Setup Duet 3 Config no tools shown
@roth I am using a tablet and cannot read your zip file, maybe you can post it in a readable format please.
; Configuration file for Duet 3 (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Jul 22 2020 23:16:26 GMT+0200 (Mitteleuropäische Sommerzeit) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Duet 3" ; set printer name M665 R155 L397.19 B155 H520 ; Set delta radius, diagonal rod length, printable radius and homed height M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them ; Drives M569 P0.0 S1 ; physical drive 0.0 goes forwards M569 P0.1 S1 ; physical drive 0.1 goes forwards M569 P0.2 S1 ; physical drive 0.2 goes forwards M569 P0.3 S1 ; physical drive 0.3 goes forwards M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z80.00 E403.00 ; set steps per mm M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min) M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min) M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2) M906 X1200 Y1200 Z1200 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 Z0 S1 ; set minimum Z ; Endstops ; WARNING: No endstops configured ; Z-Probe M950 S0 C"io4.out" ; create servo pin 0 for BLTouch M558 P9 C"^io4.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X0 Y20 Z0 ; set Z probe trigger value, offset and trigger height M557 R150 S45 ; define mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1 M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ; Fans M950 F0 C"out8" Q500 ; create fan 0 on pin out8 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"out9" Q500 ; create fan 1 on pin out9 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M575 P1 S1 B57600 ; enable support for PanelDue M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
@roth thanks a lot, now I can look at it!
@roth what you can do as first step is to validate whether the config is valid by calling
M98 P"config.g"
and check for errors. I don't see an error at first view. -
@JoergS5 said in Setup Duet 3 Config no tools shown:
M98 P"config.g"
Error: Bad command: Q0 @"Miscellaneous" 23.7.2020, 00:22:53 M98 P"config.g" Error: Bad command: Q0 @"Configuration file for Duet 3 (firmware version 3)" Error: Bad command: Q0 @"executed by the firmware on start-up" Error: Bad command: Q0 @"Drives" Error: Bad command: Q0 @"Axis Limits" Error: Bad command: Q0 @"Endstops" Error: Bad command: Q0 @"WARNING: No endstops configured" Error: Bad command: Q0 @"Z-Probe" Error: Bad command: Q0 @"Heaters" Error: Bad command: Q0 @"Fans" Error: Bad command: Q0 @"Tools" 23.7.2020, 00:22:53 Error: Bad command: Q0 @"Custom settings are not defined" 23.7.2020, 00:22:53 Warning: heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C. 23.7.2020, 00:22:52 Error: Bad command: Q0 @"General preferences" 23.7.2020, 00:22:52 Error: Bad command: Q0 @"generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Jul 22 2020 23:16:26 GMT+0200 (Mitteleu" 23.7.2020, 00:22:52 Error: Bad command: Q0 @"" -
@roth strange, it interpretes the comments as G-Code
Ok thanks for your Help. I know something is wrong.
@roth something similar happened here https://forum.duet3d.com/topic/11848/bad-command-missing-characters-in-gcode-since-firmware-upgrade
and here
https://forum.duet3d.com/topic/2565/unable-to-edit-config-files-in-duet-web-controlThe first tries were to check the SDCard and to use a different browser.
@roth despite the errors it seems to process the config, so you can try appending T0 at the end of the config.
I do not understand that.
Just insert T0 at the end of the config code? -
@roth yes, to select the tool
no change
RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 version 3.0beta12 running on Duet 3 MB6HCApparently something is wrong.
The board is new.
I wonder why there is a beta version on it.
I only used the iso for the Raspberry. -
@roth so you should update to 3.1.1
Even a new board can lay around at some vendor. And 3.0beta12 is not very old (maybe 2 months)
You can get the newest binaries from
https://github.com/Duet3D/RepRapFirmware/releases -
Yes i tried.
Nothing changes in the version.
I have to try that without Raspberry. -
I have write the image new to the mico sd. And I tried to update to version 3.0 via the web interface. But it doesn't work, please wait while updates are being installed .
And when i start all new the old firmware is on the board. -
@roth From time to time (usually after an emergency stop), my tools + bed heater also don't show up in DuetWebControl.
I've fixed this by:
1). backing up my current config
2). opening config.g in DWC and deleting all contents
3). Paste the contents back in using my back-upI don't know why I have this problem, or why these steps seem to fix it.
Or maybe just reuploading the config would work too.
To update the Duet 3 with SBC, you will need to use the pi as described here:
sudo apt update
sudo apt upgrade3.1.1 should be your first step in getting up and running.
Yes but after that the Firmware on the board are the same. Update not work.
Ah, I'm afraid that beta 12 had some problems with updating sometimes. In the link I posted above the section directly below the sudo commands is instructions on using Bossa to flash the firmware directly to the board over USB. Follow that and then you should get on your way.
