    Troubleshooting dual z axis sync
    710
    • engikeneerundefined
      engikeneer
      @chuymatt how exactly does it move? What is it doing/not doing?
      When you connected the single motor to the Z-driver, did you put the jumpers on the other Z-header? There is a note about this on the duet wiring diagrams.
      Also have you checked that both motors work okay/are wired up correctly? Try plugging them in to different drivers and checking they spin etc.
      Do you get any errors come up when you try to move Z?
      i3 clone with a bunch of mods
      chuymattundefined 1 Reply Last reply Reply Quote 0
      • chuymattundefined
        chuymatt @JamesM
        @JamesM
        Would hat have made the y and x motors run hotter?
        I have changed to 16 with interp.
        Thanks!
        This is my first reprap firmware printer and only my second printer overall.
        • chuymattundefined
          chuymatt @fcwilt
          @fcwilt I was banging my head against the wall for a while trying to get the corexy movement correct and this was what seemed to make commands have the intended effect. I'll admit I was flailing with that section.
          • chuymattundefined
            chuymatt @JamesM
            @JamesM Oh. wow. So much faster. Also, homing is kinda scary now...
            JamesMundefined 1 Reply Last reply Reply Quote 0
            • chuymattundefined
              chuymatt @engikeneer
              @engikeneer
              Well... I moved on to the next aspect of my build after getting movement and the bltouch to work I neglected to put the jumpers back on. It is moving correctly now. Before, z1 was not moving anything. now they are both going at it.
              Rookie mistakes.
              • chuymattundefined
                chuymatt
                Now z homing does not work correctly. X slams into the non-triggered side and then pingpongs back and forth on the y axis while the z is raising up. Super weird.
                • fcwiltundefined
                  fcwilt @chuymatt
                  @chuymatt said in Troubleshooting dual z axis sync:
                  Well you've got two Z motors and a BLTouch - correct?
                  At one point in your config file you had two endstops for Z but now it is one.
                  Are you using end stops (either 1 or 2) for homing Z or are you using the BLTouch.
                  In your bed.g M401 and M402 appear with the comment to remove if using BLTouch?
                  Since you appear to be using a BLTouch you should remove them.
                  Please post your home*.g files.
                  • chuymattundefined
                    chuymatt @fcwilt
                    @fcwilt I am using the BL touch only.
                    Thank you for taking the time to help.
                    It no longer pingpongs.
                    All
                    0:/sys/homeall.g
                    ; homeall.g
                    ; called to home all axes
                    ; generated by RepRapFirmware Configuration Tool v3.1.3 on Wed Jun 24 2020 23:25:43 GMT-0700 (Pacific Daylight Time)
                    G91                   ; relative positioning
                    G1 H2 Z5 F18000        ; lift Z relative to current position
                    G1 H1 X-335 Y-335 F6000 ; move quickly to X or Y endstop and stop there (first pass)
                    G1 H1 X-335            ; home X axis
                    G1 H1 Y-335            ; home Y axis
                    G1 X5 Y5 F2800      ; go back a few mm
                    G1 H1 X-335 F360       ; move slowly to X axis endstop once more (second pass)
                    G1 H1 Y-335            ; then move slowly to Y axis endstop
                    G90                   ; absolute positioning
                    G1 X55 Y25 F27000      ; go to first bed probe point and home Z
                    G30                   ; home Z by probing the bed
                    ;G91                  ; relative positioning
                    ;G1 Z5 F100           ; lift Z relative to current position
                    ;G90                  ; absolute positioning
                    CoreXY
                    Send code...
                    Status
                    Idle
                    Mode: FFF
                    Tool Position
                    X
                    0.0
                    Y
                    0.0
                    Z
                    0.00
                    Extruder Drives
                    Drive 0
                    0.0
                    Speeds
                    Requested Speed
                    0 mm/s
                    Top Speed
                    0 mm/s
                    Sensors
                    Vin
                    23.9 V
                    MCU Temperature
                    38.0 C
                    Z-Probe
                    0
                     Tools
                     Extra
                     Control All
                    Tool	Heater	Current	Active	Standby
                    Hotend
                    T0 - Load Filament	Heater 1
                    active	207.9 C
                    205
                    0
                    Bed	Heater 0
                    active	45.2 C
                    60
                    0
                    Temperature Chart
                    System Directory
                    0:/sys/homex.g
                    ; homex.g
                    ; called to home the X axis
                    G1 H2 Z5 F6000   ; lift Z relative to current position
                    G1 H1 X-335 F1800 ; move quickly to X axis endstop and stop there (first pass)
                    G1 X5 F6000     ; go back a few mm
                    G1 H2 Z-5 F6000  ; lower Z again
                    0:/sys/homey.g
                    ; homey.g
                    ; called to home the Y axis
                    G1 H1 Y-335 F6000 ; move quickly to Y axis endstop and stop there (first pass)
                    G1 Y5 F6000     ; go back a few mm
                    G1 H1 Y-335 F360  ; move slowly to Y axis endstop once more (second pass)
                    ; homez.g
                    ; called to home the Z axis
                    G1 H2 Z5 F1000   ; lift Z relative to current position
                    G1 X100 Y-155 F1000 ; go to first probe point
                    • fcwiltundefined
                      fcwilt
                      Glad to hear it is work.
                      I assume you cleaned up the config.g file?
                      • JamesMundefined
                        JamesM @chuymatt
                        @chuymatt You need to adjust the steps/mm appropriately after changing the microstepping. That is probably why it's moving so fast. So X and Y should be set at 80 and Z at 400
                        • fcwiltundefined
                          fcwilt @JamesM
                          @JamesM said in Troubleshooting dual z axis sync:
                          If M92 appears before M350 and M92 contains the correct values for 16x micro-stepping then any needed adjustments will be made for the values used in M350 if for some reason they are other than 16x micro-stepping.
