    Duet3+SBC print stops - DWC unresponsive -
    jubilee
    607
    • Carloundefined
      Carlo @BryanH
      @BryanH
      Hi out of interest if you reload the page does DWC control come back ?...not that this will fix your issue but may help point to it and you may then be able to M122
      Maybe something worth trying if it was to happens again.
        Post your config.g as well as M122 please.
        • BryanHundefined
          BryanH
          Page reloads did not work.
          Browser restart did not work.
          Browser cache clear and restart did not work.
          Power cycle of entire system required to regain access to DWC as stated in initial post.
          No errors recorded in eventlog.txt
          No errors recorded in console.
          DWC hung again - required reboot of pi to restore access
          m122
          RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode)
          Board ID: 08DJM-956L2-G43S4-6J9DL-3SJ6S-1866H
          Used output buffers: 1 of 40 (14 max)
          Static ram: 154604
          Dynamic ram: 163732 of which 20 recycled
          Exception stack ram used: 520
          Never used ram: 74340
          Tasks: NETWORK(ready,1972) HEAT(blocked,1088) CanReceiv(suspended,3420) CanSender(suspended,1428) CanClock(blocked,1436) TMC(blocked,68) MAIN(running,4936) IDLE(ready,76)
          Owned mutexes:
          Last reset 09:06:56 ago, cause: power up
          Last software reset at 2020-07-22 19:13, reason: User, spinning module LinuxInterface, available RAM 74300 bytes (slot 2)
          Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
          Error status: 0
          MCU temperature: min 18.1, current 39.6, max 41.1
          Supply voltage: min 23.9, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
          12V rail voltage: min 11.9, current 12.0, max 12.1, under voltage events: 0
          Driver 0: standstill, reads 26677, writes 27 timeouts 0, SG min/max 0/1023
          Driver 1: standstill, reads 26681, writes 23 timeouts 0, SG min/max 0/55
          Driver 2: standstill, reads 26678, writes 27 timeouts 0, SG min/max 0/1023
          Driver 3: standstill, reads 26678, writes 27 timeouts 0, SG min/max 0/1023
          Driver 4: standstill, reads 26679, writes 27 timeouts 0, SG min/max 0/1023
          Driver 5: standstill, reads 26679, writes 27 timeouts 0, SG min/max 0/1023
          Date/time: 2020-07-25 19:05:43
          Slowest loop: 10.81ms; fastest: 0.14ms
          === Storage ===
          Free file entries: 10
          Hiccups: 0(0), FreeDm: 375, MinFreeDm: 322, MaxWait: 3079109ms
          Bed compensation in use: mesh, comp offset 0.008
          === MainDDARing ===
          Scheduled moves: 45996, completed moves: 45996, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
          === AuxDDARing ===
          Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
          Heater 0 is on, I-accum = 0.1
          Segments left: 0
          Movement lock held by null
          HTTP* is ready with "M122" in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon* is idle in state(s) 0
          Aux2 is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 2.21ms; fastest: 0.01ms
          HTTP sessions: 0 of 8
          • Ethernet -
            State: disabled
            Error counts: 0 0 0 0 0
            === CAN ===
            Messages sent 175312, longest wait 2ms for type 6011
            === Linux interface ===
            State: 0, failed transfers: 0
            Last transfer: 17ms ago
            RX/TX seq numbers: 6486/19231
            SPI underruns 0, overruns 0
            Number of disconnects: 8
            Buffer RX/TX: 0/0-0
            === Duet Control Server ===
            Duet Control Server v3.1.1
            Code buffer space: 4096
            Full transfers per second: 29.63
          config.g
          • Wallyundefined
            Wally
            How are you powering the SBC (Raspberry Pi)?
            I saw similar happenings powering the Pi from the 6HC Main board. Changing the main board jumpers to not power the Pi and using a wall wart to power the Pi separately resolved my issues.
            BryanHundefined 1 Reply Last reply Reply Quote 0
            • HebigTundefined
              HebigT
              I had an issue like this that was caused by a poor ribbon cable connection between the Duet and Pi. It usually required that I reseat the cable before DWC would work again, but It was also somewhat unpredictable.
              I replaced the ribbon cable with some jumper wires and the issue hasn't returned.
              • BryanHundefined
                BryanH @Wally
                @Wally Pi is powered by the Duet3 per the documentation.
                Wallyundefined 1 Reply Last reply Reply Quote 0
                • Wallyundefined
                  Wally @BryanH
                  @BryanH Thanks for the details. Suggest changing your main board jumpers and power the Pi independently (separate power source like an AC adapter) to see if that helps resolve.
                  • BryanHundefined
                    BryanH
                    @Wally Thanks for the suggestion but I was really hoping for some diagnostics / troubleshooting. Does anyone know if we can connect the Pi to the Duet3 via USB while in operation to capture the debug output on the USB port? I've already set the DSF / DWC to debug logging and will be trying some increasingly longer prints to see if I can reproduce the issue.
                      Trying to power the pi separately might be worthwhile. It would be interesting to see if that helped or not.
                      It could also very likely be an issue with DSF. Duet3 + SBC is still one of the more cutting edge implementations.
                      You may be able to get some more info via this technique to enable debugging
                      https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Monitoring_optional
                      • BryanHundefined
                        BryanH
                        @Phaedrux Thanks for the info - I'm running the debug monitoring now - Found what looks like an out of memory dump in the Pi's logs at or about the time of the last failure - Should I post it here?
                        Thanks!
                          Phaedrux Moderator @BryanH
                          @BryanH said in Duet3+SBC print stops - DWC unresponsive -:
                          Sure.
                          • BryanHundefined
                            BryanH
                            JubileePiLogDump.txt
                              Thanks. Perhaps @chrishamm will be able to take a look.
                              • BryanHundefined
                                BryanH
                                Great, that's from the kernel log - I'm pulling the syslog to see if there's anything there.
                                • BryanHundefined
                                  BryanH
                                  Syslog with the observed issue https://drive.google.com/file/d/1qGrD7uS_jXZGs1kyyUrE6AGbiEL8Fvxc/view?usp=sharing
                                  • chrishammundefined
                                    chrishamm administrators
                                    Unfortunately there is no useful information in the logs you provided. Please start DuetControlServer with debug log level using a terminal on the Pi - just be aware that a print will be terminated once that is closed:
                                    sudo systemctl stop duetcontrolserver
                                    sudo /opt/dsf/bin/DuetControlServer -l debug
                                    I need to know what exactly is causing the hang. Did you observe any pattern when the hangs occurred? When it hangs, you should be able to run M122 "DSF" from the G-code console to get a diagnostics output only from DCS.
                                    If it really runs out of memory at some point, I need to reproduce that. Can you compress your system directory files plus the file you were trying to print?
                                    Duet software engineer
                                    • BryanHundefined
                                      BryanH
                                      Thank you, I'm running DCS in debug mode - and will be running jobs beginning tomorrow morning with the last jobs to see if I can reproduce the issue.
