    Duet3 + Pi DWC freezing
    Duet Web Control
    2.0k
    • chrishammundefined
      chrishamm administrators @Carlo
      @Carlo I've been able to reproduce it and will come up with a fix shortly. In the meantime, reloading DWC when it freezes should solve your problem.
      Duet software engineer
      Carloundefined 2 Replies Last reply Reply Quote 0
      • Carloundefined
        Carlo @chrishamm
        @chrishamm
        Hi Chris
        That's great
        I don't want it to seem I'm hassling you I'm not as the standalone works fine my issue is a when ever just thought the feedback could help in general.
        Thanks
        C
          dc42 administrators @Carlo
          @Carlo said in Duet3 + Pi DWC freezing:
          @chrishamm
          Hi Chris
          That's great
          Thanks
          C
          Your feedback is indeed helpful. We are preparing a 3.1.1 release and it's good to get fixes for other significant bugs into it.
          • Carloundefined
            Carlo @chrishamm
            @chrishamm
            Hi Chris,
            It was not possible to just reload the page as gcode files would not start it would heat as expected but on initial movement would then try to home and not recognize the endstops so I installed DSF etc from a standalone raspbian install which has fixed the freezing but not the unable to print with the same issues as above also cannot use the webcam in DWC as it causes DWC to restart with out displaying error on each attempt though I can view the Pi cam from the web browser.
            This is on 3.1.1 as per apt get.
            Cheers
            C
            Carloundefined 1 Reply Last reply Reply Quote 0
            • Carloundefined
              Carlo @Carlo
              @Carlo
              Hi Chris DC,
              Any update on a fix for this minor issue ?
              Cheers
              C
                Phaedrux Moderator @Carlo
                this minor issue ?
                Sorry what's the minor remaining issue in a nut shell?
                • Carloundefined
                  Carlo @Phaedrux
                  @Phaedrux
                  That when G-code is loaded it results in unexpected movement at the start of a print like the nozzle being plowed in to the bed or homed with the carriages crashing at the end stops and without the Pi files print as expected.
                  Cheers
                  C
                  • Carloundefined
                    Carlo @Phaedrux
                    @Phaedrux
                    Does this have any meaning in the issues I'm having ?
                    7/14/2020, 2:05:13 PM Warning: Firmware halted
                    7/14/2020, 2:05:13 PM Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)
                    7/14/2020, 2:05:12 PM Connection to Duet established
                    7/14/2020, 2:05:12 PM Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)
                    Video of issue linked below
                    https://youtu.be/29_tLbxniCM
                    Exactly the same issue with 2off Pi4b 1off Pi3b+ at the same point always
                    Cheers
                    C
                    • Carloundefined
                      Carlo @Carlo
                      @Carlo
                      Works OK in stand alone
                      https://www.youtube.com/watch?v=mCwJnyaidI4
                        @Carlo Under investigation.
                        • Carloundefined
                          Carlo @Phaedrux
                          @Phaedrux
                          Cheers
                          • Carloundefined
                            Carlo @Carlo
                            @Carlo
                            So received my new Duet 3 yesterday so new board new cable new installation DuetPi
                            nothing else attached same issue works perfectly in stand alone and does everything in SBC mode but print ...If I use DuetPi it will start the print then head to the endstops but wont stop at them after a few seconds but if I build PiOs install DSF etc it heads the other way and ploughs in to the bed but at the same point everytime after a few seconds to the mm?
                            with the motors screeming and M122 shows no errors everything is peachy as far as the board is concerned ...Turns out its the purge line in my start code.. which works fine in standalone mode but not SBC SBC "worked" without it Huh? Quotes well A print
                            Is it the spacing of the lines printing at the moment so can't retry right now but like to know how it ends.
                            any ideas ?
                            ; Draw arc to prime the nozzle between 6PM and 9PM on the bed edge
                            G1 X0 Y-175 Z0.25 F6000
                            G2 X-175 Y0 I0 J175 E30 F1500
                            G1 X-174.52
                            G3 X0 Y-174.52 I174.52 J0 E28 F1500
                            Cheers
                            C
                            Phaedruxundefined chrishammundefined 2 Replies Last reply Reply Quote 0
                              @Carlo Interesting. I guess it doesn't like the arc.
                                @Carlo Can you please upload the full file?
                                • Carloundefined
                                  Carlo @chrishamm
                                  @chrishamm
                                  Its any with that start code so here you go a small one it gets about 10mm in to the purge arc then thats all she wrote
                                  Predator_rail_align_guide_v2higher.gcode
                                    @Carlo Thanks for the file. I could provoke an error that will be fixed in v3.2 but I am not sure if it is related to the problem you reported. I'll try your G2 code on Monday when I get back and report my findings.
                                    • Carloundefined
                                      Carlo @chrishamm
                                      @chrishamm
                                      Only posted in case its of help to you guys if it is actually a bug ...now with leaving it out of my slicer my SBC setup is printing beautifully and I simply set 0.5mm unretract before start of print so no purge needed in PSlicer so all good.
                                      Cheers
                                      C
                                      • Carloundefined
                                        Carlo @chrishamm
                                        @chrishamm
                                        Hi Chris,
                                        Just thought I would let you know the latest update fixed the issue.
                                        Cheers
                                        C
                                        chrishammundefined 1 Reply Last reply Reply Quote 1
                                          @Carlo Great, thanks for letting me know!
