Ender 5 Duet Wifi 2 and BLTouch 3.1
743
    TheBiologist
    Ok so I am new to to the BLTouch and the Ender 5. I have currently updated it to a Duet wifi 2 and a meanwell PSU. I got the printer to work last night fine with manual leveling and end stop switches. I have been using the RRF Config tool to get the BLTouch to work with little success.
    Currently the probe will extend but not retrack after powering up. It will not trigger as an endstop ( I unplugged the original) for homing.
    Config.g
    ; generated by RepRapFirmware Configuration Tool v3.1.3 on Mon Jul 06 2020 13:33:30 GMT-0500 (Central Daylight Time)
    M550 P"Ender 5" ; set printer name
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P2 S0 ; physical drive 2 goes backwards
    M350 X16 Y16 Z16 E16 I0 ; configure microstepping without interpolation
    M92 X80.00 Y80.00 Z400.00 E96.15 ; set steps per mm
    M566 X600.00 Y600.00 Z60.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X30000.00 Y30000.00 Z600.00 E600.00 ; set maximum speeds (mm/min)
    M201 X500.00 Y500.00 Z200.00 E4000.00 ; set accelerations (mm/s^2)
    M906 X850 Y800 Z700 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X220 Y220 Z300 S0 ; set axis maxima
    M950 S0 C"duex.pwm1" ; create servo pin 0 for BLTouch
    M558 P9 C"!zprobe.in+zprobe.mod" H5 F0 T6000 ; set Z probe type to bltouch and the dive height + speeds
    G31 P0 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
    M557 X15:195 Y15:195 S20 ; define mesh grid
    M106 P0 S1 H0 T45 ; set fan 0 value. Thermostatic control is turned on
    M106 P1 S1 H0 T45 ; set fan 1 value. Thermostatic control is turned on
    M950 F2 C"fan1" Q500 ; create fan 2 on pin fan1 and set its frequency
    M106 P2 S0.3 H-1 ; set fan 2 value. Thermostatic control is turned off
    homeall
    ; homeall.g
    ; called to home all axes
    ; generated by RepRapFirmware Configuration Tool v3.1.3 on Mon Jul 06 2020 13:33:32 GMT-0500 (Central Daylight Time)
    G91 ; relative positioning
    G1 H1 X-225 Y-225 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
    G1 H2 X5 Y5 F6000 ; go back a few mm
    G1 H1 X-225 Y-225 F360 ; move slowly to X and Y axis endstops once more (second pass)
    G90 ; absolute positioning
    G1 X15 Y15 F6000 ; go to first bed probe point and home Z
    ;G91 ; relative positioning
    ;G90 ; absolute positioning
    deploy and retract
    M280 P0 S10
    M280 P0 S90
      @TheBiologist said in Ender 5 Duet Wifi 2 and BLTouch 3.1:
      How do you have the BLtouch connected? Do you have a duex?
      Depending on where you have the servo control wire connected, you may need to change the pin name used by M950. I think there is a bug in the configurator that is showing the wrong pin choices for the PWM servo control.
      If you're connected to expansion header 3 like shown in the connecting a bltouch doc it should be like this:
      M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
      M558 P9 C"!zprobe.in" H5 F0 T6000 ; set Z probe type to bltouch and the dive height + speeds
      undefined undefined 2 Replies Last reply 6 Jul 2020, 19:16 Reply Quote 0
        DIY-O-Sphere @Phaedrux
        @Phaedrux said in Ender 5 Duet Wifi 2 and BLTouch 3.1:
        M558 P9 C"^zprobe.in" H5 F0 T6000
        (UTC+1)
        undefined 1 Reply Last reply 6 Jul 2020, 19:17 Reply Quote 1
          Phaedrux Moderator @DIY-O-Sphere
          @DIY-O-Sphere Good eye!
            TheBiologist
            Awesome I will try that. Thanks for the quick reply
              TheBiologist @Phaedrux
              @Phaedrux yes I have it wired like in the photo. I made the suggested changes but bltouch still does not power cycle instead is flashing red at a slow steady rate. When I tried to rest the bltouch i get Error: M280: Invalid servo index 0 in M280 command.
