G29 G32 😱
The highlighted item being greyed out is ok because It's referring to a different means of compensation. You are using mesh compensation (it shows it as active "compensation in use" mesh" To disable it you would use "disabled mesh compensation (g29 S2)"
@Phaedrux hello agree so here is fine. can you please tell me if my start script is correct?
Yes that looks like it should work
I'm afraid the issue is with the calibration and mesh creation being inaccurate due to mechanical issues. Some things software can't correct for.
I also tried to lower 40% of the values in the map where I highlighted in the photo above ...
without success I have not noticed any difference -
and how is it possible then that without the map doing only the G32 and putting a thickness of paper folded in 2 under the plate I adjust only the height print well
If it's printing well without G29, why use G29?
The combination of probe offset from the nozzle and effector tilt varying with position can lead to probed points being inaccurate.
yes I understand but something should change if I change the values of the map manually instead nothing changes ok thanks for everything I keep the thickness of cards under the plate
@Phaedrux
G29 S1 P "heightmap.csv also delete this from simplify3d start script? bI'm sorry if I write badly I use google translate -
Just delete the
P "heightmap.csv"
part from the start script. Leave G29 S1 intact. -
ok
@Phaedrux nothing has changed
Then I'm all out of ideas and we're back to improving the mechanics. That's the limit of my delta insight unfortunately.
hello can you tell me if I have to set the offset of my extruder with respect to the center of the effector? maybe that's why the map doesn't compensate well
Do you mean the offset of the probe?
@Phaedrux no my titan aero is not in the center of my effector so the nozzle is not in the center of the effector
