    Need help to config file for ender 3 pro
    1.7k
    • Roei3dundefined
      Roei3d @JoergS5
      @JoergS5 x6000 or x600.00 if ido x6000 its move very fast
      • JoergS5undefined
        JoergS5 @Roei3d
        @Roei3d M203 is in mm/min, so 30000 mm/min is 500 mm/s, and 6000 would be 100 mm/s. You can try different values and optimize speed setting, but I would start with 6000.
        But my impression from the video is that your fans are the loudest.
        Roei3dundefined 1 Reply Last reply Reply Quote 0
          It was hard to hear more than fan noise in your video, but there was some stepper noise.
          The 2209 has stealthchop, whereas the 2660 in the Duet Wifi does not. So you have switched from potentially quieter drivers to more powerful drivers. A Duet Maestro may have been a better choice if silence was your aim.
          The ender 3 frame bolts the steppers directly to the frame which can amplify the noise through resonance. Adding a rubber or cork gasket between the steppers and the frame can drastically reduce the sound.
          • Roei3dundefined
            Roei3d @JoergS5
            @JoergS5 THANKS I WELL CHECKED IT
            • Roei3dundefined
              Roei3d @Phaedrux
              @Phaedrux OK THANKS WHAT DO YOU THINK ABOUT THIS CONFIG
              M906 X700 Y700 Z700 E800 I30                       ; set motor currents (mA) and motor idle factor in per cent
              MY MOTOR VERY HOT
                I think your CAPSLOCK key is stuck in the on position. Fix that first.
                I think those motor currents are alright for the stock motors of the Ender. I use about the same on my Maestro + Ender 3 Pro.
                Unfortunately again the Creality motors aren't a great pairing for the Duet Wifi.
                • Roei3dundefined
                  Roei3d @Phaedrux
                  @Phaedrux sorry for the caps look 😂
                  Now my printer working Almost perfect.
                  I have a problem with lines.
                  On y axis itray A lot of xyz test cube
                  On the y side have small ringing I checked the entire frame.
                  I pulled the straps, there's no difference.
                  My ender 3 upgrade all axis With linar rail.
                  Is there any chance that these lines are a software problem and not a hardware problem? Thnks for the help
                  ![alt text](image url20200705_080730.jpg )
                    Try reducing your X Y jerk by half
                    M566 X1200.00 Y1200.00
                    • Roei3dundefined
                      Roei3d @Phaedrux
                      @Phaedrux ok i well change it to x600 y600?
                        That would be half yes.
                        • Roei3dundefined
                          Roei3d @Phaedrux
                          @Phaedrux thnks ijust wanted to know that I understood you right. 👍
                          • Roei3dundefined
                            Roei3d @Roei3d
                            @Roei3d ok itray x600 y600 no change tray x400 y400 no change the left cube is xy400 the right xy600, all my print very good quality but the ringing make my crazy what ineed to do now?
                              It's possible to over tighten the belts. Try loosening them a bit.
                              You can try dropping motor current slightly too.
                              • Roei3dundefined
                                Roei3d @Phaedrux
                                @Phaedrux itry to loss the belt no change, how I change motor current
                                ? M906? And to what current I change?
                                This is my updated config after some changes and my last print I uploaded is with this config
                                General preferences
                                M550 P"Ender 3 Pro BLV" ; set printer name
                                M918 P1 E4 F2000000 ; configure direct-connect display
                                M551 P"" ; set password
                                M552 S1 ; enable network
                                M586 P0 S1 ; enable HTTP
                                M586 P1 S0 ; disable FTP
                                M586 P2 S0 ; disable Telnet
                                M569 P0 S0 ; physical drive 0 goes backwards
                                M92 X80 Y80 Z400 E406 ; set steps per mm
                                M566 X400 Y400 Z50 E3000 P1 ; set maximum instantaneous speed changes (mm/min)
                                M203 X12000 Y12000 Z900 E6000 ; set maximum speeds (mm/min)
                                M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
                                M84 S30 ; Set idle timeout
                                M208 X235 Y235 Z240 S0 ; set axis maxima
                                ; Filament runout sensor ;Filament run-out sensor triggers a pause
                                M591 D0 P2 C3 S1
                                M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
                                M558 P9 H2.5 F350 T6000 ; set Z probe type to bltouch and the dive height + speeds
                                G31 P500 X-40 Y-12 Z9.408 ; set Z probe trigger value, offset and trigger height
                                M557 X30:220 Y30:220 S40 ; define mesh grid
                                M305 P0 T98801 B4185 R4700 ; Set thermistor + ADC parameters for heater 0
                                M143 H0 S100 ; Set temperature limit for heater 0 to 120C
                                M305 P1 T98801 B4185 R4700 ; Set thermistor + ADC parameters for heater 1
                                M143 H1 S250 ; Set temperature limit for heater 1 to 280C
                                M106 P1 S0.8 I0 F10 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                M106 P2 S0.8 I0 F20 H1:0 T45 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                M563 P0 S"hotend" D0 H1 F0 ; define tool 0
                                ; Pressure Advance
                                M572 D0 S0.35
                                M501 ; Load saved parameters from non-volatile memory
                                T0 ; Select first tool
                                ; BLTouch startup
                                G4 S2 ; Pause a couple seconds
                                M280 P64 S160 ; Clear any alarms
                                M402 ; retract pin just in case
                                  Phaedrux Moderator @Roei3d
                                  @Roei3d said in Need help to config file for ender 3 pro:
                                  Try 600 for X and Y, if slightly loosening the belt doesn't help.
                                  What slicer are you using? Does it have any acceleration and jerk control enabled that may be changing it to a different value than what you have specified in your config?
                                  Can you share a sliced gcode file?
                                  Roei3dundefined 2 Replies Last reply Reply Quote 0
                                  • Roei3dundefined
                                    Roei3d @Phaedrux
                                    @Phaedrux I use cura no jerk and acceleration not enabled in cura, when igi home I upload my last minion print gcode
                                    • Roei3dundefined
                                      Roei3d @Phaedrux
                                      @Phaedrux XYZ NO INFIIL.gcode
                                      this is my gcode xyz cube 0 infiil itray chang m906 to x600 y600 no change
                                        If you do a simple cylinder do you also see the ringing pattern? That would indicate something other than corner ringing that would start strong at a change in direction and then lessen as it moves away from the edge. It's quite hard to tell from those silver prints since the fronts aren't illuminated.
                                        Can you post a video of it printing?
                                        • Roei3dundefined
                                          Roei3d @Phaedrux
                                          @Phaedrux https://youtu.be/nBy0lpH--Uk
                                          In cylinder I hardly see anything.
                                            Try lowering the acceleration and jerk for the Y axis. Perhaps the big heavy mirror is making it shake on direction changes.
