    Duet 3 RRF3 BLtouch
    Firmware installation
    941
    • mrenz999undefined
      mrenz999 @Phaedrux
      @Phaedrux I do and will do that.. Be right back
      mrenz999undefined 1 Reply Last reply Reply Quote 0
      • mrenz999undefined
        mrenz999 @mrenz999
        @mrenz999 Wires all check out correctly. Did a full power off leave for a few mins and power back on. Does the full test. Had another BLTouch and swapped it out to make sure it wasn't a faulty unit. All the same behavior and still not working.
        • mrenz999undefined
          mrenz999 @Phaedrux
          @Phaedrux Something new now. Tried to home z and it says zprobe already triggered at start of moving probe.
          • baird1faundefined
            baird1fa @mrenz999
            @mrenz999 yes it needs the ^ that turns on the pull up resistor.
            Do you have your deploy.g and retract.g files setup?
            In deploy.g you need M280 P0 S10
            And retract.g needs M280 P0 S90
            That might be why it won’t deploy. Once they are setup M401 should deploy and M402 should retract.
            • mrenz999undefined
              mrenz999 @baird1fa
              @baird1fa
              ; deployprobe.g
              ; called to deploy a physical Z probe
              ; generated by RepRapFirmware Configuration Tool v3.1.1 on Thu Jun 04 2020 11:20:25 GMT-0700 (Pacific Daylight Time)
              ;M280 P0 S10 ; deploy BLTouch
              M280 P0 S10 ;deploy BLTouch
              ; retractprobe.g
              ; called to retract a physical Z probe
              ; M280 P0 S90 ; retract BLTouch
              • baird1faundefined
                baird1fa
                Mine had an issue with the steppers being active. I had to send an M18 to disable the extruder steppers. They were causing interference when active.
                • mrenz999undefined
                  mrenz999 @baird1fa
                  @baird1fa Duet 3 ? Or bltouch?
                  baird1faundefined 1 Reply Last reply Reply Quote 0
                  • baird1faundefined
                    baird1fa @mrenz999
                    @mrenz999 both. I’ve got a BLTouch and a duet 3. Sorry the interference I think was between the duet 3 and the BLTouch.
                      I don't suppose you have an oscilloscope?
                      mrenz999undefined 2 Replies Last reply Reply Quote 0
                      • mrenz999undefined
                        mrenz999 @Phaedrux
                        @Phaedrux Sorry. I do not
                        • mrenz999undefined
                          mrenz999 @Phaedrux
                          @Phaedrux
                          The z probe is showing triggered on the machine tab, and it's value is 1000 on the dashboard.
                          Does it matter that I am using io3 ? Should I change it to 7 ?
                          • baird1faundefined
                            baird1fa @mrenz999
                            @mrenz999
                            It might matter. The documentation says to use io4,5or7. I’m using io4 and it works.
                            • mrenz999undefined
                              mrenz999 @baird1fa
                              @baird1fa That's what I was thinking. Going to just swap it to 7 and see what happens. Will update either way.
                              • mrenz999undefined
                                mrenz999 @baird1fa
                                @baird1fa Ok changing it to 7 had this effect. Homed x and y fine. No change. Moved to center of bed and before it headed towards the bed it probed the retracted the probe and stopped moving with an error that the z probe was already triggered. So it triggered at the beginning of the start of the bed movement. Bed is still far away from the probe.
                                • mrenz999undefined
                                  mrenz999
                                  I rechecked all wires. Unplugged and replugged it in. Hard cycled the power and now it seems to be working. Thank you everyone for your assitance 🙂
                                  • baird1faundefined
                                    baird1fa
                                    I’m glad we were able to help and you are up and running.
                                    • baird1faundefined
                                      baird1fa
                                      it bet that internally that pin4,5,and7 are the only ones able to do a servo signal.
                                      it would be helpful if there was some error handling built into the firmware that would throw an error when you try to configure an incorrect pin to do servo commands.
                                        A Former User @baird1fa
                                        @baird1fa said in Duet 3 RRF3 BLtouch:
                                        https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Hardware_Overview#Section_IO
                                        I only checked that io3.in was able to analoge in, my bad!
