    Duet3 + Pi DWC freezing
    Duet Web Control
    2.0k
    • chrishammundefined
      chrishamm administrators @Carlo
      @Carlo Maybe you need to run sudo chmod +x /opt/dsf/bin/DuetControlServer if you deleted it before.
      Unfortunately I've found another issue which I am still debugging. I'll post an update here when I've fixed that.
      Duet software engineer
      Carloundefined 1 Reply Last reply Reply Quote 0
      • Carloundefined
        Carlo @chrishamm
        @chrishamm said in Duet3 + Pi DWC freezing:
        That fixed it ..as in its not freezing now 👏 👍
        Thanks Really Appreciate Your Help!
        C
        • Carloundefined
          Carlo @Carlo
          @Carlo
          Sorry Chris I spoke to soon doing it is again
            @Carlo I've been able to reproduce it and will come up with a fix shortly. In the meantime, reloading DWC when it freezes should solve your problem.
            Carloundefined 2 Replies Last reply Reply Quote 0
            • Carloundefined
              Carlo @chrishamm
              @chrishamm
              Hi Chris
              That's great
              I don't want it to seem I'm hassling you I'm not as the standalone works fine my issue is a when ever just thought the feedback could help in general.
              Thanks
              C
                dc42 administrators @Carlo
                @Carlo said in Duet3 + Pi DWC freezing:
                @chrishamm
                Hi Chris
                That's great
                Thanks
                C
                Your feedback is indeed helpful. We are preparing a 3.1.1 release and it's good to get fixes for other significant bugs into it.
                • Carloundefined
                  Carlo @chrishamm
                  @chrishamm
                  Hi Chris,
                  It was not possible to just reload the page as gcode files would not start it would heat as expected but on initial movement would then try to home and not recognize the endstops so I installed DSF etc from a standalone raspbian install which has fixed the freezing but not the unable to print with the same issues as above also cannot use the webcam in DWC as it causes DWC to restart with out displaying error on each attempt though I can view the Pi cam from the web browser.
                  This is on 3.1.1 as per apt get.
                  Cheers
                  C
                  • Carloundefined
                    Carlo @Carlo
                    @Carlo
                    Hi Chris DC,
                    Any update on a fix for this minor issue ?
                    Cheers
                    C
                      Phaedrux Moderator @Carlo
                      this minor issue ?
                      Sorry what's the minor remaining issue in a nut shell?
                      • Carloundefined
                        Carlo @Phaedrux
                        @Phaedrux
                        That when G-code is loaded it results in unexpected movement at the start of a print like the nozzle being plowed in to the bed or homed with the carriages crashing at the end stops and without the Pi files print as expected.
                        Cheers
                        C
                        • Carloundefined
                          Carlo @Phaedrux
                          @Phaedrux
                          Does this have any meaning in the issues I'm having ?
                          7/14/2020, 2:05:13 PM Warning: Firmware halted
                          7/14/2020, 2:05:13 PM Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)
                          7/14/2020, 2:05:12 PM Connection to Duet established
                          7/14/2020, 2:05:12 PM Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)
                          Video of issue linked below
                          https://youtu.be/29_tLbxniCM
                          Exactly the same issue with 2off Pi4b 1off Pi3b+ at the same point always
                          Cheers
                          C
                          • Carloundefined
                            Carlo @Carlo
                            @Carlo
                            Works OK in stand alone
                            https://www.youtube.com/watch?v=mCwJnyaidI4
                              @Carlo Under investigation.
                              • Carloundefined
                                Carlo @Phaedrux
                                @Phaedrux
                                Cheers
                                • Carloundefined
                                  Carlo @Carlo
                                  @Carlo
                                  So received my new Duet 3 yesterday so new board new cable new installation DuetPi
                                  nothing else attached same issue works perfectly in stand alone and does everything in SBC mode but print ...If I use DuetPi it will start the print then head to the endstops but wont stop at them after a few seconds but if I build PiOs install DSF etc it heads the other way and ploughs in to the bed but at the same point everytime after a few seconds to the mm?
                                  with the motors screeming and M122 shows no errors everything is peachy as far as the board is concerned ...Turns out its the purge line in my start code.. which works fine in standalone mode but not SBC SBC "worked" without it Huh? Quotes well A print
                                  Is it the spacing of the lines printing at the moment so can't retry right now but like to know how it ends.
                                  any ideas ?
                                  ; Draw arc to prime the nozzle between 6PM and 9PM on the bed edge
                                  G1 X0 Y-175 Z0.25 F6000
                                  G2 X-175 Y0 I0 J175 E30 F1500
                                  G1 X-174.52
                                  G3 X0 Y-174.52 I174.52 J0 E28 F1500
                                  Cheers
                                  C
                                  Phaedruxundefined chrishammundefined 2 Replies Last reply Reply Quote 0
                                    @Carlo Interesting. I guess it doesn't like the arc.
                                      @Carlo Can you please upload the full file?
                                      • Carloundefined
                                        Carlo @chrishamm
                                        @chrishamm
                                        Its any with that start code so here you go a small one it gets about 10mm in to the purge arc then thats all she wrote
                                        Predator_rail_align_guide_v2higher.gcode
                                          @Carlo Thanks for the file. I could provoke an error that will be fixed in v3.2 but I am not sure if it is related to the problem you reported. I'll try your G2 code on Monday when I get back and report my findings.
                                          • Carloundefined
                                            Carlo @chrishamm
                                            @chrishamm
                                            Only posted in case its of help to you guys if it is actually a bug ...now with leaving it out of my slicer my SBC setup is printing beautifully and I simply set 0.5mm unretract before start of print so no purge needed in PSlicer so all good.
                                            Cheers
                                            C
