    BL-Touch - multiple problems -
    Firmware installation
    2.4k
    • duttiundefined
      dutti
      M558 P9 C"^io7.in" H15 F120 T1400 ;set Z probe type to bltouch and the dive height + speeds
      M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
      G31 P500 X20 Y100 Z4 ; set Z probe trigger value, offset and trigger height
      M557 X15:650 Y15:650 S60 ; define mesh grid
      • JoergS5undefined
        JoergS5 @dutti
        @barbarossa-cologne from documentation, setting lower P for G31 seems better:
        G31 P25 X20 Y100 Z4
        and
        M558 P9 C"io7.in" H15 F120 T1400
        without the ^, because Duet 3 IO ports all have pullups already.
        https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Duet_3_endstop_inputs each IO of Duet 3 has already pullup resistors: "Endstop devices can be connected to the IO_0 through IO_9 connectors. Each endstop input has a 27K pullup resistor, so the endstop devices only need to sink 0.12mA."
        You wrote above, that removing ^ didn't work, but how did you mention, maybe it was the wrong P of G31 or some other cause.
        • duttiundefined
          dutti
          @JoergS5
          ITS WORKING!!!!!!
          I connected the BL to IO4.
          I think the IO7 connector isn´t working.
          Refund Duet??? 🙂
          I´m not sure about the ´´^ ´´. Let it like this and its working now.
          • JoergS5undefined
            JoergS5 @dutti
            @barbarossa-cologne I am glad to hear that!!
            duttiundefined 1 Reply Last reply Reply Quote 0
            • duttiundefined
              dutti @JoergS5
              @JoergS5
              And NO. I´m a Idiot. the ´´^ `` must be deleted. Thanks Jörg and @Phaedrux
                dc42 administrators @dutti
                @barbarossa-cologne said in BL-Touch - multiple problems -:
                @Phaedrux said in BL-Touch - multiple problems -:
                M98 Pconfig.g
                ´´´Response to long, see console´´.
                So switch to the Console page of DWC to see the messages.
                I havent connected the expansion board, yet. Is this a problem?
                You will get some error messages from running config.g if it refers to ports on an expansion board that isn't connected.
                  Phaedrux Moderator @dutti
                  @JoergS5
                  So you're able to use io7 when removing the ^?
                  • duttiundefined
                    dutti @dc42
                    ok. problem solved.
                    thanks
                    • duttiundefined
                      dutti @Phaedrux
                      @Phaedrux
                      no IO7 is dead. with or without. no retract or deploy
                      • JoergS5undefined
                        JoergS5 @dutti
                        @Phaedrux
                        I would make an image from the soldered side of io7 and publish so it can be valued whether it may be a soldering problem.
                        duttiundefined 1 Reply Last reply Reply Quote 1
                        • duttiundefined
                          dutti @JoergS5
                          @JoergS5
                          ok. I´ll do it!
                            In addition to the photos can you also provide the following:
                            The output of M122
                            The output of M98 P"config.g"
                            Your current config.g
                            Also please do this test and report the results:
                            Send M950 J5 C"io7.in", then read the state of the pin by sending: echo sensors.gpIn[5]
                            Do this both with and without a jumper shorting io7.in to ground.
                            Result should be 0 with the jumper, 1 without
