Duet 3 RRF 3 Stepper motors pausing
This has been on ongoing issue. I will home the printer and during homing the motors will pause. Come to a full stop then continue on. I haven't seen anything that indicates what could be causing this.
Please post your config.g. XY stuttering can be caused by using mesh compensation and having a too low Z jerk value which causes the XY to pause to allow time for the Z axis to change height since it's a coordinated move. Increasing the Z axis jerk to at least 60mm/min is usually enough to solve it.
If that's not the case, please provide more details.
@Phaedrux I will check that when I get home from work and respond. Thank you.
@Phaedrux
; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 16 2020 08:02:01 GMT-0700 (Pacific Daylight Time); General preferences
M550 P"Duet 3" ; set printer name
M669 K1 ; select CoreXY mode; Drives
M569 P0.0 S0 ; physical drive 0.0 goes forwards
M569 P0.2 S0 ; physical drive 0.2 goes backwards
M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
M92 X80.00 Y80.00 Z400.00 E415.00 ; set steps per mm
M203 X9000.00 Y9000.00 Z480.00 E3600.00 ; set maximum speeds (mm/min)
M201 X2500.00 Y2500.00 Z20.00 E1000.00 ; set accelerations (mm/s^2)
M208 X330 Y330 Z400 S0 ; set axis maxima; Endstops
M574 X1 S1 P"!io0.in" ; configure active-high endstop for low end on X via pin !io0.in
M574 Y1 S1 P"!io1.in" ; configure active-high endstop for low end on Y via pin !io1.in
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
M558 P9 C"^io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds height + speeds
G31 P500 X-40 Y-10 Z4.25 ; set Z probe trigger value, offset and trigger height
M557 X50:260 Y50:260 S20 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B4008 ; configure sensor 0 as thermistor on pin temp0
M308 S1 P"temp1" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin temp1
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
M950 F2 C"out9" Q500 ; create fan 2 on pin out9 and set its frequency
M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off; Tools
M501 -
@mrenz999 said in Duet 3 RRF 3 Stepper motors pausing:
As I suspected.
@Phaedrux What should it be for the z ?
@mrenz999 a good place to start is doubling it. Then double again. Once it works you are good. Or try 60 as was suggested before.
@Phaedrux said in Duet 3 RRF 3 Stepper motors pausing:
