Load Filament Heater 2 off 24.8 C 0 0 Bed Heater 0 off 25.6 C 0 0 Chamber Heater 3 off 26.9 C 0 0 Temperature Chart System Directory 0:/sys/config.g ; Configuration file for Duet 3 (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Apr 24 2020 14:40:15 GMT-0600 (Central Standard Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Duet 3" ; set printer name M667 S1 ; select CoreXY mode ; Drives M569 P0.0 S1 ; physical drive 0.0 goes backwards M569 P0.1 S0 ; physical drive 0.1 goes backwards M569 P0.2 S0 ; physical drive 0.2 goes backwards M569 P0.4 S0 ; physical drive 0.4 goes backwards M569 P0.5 S0 ; physical drive 0.5 goes forwards M584 X0.2 Y0.1 Z0.4 E0.5:0.0 ; set drive mapping M350 X32 Y32 Z32 E16:16 I1 ; configure microstepping with interpolation M92 X200.00 Y200.00 Z1600.00 E837:837 ; set steps per mm M566 X800.00 Y800.00 Z100.00 E240.00:240.00 ; set maximum instantaneous speed changes (mm/min) M203 X15000.00 Y15000.00 Z1200.00 E2400.00:2400.00 ; set maximum speeds (mm/min) M201 X800.00 Y800.00 Z40.00 E300.00:300.00 ; set accelerations (mm/s^2) M906 X1800 Y1800 Z1200 E1000:1000 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X-186.5 Y-175 Z-2.8 S1 ; set axis minima M208 X186.5 Y175 Z583.1 S0 ; set axis maxima ; Endstops M574 X1 S1 P"io0.in" ; configure active-high endstop for low end on X via pin io0.in use a NC switch M574 Y1 S1 P"io1.in" ; configure active-high endstop for low end on Y via pin io1.in use a NC switch M574 Z2 S1 P"io2.in" ; configure active-high endstop for high end on Z via pin io2.in use a NC switch ; Z-Probe M950 S0 C"io4.out" ; Set pin4 out as servo out 0 M558 P9 C"^io4.in" H3 F200 T12000 ; set Z probe type to BL touch and the dive height + speeds G31 P500 X55 Y48 Z2.776 ; set Z probe trigger value, offset and trigger height M557 X-115:185 Y-120:120 S60 ; define mesh grid M280 P0 S160 I1 ; Reset Probe just in case M402 ; Retract probe just in case ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M143 H0 S165 ; set temperature limit for heater 0 to 165C M307 H0 B1 S1.00 ; Enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M308 S1 P"temp1" Y"pt1000" R2200 ; configure sensor 1 as PT1000 on pin temp1 M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M143 H1 S340 ; set temperature limit for heater 1 to 340C M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M308 S2 P"temp2" Y"pt1000" R2200 ; configure sensor 2 as PT1000 on pin temp2 M950 H2 C"out2" T2 ; create nozzle heater output on out2 and map it to sensor 2 M143 H2 S340 ; set temperature limit for heater 2 to 340C M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M308 S3 P"temp3" Y"thermistor" T100000 B4138 ; configure sensor 3 as thermistor on pin temp0 M950 H3 C"out3" T3 ; create chamber heater output on out3 and map it to sensor 3 M143 H3 S75 ; set temperature limit for heater 3 to 75C M307 H3 B1 ; disable bang-bang mode for heater and set PWM limit M141 H3 ; map heated chamber to heater 3 ;Heater Tuning parameters M307 H0 A253.1 C685.6 D0.7 V24.9 B0 ; PID model for Heater 0 M307 H1 A529.2 C249.3 D5.7 V24.8 B0 ; PID model for heater 1 M307 H2 A418.3 C213.8 D3.6 V24.8 B0 ; PID model for heater 2 M307 H3 A90 C1500 D600 V24.8 B1 ; BANG-BANG model for heater 3 ;Virtual Heaters M308 S4 P"MCU" Y"mcu-temp" ; create mcu temperature M308 S5 P"Stepper driver" Y"drivers" ; create driver temperatures ; Fans M950 F0 C"out7" Q500 ; create fan 0 on pin out4 and set its frequency used for Radiator cooler fan M106 P0 T85 S1 H1:2 ; set fan 0 value. Thermostatic control is turned on M950 F1 C"out8" Q500 ; create fan 1 on pin out5 and set its frequency used for Water circ pump M106 P1 T45 S1 H1:2 ; set fan 1 value. Thermostatic control is turned on M950 F2 C"out4" Q500 ; create fan 2 on pin out7 and set its frequency used for Part cooling fan M106 P2 S0.0 ; set fan 2 value. Thermostatic control is turned off M950 F3 C"out5" Q500 ; create fan 3 on pin out8 and set its frequency used for board cooling fan M106 P3 T35:55 H4:5 ; set fan 3 value. Thermostatic control is proportional to the CPU or driver temps M950 F4 C"out6" Q500 ; create fan 4 on pin out 6 and set its frequency used. for bed cooling fan M106 P4 S0.0 ; set fan 4 value. Thermostatic control is turned off. Controlled by Gcode only ; Tools M563 P0 S"Primary" D0 H1 F2 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M563 P1 S"Secondary" D1 H2 F2 ; define tool 1 G10 P1 X25.25 Y0 Z0 ; set tool 1 axis offsets G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C ; Custom settings M572 D0:1 S0.03:0.03 ; Set Pressure advance settings G28 Z ; Home Z G28 X Y ; Home X and Y M280 P0 S120 I1 ; Probe Self test T0 ; Set tool 0 active G1 X0 Y0 F12000 ; Move print head to middle of bed ; Miscellaneous M911 S22.0 R24.0 P"M913 X50 Y50 G91 M83 G1 Z3 E-5 F1000 ; Set the power loss resume parameters
I would recommend removing the homing commands from your config.g. Definitely not best practice to have movement commands executed at startup.
@Phaedrux it is the Smart 3.1 BLTouch, I think that is the newest version.
I will try the update to 3.1.1 for the Duet.
@Phaedrux That is sound advice, I will do that.
@baird1fa if the update doesnt help:
I read in another thread that the heater disturbed the bltouch. One solution was to assemble the bltouch at a different position. The other means was to protect the cables with a shield, which can be bought separately and is around the cable.
It looked similar like the shielded cable on the left here in this link https://www.antclabs.com/wiring
@Phaedrux I have completed the upgrade to the latest version of the firmware. I tested the BL touch and after the update I was still able to deploy and retract the probe, so I started a print and the probe did not deploy. I hit the E-stop and then started the print again and the probe worked fine.
Now that the print has completed, I cannot activate the probe. I'm going to replace the BLTouch with a spare one and see if that has any effect.
@baird1fa said in BLTouch does not deploy for a print:
Good next step. Redo the wiring if possible as well if just changing the probe doesn't help. The intermittency really seems like a wiring fault.
@Phaedrux It really seems like something other than wiring. I can do exactly one print before it the servo signal doesn’t work. It really makes me think it is something that is in my slicer code but I don’t have anything strange there.
I have noticed since my upgrade to firmware 3.1.1 that I have a termination error at line 106 of my config.g macro. Line 106 is the latest line of my config.g
Ok that's something worth looking into.
Send M98 P"config.g" and report the results.
Maybe include your current config.g as well.
@Phaedrux
I’m just in the middle of a print so I will do that once it’s done. Also the config is the same as previously posted.Regards.
@Phaedrux I found that issue, It was my M911 command, I seem to have forgotten to close the quotations (") and so it wasn't understanding that command. So I'm pretty sure that is a completely unrelated issue.
But back to the matter at hand. The BLTouch will not deploy after I start a print job.
