    Homing advice
    3.0k
      So you have the choice of either viewing the "back" of the printer as the "front" and choosing the back right corner as 0,0 and the homing position, or choosing the front left as 0,0 and the homing position at the high end of travel in the back right corner.
      Either way is fine, but you need to be careful that you don't get an axis flipped which can lead to printed models being mirrored from what the slicer shows since the slicer is assuming the 0,0 position is in the front left and +X moves to the right, -X to the left. -Y to the front, +Y to the back.
      • agent0810undefined
        agent0810
        so i think i would like to keep the Back of the printer as the 0,0 since that is where the stop switches are. but im still confused on what i need to change to make that happen. i know im being a complete noob and i apologize for that .
          Well 0,0 and the endstops don't have to match. Homing to the high end of travel is fine. This has the benefit of staying matched with the slicer view and stays consistent with the language normally used with printers, namely the right handed coordinate system, meaning +X moves to the right, -X to the left. -Y to the front, +Y to the back.
          Here are some illustrations.
          So in your case, here's what you need to change in your config.
          M574 X2 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop
          M574 Y2 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop
          Instead of X1 and Y1, it's not X2 and Y2, for the high end of travel, back right corner.
          And change the directions of travel for the homing moves from negative to positive.
          ; homeall.g
          ; called to home all axes
          ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sun Jul 05 2020 20:32:27 GMT-0500 (Central Daylight Time)
          G91 ; relative positioning
          G1 H1 X+250 Y+250 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
          G1 H2 X-5 Y-5 F6000 ; go back a few mm
          G1 H1 X+230 Y+230 F360 ; move slowly to X and Y axis endstops once more (second pass)
          G1 H1 Z305 F360 ; move Z up stopping at the endstop
          G90 ; absolute positioning
          G92 Z300 ; set Z position to axis maximum (you may want to adjust this)
          ; homex.g
          ; called to home the X axis
          G1 H1 X+250 F1800 ; move quickly to X axis endstop and stop there (first pass)
          G1 H2 X-5 F6000 ; go back a few mm
          G1 H1 X+230 F360 ; move slowly to X axis endstop once more (second pass)
          G1 H2 Z-5 F6000 ; lower Z again
          ; homey.g
          ; called to home the Y axis
          G1 H1 Y+230 F1800 ; move quickly to Y axis endstop and stop there (first pass)
          G1 H2 Y-5 F6000 ; go back a few mm
          G1 H1 Y+230 F360 ; move slowly to Y axis endstop once more (second pass)
            agent0810
            thank you for the detailed explanation, makes a little more sense now. still working on understanding the settings though. i made you suggested changes and now the extruder is in the front right corner and when i do home all sits there and bangs over and over when each of the axis homes.
            X+ currently moves to the left
            Y+ moves towards myself or the front
            Z+ moves the bed up
              Did you copy and paste my homing files into yours?
              And just to confirm...
              Is the X endstop on the left or right?
              Is the Y endstop at the front or back?
                agent0810
                yes sir, copied and pasted.
                The Y is in the back right corner.
                The x is on the right,
                  @Phaedrux said in Homing advice:
                  M574 X2 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y2 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop
                  And you changed M574 to X2 and Y2?
                    agent0810
                    yes sir copied all 3 homing files and pasted over mine.
                    M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
                      Alright, then we may need to change a motor direction.
                      Try
                      M569 P0 S0
                      M569 P1 S0
                        agent0810
                        That may have done it.
                        X+ Moves to the right !!!!!!
                        Y+ Moves to the Back!!!!
                        Z+ Moves up!!!!!
                        so after i home, the "position tool" says its X - 225.0, Y 225.0, Z - 300.00 thats what i want right?
                          Phaedrux Moderator @agent0810
                          @agent0810 said in Homing advice:
                          Are those negative values?
                            agent0810
                            no dashes,
                            Status
                            Printing
                            Mode: FFF
                            Tool Position
                            X
                            225.0
                            Y
                            225.0
                            Z
                            300.00
                              The last thing to check is that when you move to 0,0 it's at the corner of the bed. If it's not, then you'll have to adjust the M208 maxima values.
                                agent0810
                                so when i "home all" it sends it to the back right corner. when i got to 0,0 it goes to the front left corner. when i try to start a print, it starts in the back right corner, bangs against the stops then the bed starts to lower all the way.
                                  What do you have in your start gcode?
                                    agent0810
                                    Here is the start:
                                    ;FLAVOR:Marlin
                                    ;TIME:336
                                    ;Filament used: 0.10025m
                                    ;Layer height: 0.2
                                    ;MINX:89
                                    ;MINY:95
                                    ;MINZ:0.2
                                    ;MAXX:131
                                    ;MAXY:125
                                    ;MAXZ:14.8
                                    ;Generated with Cura_SteamEngine 4.6.1
                                    M140 S60
                                    M105
                                    M190 S60
                                    M104 S230
                                    M105
                                    M109 S230
                                    M82 ;absolute extrusion mode
                                    M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration
                                    M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate
                                    M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
                                    M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
                                    M220 S100 ;Reset Feedrate
                                    M221 S100 ;Reset Flowrate
                                    G28 ;Home
                                    G92 E0 ;Reset Extruder
                                    G1 Z2.0 F3000 ;Move Z Axis up
                                    G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
                                    G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
                                    G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
                                    G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
                                    G92 E0
                                    G92 E0
                                    G1 F5100 E-7
                                    ;LAYER_COUNT:86
                                    ;LAYER:0
                                    M107
                                      Unrelated, but delete those lines from your slicer start gcode section in Cura.
                                      I don't see a G90 in there to make sure you're in absolute positioning mode.
                                      Does it do the prime line correctly or does it just start crashing?
                                        agent0810
                                        just starts crashing.
                                          agent0810
                                          Here are my machine settings in cura......do the print head settings look okay?
                                            Change the Gcode flavor to RepRap.
                                            Can you share an actual sliced gcode file?