                Please send M115 to verify what firmware version you are actually using.
                Then send M98 P"config.g" in the console and report the results.
                undefined 1 Reply Last reply 6 Jul 2020, 22:51 Reply Quote 0
                  @Phaedrux
                  m115
                  FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.02(RTOS) ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2018-12-24b1
                  M98 P"config.g"
                  HTTP is enabled on port 80
                  FTP is disabled
                  TELNET is disabled
                  Warning: M950 command is not supported
                  Warning: M308 command is not supported
                  undefined 1 Reply Last reply 6 Jul 2020, 23:04 Reply Quote 0
                    DIY-O-Sphere @TheBiologist
                    Your config is for RRF3, but your firmware is RRF2
                    You have to update the firmware.
                    First to 3.0 after that go to 3.1.1
                    (UTC+1)
                    undefined 1 Reply Last reply 7 Jul 2020, 00:22 Reply Quote 0
                      TheBiologist @DIY-O-Sphere
                      @DIY-O-Sphere ok I have now successfully updated to 3.1.1. I am still not getting the bltouch to work. It still will not self test on power up. It drops the pin and then starts blinking red light. I have checked the wires and all connections are good. This is a legit BLTouch with their wiring.
                      undefined 1 Reply Last reply 7 Jul 2020, 02:20 Reply Quote 0
                        TheBiologist
                        M98 P"config.g"
                        M98 P"config.g"
                        FTP is disabled
                        TELNET is disabled
                        Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
                        Error: Pin 'fan1' is not free
                        Error: Fan number 2 not found
                        m115
                        FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-05-19b2
                        undefined 1 Reply Last reply 7 Jul 2020, 02:23 Reply Quote 0
                          TheBiologist
                          Fixed the fan error. Not sure what to do with the heater error or that the z probe is reading 1000 like it is being triggered.
                          undefined 1 Reply Last reply 7 Jul 2020, 02:24 Reply Quote 0
                            Phaedrux Moderator @TheBiologist
                            What happens if you connect only 5v and ground? That should cause it to self test. If it's still failing on self test check the pin. You can remove the grub screw on the top of the body and remove the pin. Maybe it's bent or dirty.
                            If it's still failing self test try and send the error reset command and then try and deploy and retract again.
                            What do you have in your config.g and deploy and retract now?
                            undefined 1 Reply Last reply 7 Jul 2020, 03:39 Reply Quote 0
                              This is just telling you what it thinks your bed temp could reach if it fails on. To get rid of the warning choose a lower powered heater. Otherwise, just be aware. Don't leave it unattended. Have a fire extinguisher handy. Smoke alarm. Thermal cut out fuse.
                              undefined 1 Reply Last reply 7 Jul 2020, 03:40 Reply Quote 0
                                Did you change your ! to a ^ in the M558 as pointed out by @DIY-O-Sphere ?
                                If you did change that and it's still showing 1000 all the time, that could mean the probe is damaged, or there is a problem with your white signal wire.
                                undefined 1 Reply Last reply 7 Jul 2020, 05:13 Reply Quote 0
                                  @Phaedrux The probe cycles twice and then starts blinking red.
                                  M558 P9 C"^zprobe.in" H5 F0 T6000 ; set Z probe type to bltouch and the dive height + speeds
                                  M950 F2 C"fan2" Q500 ; create fan 2 on pin fan1 and set its frequency
                                  Deploy and retract
                                  M280 P0 S10 ; deploy BLTouch
                                  M280 P0 S90 ; retract BLTouch
                                    @Phaedrux it is just the factory ender 5 bed heater. Is that normal?
                                    undefined 1 Reply Last reply 7 Jul 2020, 04:02 Reply Quote 0
                                      Don't set it to P0. That meas triggered at not triggered. Use G31 P25
                                      You need a feed rate set too. Use F60.
                                      undefined 1 Reply Last reply 7 Jul 2020, 15:15 Reply Quote 0
                                        yeah it's not uncommon to see the warning. It's a motorized hot plate with wifi afterall.
                                          @Phaedrux Thanks for the help! SO far so good. I will try leveling the bed tomorrow.
                                          5 out of 21