; G-Code generated by Simplify3D(R) Version 4.1.2 ; Jun 27, 2020 at 4:19:50 PM ; Settings Summary ; processName,Process1 ; applyToModels,Float switch Jbox cover,Float switch Jbox cover(2) ; profileName,Custom 22 (modified) ; profileVersion,2020-06-23 08:44:31 ; baseProfile,Default ; printMaterial,PC ; printQuality,Medium ; printExtruders,Extruder 2 Only ; extruderName,Extruder 1,Extruder 2 ; extruderToolheadNumber,0,1 ; extruderDiameter,0.8,0.4 ; extruderAutoWidth,1,1 ; extruderWidth,0.96,0.48 ; extrusionMultiplier,1,1.05 ; extruderUseRetract,1,1 ; extruderRetractionDistance,1,2 ; extruderExtraRestartDistance,0,0 ; extruderRetractionZLift,0.4,0.6 ; extruderRetractionSpeed,2400,2400 ; extruderUseCoasting,0,1 ; extruderCoastingDistance,0.2,0.2 ; extruderUseWipe,1,1 ; extruderWipeDistance,1,1 ; primaryExtruder,1 ; layerHeight,0.25 ; topSolidLayers,4 ; bottomSolidLayers,3 ; perimeterOutlines,3 ; printPerimetersInsideOut,1 ; startPointOption,2 ; startPointOriginX,0 ; startPointOriginY,0 ; sequentialIslands,0 ; spiralVaseMode,0 ; firstLayerHeightPercentage,120 ; firstLayerWidthPercentage,100 ; firstLayerUnderspeed,0.65 ; useRaft,0 ; raftExtruder,1 ; raftTopLayers,3 ; raftBaseLayers,2 ; raftOffset,3 ; raftSeparationDistance,0.14 ; raftTopInfill,100 ; aboveRaftSpeedMultiplier,0.3 ; useSkirt,1 ; skirtExtruder,1 ; skirtLayers,1 ; skirtOutlines,1 ; skirtOffset,2 ; usePrimePillar,0 ; primePillarExtruder,999 ; primePillarWidth,12 ; primePillarLocation,7 ; primePillarSpeedMultiplier,1 ; useOozeShield,0 ; oozeShieldExtruder,999 ; oozeShieldOffset,2 ; oozeShieldOutlines,1 ; oozeShieldSidewallShape,1 ; oozeShieldSidewallAngle,30 ; oozeShieldSpeedMultiplier,1 ; infillExtruder,1 ; internalInfillPattern,Fast Honeycomb ; externalInfillPattern,Rectilinear ; infillPercentage,30 ; outlineOverlapPercentage,40 ; infillExtrusionWidthPercentage,100 ; minInfillLength,5 ; infillLayerInterval,1 ; internalInfillAngles,0 ; overlapInternalInfillAngles,0 ; externalInfillAngles,45,-45,0,90 ; generateSupport,0 ; supportExtruder,1 ; supportInfillPercentage,45 ; supportExtraInflation,2 ; supportBaseLayers,2 ; denseSupportExtruder,1 ; denseSupportLayers,3 ; denseSupportInfillPercentage,70 ; supportLayerInterval,1 ; supportHorizontalPartOffset,0.8 ; supportUpperSeparationLayers,1 ; supportLowerSeparationLayers,1 ; supportType,0 ; supportGridSpacing,4 ; maxOverhangAngle,45 ; supportAngles,0 ; temperatureName,Extruder 1,Extruder 2,Heated Bed,Chamber circ fan,Chamber heater,Standby temp ; temperatureNumber,0,1,0,3,2,4 ; temperatureSetpointCount,1,1,1,1,1,1 ; temperatureSetpointLayers,1,1,1,1,1,1 ; temperatureSetpointTemperatures,0,300,120,200,60,0 ; temperatureStabilizeAtStartup,0,1,1,1,1,1 ; temperatureHeatedBed,0,0,1,0,0,0 ; fanLayers,1,5,10,30,40 ; fanSpeeds,0,10,15,20,25 ; blipFanToFullPower,0 ; adjustSpeedForCooling,1 ; minSpeedLayerTime,15 ; minCoolingSpeedSlowdown,50 ; increaseFanForCooling,0 ; minFanLayerTime,45 ; maxCoolingFanSpeed,100 ; increaseFanForBridging,1 ; bridgingFanSpeed,40 ; use5D,1 ; relativeEdistances,0 ; allowEaxisZeroing,1 ; independentExtruderAxes,0 ; includeM10123,0 ; stickySupport,1 ; applyToolheadOffsets,0 ; gcodeXoffset,0 ; gcodeYoffset,0 ; gcodeZoffset,0 ; overrideMachineDefinition,1 ; machineTypeOverride,0 ; strokeXoverride,355 ; strokeYoverride,334 ; strokeZoverride,578 ; originOffsetXoverride,177.5 ; originOffsetYoverride,175 ; originOffsetZoverride,0 ; homeXdirOverride,-1 ; homeYdirOverride,-1 ; homeZdirOverride,1 ; flipXoverride,1 ; flipYoverride,-1 ; flipZoverride,1 ; toolheadOffsets,0,0|0,0|0,0|0,0|0,0|0,0 ; overrideFirmwareConfiguration,1 ; firmwareTypeOverride,RepRap (Marlin/Repetier/Sprinter) ; GPXconfigOverride,r2 ; baudRateOverride,250000 ; overridePrinterModels,0 ; printerModelsOverride ; startingGcode,M106 P4 S100 ;Turn on chamber circ fan,,M104 S[extruder0_temperature] T0 ; Set nozzle 1 to temp,M104 S[extruder1_temperature] T1 ; Set nozzle 2 to temp,M140 S[bed0_temperature] ; Set bed to temp,M141 S[extruder2_temperature] ; Chamber heaters,,G28 ; Home all,M401,G0 Z10 F700 ; Bring up Z,M402,G1 X-55 Y-48 F12000,,G30 ;Probe bed single point and set offset of Z,M400,G29 ;Bed mesh probe,G1 Z25 F400 ;Lower bed while heating ,G1 X-185 Y-175 F12000 ;move head out of the way while heating,M400,,M109 T0 S[extruder0_temperature] ; Hold until nozzle 1 at temp,M109 T1 S[extruder1_temperature] ; Hold until nozzle 2 at temp,M190 S[bed0_temperature] ; Hold until bed at temp,,T0 ; First nozzle,G21 ; Metric values,G90 ; Absolute positioning,G92 E0 ; Set extruder to 0,,T1 ; First nozzle,G21 ; Metric values,G90 ; Absolute positioning,G92 E0 ; Set extruder to 0,,M106 P4 S[extruder3_temperature] ; Turn set chamber fan speed (speed depends on Filament),,G0 Z0.5 F900 ; Raise nozzle to .5mm over bed,,;M201 X600 Y600 Z100 E10000 ; Set acceleration,;M207 X5 ; Set Jerk,M400, ; layerChangeGcode, ; retractionGcode, ; toolChangeGcode, ; endingGcode,G28 Z,G28 X Y,M106 S0 ; Turn off cooling fan,M98 P"0/macros/Slow_cool.g" ;Slowly cools the bed and build chamber *comment for non PC or ABS parts,M104 S0 ; turn off extruder,M140 S0 ; turn off bed,M141 S0 ; Turn off chamber heater, ; exportFileFormat,gcode ; celebration,0 ; celebrationSong,Random Song ; postProcessing, ; defaultSpeed,2700 ; outlineUnderspeed,0.7 ; solidInfillUnderspeed,0.9 ; supportUnderspeed,0.9 ; rapidXYspeed,12000 ; rapidZspeed,1200 ; minBridgingArea,5 ; bridgingExtraInflation,1 ; bridgingExtrusionMultiplier,1.1 ; bridgingSpeedMultiplier,0.75 ; useFixedBridgingAngle,0 ; fixedBridgingAngle,0 ; applyBridgingToPerimeters,1 ; filamentDiameters,2.88|2.88|1.75|1.75|1.75|1.75 ; filamentPricesPerKg,46|46|46|46|46|46 ; filamentDensities,1.04|1.25|1.25|1.25|1.25|1.25 ; useMinPrintHeight,0 ; minPrintHeight,0 ; useMaxPrintHeight,0 ; maxPrintHeight,60.1 ; useDiaphragm,0 ; diaphragmLayerInterval,20 ; robustSlicing,1 ; mergeAllIntoSolid,0 ; onlyRetractWhenCrossingOutline,0 ; retractBetweenLayers,1 ; useRetractionMinTravel,1 ; retractionMinTravel,3 ; retractWhileWiping,1 ; onlyWipeOutlines,0 ; avoidCrossingOutline,0 ; maxMovementDetourFactor,5 ; toolChangeRetractionDistance,12 ; toolChangeExtraRestartDistance,-0.5 ; toolChangeRetractionSpeed,600 ; externalThinWallType,1 ; internalThinWallType,1 ; thinWallAllowedOverlapPercentage,25 ; singleExtrusionMinLength,3 ; singleExtrusionMinPrintingWidthPercentage,50 ; singleExtrusionMaxPrintingWidthPercentage,200 ; singleExtrusionEndpointExtension,0.2 ; horizontalSizeCompensation,0 G90 M82 M106 S0 M106 P4 S100 ;Turn on chamber circ fan M104 S0 T0 ; Set nozzle 1 to temp M104 S300 T1 ; Set nozzle 2 to temp M140 S120 ; Set bed to temp M141 S60 ; Chamber heaters G28 ; Home all M401 G0 Z10 F700 ; Bring up Z M402 G1 X-55 Y-48 F12000 G30 ;Probe bed single point and set offset of Z M400 G29 ;Bed mesh probe G1 Z25 F400 ;Lower bed while heating G1 X-185 Y-175 F12000 ;move head out of the way while heating M400 M109 T0 S0 ; Hold until nozzle 1 at temp M109 T1 S300 ; Hold until nozzle 2 at temp M190 S120 ; Hold until bed at temp T0 ; First nozzle G21 ; Metric values G90 ; Absolute positioning G92 E0 ; Set extruder to 0 T1 ; First nozzle G21 ; Metric values G90 ; Absolute positioning G92 E0 ; Set extruder to 0 M106 P4 S200 ; Turn set chamber fan speed (speed depends on Filament) G0 Z0.5 F900 ; Raise nozzle to .5mm over bed ;M201 X600 Y600 Z100 E10000 ; Set acceleration ;M207 X5 ; Set Jerk M400 ; process Process1 ; layer 1, Z = 0.300 T1 G92 E0.0000 G1 E-2.0000 F2400 ; feature skirt ; tool H0.300 W0.480 Just regular Gcode for the tool paths here that I removed ; layer end G28 Z G28 X Y M106 S0 ; Turn off cooling fan M98 P"0/macros/Slow_cool.g" ;Slowly cools the bed and build chamber *comment for non PC or ABS parts M104 S0 ; turn off extruder M140 S0 ; turn off bed M141 S0 ; Turn off chamber heater ; Build Summary ; Build time: 0 hours 41 minutes ; Filament length: 1726.4 mm (1.73 m) ; Plastic volume: 11246.52 mm^3 (11.25 cc) ; Plastic weight: 14.06 g (0.03 lb) ; Material cost: 0.65
Here is a sample file that I just printed.
I still haven't seen your homeall.
I don't know what's in your homeall, but it should be homing Z with the probe already, so you should remove everything after G28.
I'm not sure what that's trying to accomplish.
@Phaedrux no my home Z does not use the probe, nor does my home all. As you can see in my config.g I'm using a limit switch as the maximum Z for the home Z. The probe is only used for the bed mesh.
that is why I haven't posted it sooner is it has nothing to do with the probe.; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Apr 24 2020 14:40:15 GMT-0600 (Central Standard Time) G91 ; relative positioning ;G1 H2 Z-10 F750 ; lift Z relative to current position G1 H1 Z585 F1000 ; move Z up until the endstop is triggered G1 H2 Z-5 F600 ; back off of limit for second pass G1 H1 Z8 F500 ; Second pass at limit switch G92 Z583.1 ; set Z position to axis maximum (you may want to adjust this) ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z10 F100 ; lift Z relative to current position ;G90 ; absolute positioning
and home all
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Apr 24 2020 14:40:15 GMT-0600 (Central Standard Time) G91 ; relative positioning G1 H1 Z2 F6000 ; lift Z relative to current position G1 H1 X-361 Y-355 F1800 ; move quickly to X or Y endstop and stop there (first pass) G1 H1 X-361 ; home X axis G1 H1 Y-355 ; home Y axis G1 X5 Y5 F6000 ; go back a few mm G1 H1 X-361 F360 ; move slowly to X axis endstop once more (second pass) G1 H1 Y-355 ; then move slowly to Y axis endstop G1 H1 Z585 F750 ; move Z up stopping at the endstop G90 ; absolute positioning G92 Z583.1 ; set Z position to axis maximum (you may want to adjust this) ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z10 F100 ; lift Z relative to current position ;G90 ; absolute positioning
The issue is 100% repeatable so it is not the wiring. If I use the probe a few times or use the macro, before I print a file, the probe will not deploy. If I print a file, after the file is complete the probe will not deploy. And when I say deploy, I mean it won't respond to commands at all. After I reset the board either by hitting the emergency stop button or via power cycle, the BLTouch will respond. It is a very strange issue.
