    PA tuning
    1.1k
      Phaedrux Moderator @arhi
      @arhi said in PA tuning:
      I fear it has to maybe do with how my e3dv6 with .6 nozzle and bmg handle this under extrusion... will have to do some testing... as visualising the g-codes everything looks ok
      Yes I think it looks like underrun. I seen it too on thin walled objects sometimes. Usually at the start of a line. Extra reprime can help in that case.
      • arhiundefined
        arhi @Phaedrux
        @Phaedrux need to inspect these IM gcode files, the s3d files I inspected it looked like problem is at the end of the line, not beginning.
        • arhiundefined
          arhi
          slowly moving forward on this problem... and it's making less and less sense 😞
          I decided to record the print to see if that will give me more data and I see that my idea that holes are at the end of the line, well, %$#_^@& they are not, they are at the BEGINING 😞 ..
          https://youtu.be/Lm0CWD4I9PI
          The G-Code is nothing special, the layer start by "go up, move to begining, start printing"
          and first segment (that's turned in to hole) is printed with 0.131mm/min extrusion just like all the other segments in the line
          but for some reason, nozzle is "empty" at this moment... and the "line" start forming somewhere at the middle of the first or begining of the second move.
          so the prev layer finishes, with positive extrusion...
          G1 F1800 X12.605 Y-21.648 E0.0371
          G0 F7800 X11.224 Y-22.039
          G1 F1800 X10.479 Y-22.290 E0.0306
          G1 X9.226 Y-22.553 E0.0256
          G1 X8.576 Y-22.708 E0.0875
          ;LAYER:7
          ;Z:4.000
          ;HEIGHT:0.500
          M106 S252
          there's a minimal 0.1mm retraction (that happens on the other prints as well where there are no holes)
          G1 F3000 E-0.1000
          so then lift up move to start position
          G0 F1200 Z4.000
          G0 F7800 X8.980 Y-23.015
          prime 0.1mm and start printing
          ;TYPE:WALL-OUTER
          ;WIDTH:0.700
          G1 F3000 E0.1000
          G1 F2400 X11.352 Y-22.489 E0.3182    ; HERE IS THE HOLE!!!!!
          G1 X12.701 Y-21.993 E0.1882
          I don't get it 😞
          • arhiundefined
            arhi
            problematic g-code
            link-prob.gcode
            @Phaedrux why is .7z or .zip not allowed extension? would make sense to 7z the .gcode files
            • jens55undefined
              jens55
              May I ask what program you are using to examine the g-code? It looks interesting!
              • arhiundefined
                arhi @jens55
                @jens55 said in PA tuning:
                That is CraftWare. It's a decent slicer, not feature-packed like other most popular ones (like for e.g. ideaMaker that generated the code I'm inspecting) but is IMO THE BEST g-code preview app out there. Try it out, lot of ppl use it as a slicer too and they are happy with it, it's "very visual", the devs are very responsive, development is very active and it's getting better and better every day..
                • jens55undefined
                  jens55
                  Gaaaa ..... it tells me I am not a human when I sign up for the newsletter. I might have to fire up Chrome but this is SOOOO annoying!
                  Thanks for the info though, never heard of this program before!
                  Edit: Damn Captcha .....
                  • arhiundefined
                    arhi @jens55
                    @jens55 recaptcha is having some issues these days, I had to turn off ABP and uBLOCK on my firefox in order to get netfabb 2020 premium downloaded and installed 😞 .. anyhow crafware is worth the hastle... I'm still not happy with it as a slicer (it's not bad, just idea maker is imo better) but it is very good, the support system is awesome, config system is also very very clear and easy to use... it's an eye candy .. and the gcode preview is the best there is... for e.g. if you ever tried velocity printing, craftware is the only g-code preview where you actually see the velocity print directly in the preview, it is that good 🙂
                    • jens55undefined
                      jens55
                      Yes, I did download it with chrome and agreed, eye candy factor is awesome 🙂
                      I only had limited time playing with it so far but it looks awesome.
                      • arhiundefined
                        arhi @jens55
                        @jens55 yup, super nice, I have not tried it slicing for few months, should check it again these days, but ideaMaker was lot better last time I compared them. Anyhow, IMHO, it's better than both cura and prusa slicer
                        • petriheinoundefined
                          petriheino
                          Hi, Im trying to repeat this test and trying to find solution.
                          @arhi did you found any solution for it or which way did you go with retraction/PA settings?
                          • arhiundefined
                            arhi @petriheino
                            @petriheino said in PA tuning:
                            did not turn on any of my printers for almost a year.. too much work to be done, no time for hobbies 😞 so nothing done about this
