    Duet Wifi 1.04 on Ender5,motor noise
    442
    • lui2004undefined
      lui2004
      Hi
      I have setup the Duet Wifi it on my Ender 5
      All motors are stock only the Extruder i have changes it to this one:
      https://www.amazon.de/gp/product/B07TXD7ZCF/ref=ppx_yo_dt_b_asin_title_o01_s01?ie=UTF8&psc=1
      before i home all axes is all quite and nice but after homing the motors are making to much noise, with my old board it was all quite.
      my config.g:
      M350 X16 Y16 Z16 E16 I1                 ; Configure microstepping with interpolation
      M92 X80.00 Y80.00 Z800.00 E411.53        ; Set steps per mm
      M566 X600.00 Y600.00 Z60.00 E300.00      ; Set maximum instantaneous speed changes (mm/min)
      M203 X30000.00 Y30000.00 Z500.00 E6000.00  ; Set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z200.00 E6000.00    ; Set accelerations (mm/s^2)
      M906 X580.00 Y650.00 Z580.00 E650.00 I10  ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30                                  ; Set idle timeout
      if you need more infos i will post
      thanks
      • JoergS5undefined
        JoergS5 @lui2004
        @lui2004 first guess is that your speed M203 X and Y is set too high (try 6000). You can analyze by running the printer a bit (while it's loud) and then make a M122 and look for the hiccups number. If it's high, you lost steps.
        The M906 currents for X and Y may be too low (try 50 - 80 % of stepper current), but this depends on the steppers. Do you have information on them or a type label?
        If there is another reason, it would be good if you post your complete config and homeall, and tell your firmware version.
        • lui2004undefined
          lui2004
          @JoergS5 said in Duet Wifi 1.04 on Ender5,motor noise:
          M122
          Hi
          the Motors for x,y and z are stock from Ender 5 only the Extruder motor was changed to this one:
          thats my firmware version:
          Board: Duet 2 WiFi (2WiFi)
          Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.1.1 (2020-05-19b2)
          Duet WiFi Server Version: 1.23
          M112:
          M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
          Board ID: 08DGM-917NK-F23T0-6JTD2-3S86S-KYBND
          Used output buffers: 3 of 24 (14 max)
          Static ram: 27980
          Dynamic ram: 93840 of which 44 recycled
          Exception stack ram used: 544
          Never used ram: 8664
          Tasks: NETWORK(ready,368) HEAT(blocked,1224) MAIN(running,1552) IDLE(ready,80)
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:00:55 ago, cause: power up
          Last software reset at 2020-07-24 22:31, reason: User, spinning module GCodes, available RAM 8736 bytes (slot 3)
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
          Error status: 0
          MCU temperature: min 28.4, current 31.6, max 31.8
          Supply voltage: min 24.2, current 24.4, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: standstill, SG min/max 0/232
          Driver 1: standstill, SG min/max 88/216
          Driver 2: standstill, SG min/max 0/312
          Date/time: 2020-07-25 08:54:29
          Cache data hit count 95067176
          Slowest loop: 4.60ms; fastest: 0.12ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 1.0ms, write time 0.0ms, max retries 0
          Hiccups: 0(0), FreeDm: 169, MinFreeDm: 167, MaxWait: 23772ms
          === MainDDARing ===
          Scheduled moves: 12, completed moves: 12, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
          === AuxDDARing ===
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 155.68ms; fastest: 0.00ms
          Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
          HTTP sessions: 1 of 8
          - WiFi -
          Network state is active
          WiFi firmware version 1.23
          WiFi MAC address 84:f3:eb:83:4f:81
          WiFi Vcc 3.45, reset reason Unknown
          WiFi flash size 4194304, free heap 23568
          WiFi IP address 192.168.2.112
          WiFi signal strength -68dBm, reconnections 0, sleep mode modem
          Config.g:
          ; generated by RepRapFirmware Configuration Tool v2 on Tue May 07 2019 23:06:50 GMT+0100 (British Summer Time)
          G90                                      ; Send absolute coordinates...