Agreed. Are the BLtouch wires running next to anything else?
Can you connect the BLTouch directly to the board with it's short leads and see how it behaves then?
@baird1fa do you use the chamber heater, as there are settings for one in the config? BLTouch is sensible against heat if I remember well from another thread. I can't remember the exact temperature.
BLTouch uses Hall effect, so it will have a magnet also. Neodym magnets loose magnetism at 80°, so you must take care that you don't destroy it (I don't know whether they use neodym, there are ferrite magnets with resistence up to 200 °C)
M141 S60 is at the start of your g-code, maybe this already weakens the magnet enough so that BLTouch doesn't work as expected.
This highly technical paper https://www.kjmagnetics.com/blog.asp?p=temperature-and-neodymium-magnets tells that 60°C is still ok, but I think together with the bed heat of 120°C from below going up the total temperature for the BLTouch could be higher than 60°C. And the magnet gets weaker after some overheats. I just read that thin magnet's limit is 60°C. So it depends on the shape and type of the magnet with is built into the BLTouch, both unknown to me.
@JoergS5 yes I do have a heated chamber. It only operates up to 70 (65 really). That is something I’ve been concerned about weather the temperature would affect the sensor. I have had the same issue weather I use the heat or not. I don’t use the sensor when the changer is hot.
I think they use a ferrite core (the small setscrew on the top of the BLTouch is the core) so it should be good for reasonably high temps.
It is worth mentioning that I noticed this strange behavior of the BLTouch before I ever turned on the chamber heat.
Yes all of my wiring for the print head run in a bundle between the board and the print head. It’s about 1m-2m if cabling.
I could plug BLTouch into the board but I wouldn’t be able to have it mounted where it could touch the bed. It would work purely to see if there is interference.
The only issue with that thought is that it does work when I first start a print and all the PWMs are pulsing and causing the most EMF and potential for signal noise. But after a print, it no longer works and everything is off (all the fans and heaters set to 0).
It’s not an ideal solution but I suppose a workaround would be to reset the board after each print. I think there is a GCode for that.
Edit: I just looked up the Gcode for a firmware reset and Yes the M999 does reset the board, and then also allows the BLTouch to start working again. I just simulated the end of my gcode script by creating a macro that turns on all the fans, then turns off the fans and the heaters and then tries to deploy the probe. That seems to work fine.
I have noticed that if the print finishes or even if I cancel a print I need to reboot the board. I wonder if there is something in how the firmware handles the "cancel" or the "end of print" code that is causing me this issue. Is that something that I can actually investigate or is that locked away in the firmware?
This is just deploying the probe well before the bed gets to the print head so I know if it will deploy or not. The G0 Z10 is just a rapid move to bring up the bed because it’s a 22.75” or travel between home and the probe. Then the probe gets retracted, again just so I can see if it is going to work so I have time to hit the E-Stop.
If I can get this issue resolved the M401 and M402 will be removed. I’ll leave the Z10 in there.
@baird1fa One thing I found:
M950 S0 C"io4.out"
M280 P0 S160 I1In https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch is mentioned: "On Duet 3 it is one of io4.out, io5.out or io7.out. If you use one of these pin names, you will not need to invert the output."
So you don't need the I1.
I think you will not need the ^ also. -
@JoergS5 I read that too, but the commands don’t work with out the I1. Also the ^ is for the pull-up resistor on the input isn’t it?
