    BL-Touch - multiple problems -
    Firmware installation
    2.4k
    • duttiundefined
      dutti @Phaedrux
      @Phaedrux
      Ok. I'll do it on Sunday!
      I have a cheap Chinese BL fake at home. Should I take this BL at last try?
      Is there any other sensor you can recommend if it's not working?
      The duet one?
        The BLtouch is a good probe when it's working. It's surface agnostic and a contact probe and it's quite accurate and repeatable when configured correctly. It's the most popular option for a reason.
        The IR Probe is also very good, but your print surface must be compatible with the IR sensor.
        • duttiundefined
          dutti
          @Phaedrux
          ok. Then I´ll do everything to become the BL to work.
          • duttiundefined
            dutti
            @JoergS5
            Changing the cable order wasn´t helpful.
            There is also the problem that the duet homes the z axis. Also when the BL isn´t connected.
            @Phaedrux
            • duttiundefined
              dutti
              M558 P9 C"^io7.in" H15 F120 T1400 ;set Z probe type to bltouch and the dive height + speeds
              M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
              G31 P500 X20 Y100 Z4 ; set Z probe trigger value, offset and trigger height
              M557 X15:650 Y15:650 S60 ; define mesh grid
              • JoergS5undefined
                JoergS5 @dutti
                @barbarossa-cologne from documentation, setting lower P for G31 seems better:
                G31 P25 X20 Y100 Z4
                and
                M558 P9 C"io7.in" H15 F120 T1400
                without the ^, because Duet 3 IO ports all have pullups already.
                https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Duet_3_endstop_inputs each IO of Duet 3 has already pullup resistors: "Endstop devices can be connected to the IO_0 through IO_9 connectors. Each endstop input has a 27K pullup resistor, so the endstop devices only need to sink 0.12mA."
                You wrote above, that removing ^ didn't work, but how did you mention, maybe it was the wrong P of G31 or some other cause.
                • duttiundefined
                  dutti
                  @JoergS5
                  ITS WORKING!!!!!!
                  I connected the BL to IO4.
                  I think the IO7 connector isn´t working.
                  Refund Duet??? 🙂
                  I´m not sure about the ´´^ ´´. Let it like this and its working now.
                  • JoergS5undefined
                    JoergS5 @dutti
                    @barbarossa-cologne I am glad to hear that!!
                    duttiundefined 1 Reply Last reply Reply Quote 0
                    • duttiundefined
                      dutti @JoergS5
                      @JoergS5
                      And NO. I´m a Idiot. the ´´^ `` must be deleted. Thanks Jörg and @Phaedrux
                        dc42 administrators @dutti
                        @barbarossa-cologne said in BL-Touch - multiple problems -:
                        @Phaedrux said in BL-Touch - multiple problems -:
                        M98 Pconfig.g
                        ´´´Response to long, see console´´.
                        So switch to the Console page of DWC to see the messages.
                        I havent connected the expansion board, yet. Is this a problem?
                        You will get some error messages from running config.g if it refers to ports on an expansion board that isn't connected.
                          Phaedrux Moderator @dutti
                          @JoergS5
                          So you're able to use io7 when removing the ^?
                          • duttiundefined
                            dutti @dc42
                            ok. problem solved.
                            thanks
                            • duttiundefined
                              dutti @Phaedrux
                              @Phaedrux
                              no IO7 is dead. with or without. no retract or deploy
                              • JoergS5undefined
                                JoergS5 @dutti
                                @Phaedrux
                                I would make an image from the soldered side of io7 and publish so it can be valued whether it may be a soldering problem.
                                duttiundefined 1 Reply Last reply Reply Quote 1
                                • duttiundefined
                                  dutti @JoergS5
                                  @JoergS5
                                  ok. I´ll do it!
                                    In addition to the photos can you also provide the following:
                                    The output of M122
                                    The output of M98 P"config.g"
                                    Your current config.g
                                    Also please do this test and report the results:
                                    Send M950 J5 C"io7.in", then read the state of the pin by sending: echo sensors.gpIn[5]
                                    Do this both with and without a jumper shorting io7.in to ground.
                                    Result should be 0 with the jumper, 1 without