          M83                                      ; ...but relative extruder moves
          M550 P"Ender 5"                          ; Set machine name
          M552 S1                                  ; Enable network
          M587 S"WLAN-110995" P"39510069647710671890"                 ; Configure access point. You can delete this line once connected
          M586 P0 S1                               ; Enable HTTP
          M586 P1 S0                               ; Disable FTP
          M586 P2 S0                               ; Disable Telnet
          M569 P0 S1                               ; Physical drive 0 goes forwards
          M569 P1 S1                               ; Physical drive 1 goes forwards
          M569 P2 S0                               ; Physical drive 2 goes backwards
          M569 P3 S0                               ; Physical drive 3 goes forwards
          M208 X0 Y0 Z0 S1                         ; Set axis minima
          M208 X220 Y220 Z300 S0                   ; Set axis maxima
          M574 X1 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
          M574 Y1 S1 P"ystop"                            ; configure active-high endstop for low end on Y via pin ystop
          M574 Z1 S1 P"zstop"                            ; configure active-high endstop for low end on Z via pin zstop
          M558 PO H2 F120 T6000
          M557 X20:220 Y20:220 S65                       ; define mesh grid
          M376 H20
          M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
          M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
          M140 H0                                        ; map heated bed to heater 0
          M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
          M308 S1 P"e0temp" Y"thermistor" T100000 B3950  ; configure sensor 1 as thermistor on pin e0temp
          M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
          M307 H1 B0 S1.00
          M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
          M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
          M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
          M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
          M563 P0 D0 H1                            ; Define tool 0
          G10 P0 X0 Y0 Z0                          ; Set tool 0 axis offsets
          G10 P0 R0 S0                             ; Set initial tool 0 active and standby temperatures to 0C
          M501
          M575 P1 S1 B57600
          homeall:
          ; homeall.g
          ; called to home all axes
          G1 Z5 F6000 H2          ; lift Z relative to current position
          G1 H1 X-225 Y-225 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
          G1 X5 Y5 F6000          ; go back a few mm
          G1 H1 X-225 Y-225 F360  ; move slowly to X and Y axis endstops once more (second pass)
          G1 H1 Z-305 F1800       ; move Z down stopping at the endstop
          G90                     ; absolute positioning
          G92 Z0                  ; set Z to axis minimum (you may want to adjust this)
          ;G91                    ; relative positioning
          ;G1 S2 Z5 F100          ; lift Z relative to current position
          ;G90                    ; absolute positioning
          homex.g:
          ; homex.g
          ; called to home the X axis
          G1 H1 X-225 F1800 ; move quickly to X axis endstop and stop there (first pass)
          G1 X5 F6000       ; go back a few mm
          G1 H1 X-225 F360  ; move slowly to X axis endstop once more (second pass)
          G1 Z-5 F6000 H2   ; lower Z again
          homey.g:
          ; homey.g
          ; called to home the Y axis
          G1 H1 Y-225 F1800 ; move quickly to Y axis endstop and stop there (first pass)
          G1 Y5 F6000       ; go back a few mm
          G1 H1 Y-225 F360  ; move slowly to Y axis endstop once more (second pass)
          homez.g:
          ; homez.g
          ; called to home the Z axis
          G1 H1 Z-305 F1800 ; move Z down until the endstop is triggered
          G92 Z0            ; set Z position to axis minimum (you may want to adjust this)
          • lui2004undefined
            lui2004
            6000
            a little video:
            https://streamable.com/47zfq5
            • JoergS5undefined
              JoergS5 @lui2004
              @lui2004 did you try changing
              to
              M203 X6000.00 Y6000.00 Z500.00 E6000.00
              and then turn off/on printer to be sure the change is active?
              I don't see errors in M122 and config.
              • lui2004undefined
                lui2004
                yes i have changed the values but still the same with noise
                • JoergS5undefined
                  JoergS5 @lui2004
                  @lui2004 I watched the video with audio on now 😉
                  My impression is, the most noise don't come from the steppers, but the fans. It's difficult to decide. Probably after homing some fans are activated because something heats up (heatbreak fan eg).
                  Your trapezoid spindle for Z movement is black, this may be abrasive from some spindle nut or you needed lubrication. There may be too much friction between nut and spindle. This could produce noise also (and has the danger of slip-stick and inexact Z movement also). The coupler between stepper and spindle is of a type where the stepper and trapezoid axis must match exactly. Better would be dog clutch (Rotex coupler, Oldham). They are better than those aluminium coupler with horizontal gaps.
                    It's hard to tell from the video if it's fan noise or the motor idle noise. The creality motors are a bit noisier on the Duet I think. There is a bit more whine from them.
                    Current setting on the Duet 2 WiF/Ethernet is done in steps of 100mA and is rounded down. Current setting on the Duet Maestro is in steps of 50mA and rounded down.
                    https://duet3d.dozuki.com/Wiki/Gcode#Section_M906_Set_motor_currents
                    So keep that in mind when setting your currents.
                    You may find this helpful: https://duet3d.dozuki.com/Wiki/Reducing_Stand-Still_Noise
                    • lui2004undefined
                      lui2004
                      @Phaedrux said in Duet Wifi 1.04 on Ender5,motor noise:
                      this parameters are from marlin
                      so if i have the Duet wifi how to set up ? like this ?
                      M906 X480.00 Y550.00 Z480.00 E550.00 I10 ; Set motor currents (mA)
                      • JoergS5undefined
                        JoergS5 @lui2004
                        @lui2004 can you locate what is loud? X, Y, Z steppers or fans (and which fan)?
                        lui2004undefined 1 Reply Last reply Reply Quote 0
                          Those values will be rounded down to the nearest 100ma.
                          So this: M906 X480.00 Y550.00 Z480.00 E550.00
                          Will actually be this: M906 X400.00 Y500.00 Z400.00 E500.00
                          • lui2004undefined
                            lui2004 @JoergS5
                            @JoergS5
                            all motors
                            i will try this on monday: https://duet3d.dozuki.com/Wiki/Reducing_Stand-Still_Noise
                            • lui2004undefined
                              lui2004
                              Hi
                              the noise from the motors seems like rustle
