    Homing advice
    3.0k
    • agent0810undefined
      agent0810
      thank you for the detailed explanation, makes a little more sense now. still working on understanding the settings though. i made you suggested changes and now the extruder is in the front right corner and when i do home all sits there and bangs over and over when each of the axis homes.
      X+ currently moves to the left
      Y+ moves towards myself or the front
      Z+ moves the bed up
        Did you copy and paste my homing files into yours?
        And just to confirm...
        Is the X endstop on the left or right?
        Is the Y endstop at the front or back?
          agent0810
          yes sir, copied and pasted.
          The Y is in the back right corner.
          The x is on the right,
            @Phaedrux said in Homing advice:
            M574 X2 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y2 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop
            And you changed M574 to X2 and Y2?
              agent0810
              yes sir copied all 3 homing files and pasted over mine.
              M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
                Alright, then we may need to change a motor direction.
                Try
                M569 P0 S0
                M569 P1 S0
                  agent0810
                  That may have done it.
                  X+ Moves to the right !!!!!!
                  Y+ Moves to the Back!!!!
                  Z+ Moves up!!!!!
                  so after i home, the "position tool" says its X - 225.0, Y 225.0, Z - 300.00 thats what i want right?
                    Phaedrux Moderator @agent0810
                    @agent0810 said in Homing advice:
                    Are those negative values?
                      agent0810
                      no dashes,
                      Status
                      Printing
                      Mode: FFF
                      Tool Position
                      X
                      225.0
                      Y
                      225.0
                      Z
                      300.00
                        The last thing to check is that when you move to 0,0 it's at the corner of the bed. If it's not, then you'll have to adjust the M208 maxima values.
                          agent0810
                          so when i "home all" it sends it to the back right corner. when i got to 0,0 it goes to the front left corner. when i try to start a print, it starts in the back right corner, bangs against the stops then the bed starts to lower all the way.
                            What do you have in your start gcode?
                              agent0810
                              Here is the start:
                              ;FLAVOR:Marlin
                              ;TIME:336
                              ;Filament used: 0.10025m
                              ;Layer height: 0.2
                              ;MINX:89
                              ;MINY:95
                              ;MINZ:0.2
                              ;MAXX:131
                              ;MAXY:125
                              ;MAXZ:14.8
                              ;Generated with Cura_SteamEngine 4.6.1
                              M140 S60
                              M105
                              M190 S60
                              M104 S230
                              M105
                              M109 S230
                              M82 ;absolute extrusion mode
                              M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration
                              M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate
                              M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
                              M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
                              M220 S100 ;Reset Feedrate
                              M221 S100 ;Reset Flowrate
                              G28 ;Home
                              G92 E0 ;Reset Extruder
                              G1 Z2.0 F3000 ;Move Z Axis up
                              G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
                              G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
                              G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
                              G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
                              G92 E0
                              G92 E0
                              G1 F5100 E-7
                              ;LAYER_COUNT:86
                              ;LAYER:0
                              M107
                                Unrelated, but delete those lines from your slicer start gcode section in Cura.
                                I don't see a G90 in there to make sure you're in absolute positioning mode.
                                Does it do the prime line correctly or does it just start crashing?
                                  agent0810
                                  just starts crashing.
                                    agent0810
                                    Here are my machine settings in cura......do the print head settings look okay?
                                      Change the Gcode flavor to RepRap.
                                      Can you share an actual sliced gcode file?
                                        agent0810
                                        yea let me see what i can get. should i just place G90 in before the G92? googled it and didnt see an actual setting for it in cura but someone said they just put it in the start code.
                                          Well I'd like to see the full sliced gcode first to see what it's actually got inserted where.
                                            agent0810
                                            I think this is what you are looking for.
                                            base_x.gcode
