Endstop LED lighting, but DWC does not show them triggered
1.3k
    fcwilt
    Hi
    What is the output voltage of your device when you are reading the -1.2?
    And where is the ground connection of your device connected?
    undefined 1 Reply Last reply 23 Jul 2020, 03:54 Reply Quote 0
      A Former User
      How about you for a second entertain the possibility the sensor is faulty and list the full model number so we can look at the specs?
        Leav @fcwilt
        @fcwilt said in Endstop LED lighting, but DWC does not show them triggered:
        Hi
        • When the sensor outputs 24v, input is at 3.3v (diode works!)
        • When the sensor outputs 0v/GND, input is at 1.2v (positive voltage, I was using the tilda sign)
        • GND is connected to endstop GND pin (because of wiring issues, all the endstop GNDS are connected to the E0-stop GND)
        @bearer said in Endstop LED lighting, but DWC does not show them triggered:
        • I have 3 such sensors (delta axes), and all 3 show the same behavior.
          *** Disconnected from the board they pull down the voltage to 0.7v!** holy moly this is the problem!
        • Model number is marked as "CHE12-4NA-A710 (LJ12A3-4-Z/BX)"
        • Apologies for not including this earlier!
        I'll investigate this further to see if this is an issue in my setup or the sensor!
        undefined ? 2 Replies Last reply 23 Jul 2020, 04:20 Reply Quote 0
          fcwilt @Leav
          @Leav
          Well if the output of the device only goes to 0.7 volts when you add in the voltage drop across the diode you added you are up to about 1.4 volts.
          You measured 1.2 volts - so that is about right.
          If 1.2 volts is too high then you may have to use the multiple diode approach I mentioned since this would allow pulling down the input to the 0.7 volts of the device while preventing the device from pulling up the input higher than 4 diode drops - or 2.8 volts. Three diodes might be enough if 2.1 volts is sufficient to deactivate the input.
            A Former User @Leav
            @Leav said in Endstop LED lighting, but DWC does not show them triggered:
            i doubt it, 0.7v across the NPN junction on the sensor is well below the logic threshold MIN [0.8V, 0.3 × VDDIO] for the input pin; but it does mean that adding a diode (another PN junction) adds another 0.7v which brings you over the threshold. Maybe a schotty diode would do the trick, but not alot of margins.
            unfortunately quick google search doesn't yield a datasheet that shows a pull up resistor in the sensor so you'd probably have to measure the value of the pull up and design your voltage divider accordingly.
              Leav
              @bearer @fcwilt
              What do you think of this setup? (proposed on reddit).
              Is there any chance of damaging the 3.3v rail with a setup like this?
                fcwilt
                Well I would not try that approach without hearing from dc42 first.
                Perhaps the multiple diode approach seems a bit of a kludge but it is safe.
                Do you know what the logic threshold voltages are for this Duet input. Normally a logic 0 would be specified as being below some fixed voltage and a logic 1 would be defined as being above some fixed voltage.
                With a supply voltage of 3.3 it is possible that 2.1 (three diodes) would qualify as a logic 1.
                So we are only talking about two additional diodes.
                There is a type of diode called a zener which comes in different voltage ratings which could be used in your case to insure the input doesn't exceed a certain value.
                I saw an assortment on Amazon that had numerous low voltage devices:
                Chanzon 34 Values 0.5W Zener Diode Assorted Kit (2V 2.2V 2.4V 2.7V 3V 3.3V...) plus other much higher values. It was $7 for 34 diodes.
                If you didn't mind using an LED they have different forward voltage drops depending on color. I believe I have a batch of white ones rated at 3 volts.
                ? 1 Reply Last reply 23 Jul 2020, 20:55 Reply Quote 0
                  A Former User @fcwilt
                  (high side is MIN [2.0V, 0.7 × VDDIO])
                  undefined 1 Reply Last reply 23 Jul 2020, 21:02 Reply Quote 0
                    fcwilt @A Former User
                    Normally there would be two specs - one for a logic 0 and one for a logic 1.
                    Do you have a link to this info?
                      A Former User
                      page 1355
                      http://ww1.microchip.com/downloads/en/devicedoc/atmel-11157-32-bit-cortex-m4-microcontroller-sam4e16-sam4e8_datasheet.pdf
                      undefined 1 Reply Last reply 23 Jul 2020, 21:06 Reply Quote 0
                        page 1355
                        Thank you.
                          Leav
                          Solved it! Thanks everyone for your help and guidance.
                          For posterity, I ended up using a pull down resistor of 1.7K, which balances the effects of:
                          • pull up in sensor
                          • pull up in Duet
                          undefined 1 Reply Last reply 25 Jul 2020, 08:51 Reply Quote 0
                            dc42 administrators @Leav
                            That is the standard way to use a PNP-output sensor. It's the same as for a Z probe (see https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_PNP_output_normally_open_inductive_or_capacitive_sensor) except that you need a lower value pulldown resistor, because of the pullup resistor in the Duet.
                            The output of an NPN sensor can be connected directly to the endstop input on all modern Duets, and should work that way.
                            undefined 1 Reply Last reply 25 Jul 2020, 13:35 Reply Quote 0
                              Leav @dc42
                              @dc42 said in Endstop LED lighting, but DWC does not show them triggered:
                              If I understand correctly, I think I have a very weird "NPN-ish" sensor, since it has a pull-up internally. connecting it directly would connect 24v to the 3.3v rail, which I understand is not a good thing, even with all the resistors in the way.
                              29 out of 33
