    Not a Duet question, large print surface question
    754
    • chas2706undefined
      chas2706
      FYI If you have DC42's infrared zprobe, choose the matt black option. I guarantee it works a treat!
      • Hytekundefined
        Hytek
        I use a BLtouch at the moment, would have chose matt black option anyway.
        Just looked again and only goes to 500x500, might have sold out of larger sizes
        • chas2706undefined
          chas2706
          @Hytek said in Not a Duet question, large print surface question:
          O.o that's the exact site I looked up. Got to 500x500 then went round. Might have to Email them.
          Glad to help. I just gone to their website and found at the moment are only advertising up to 500 x 500 but they definately do bigger.
          • Hytekundefined
            Hytek
            I'll send them an email tomorrow. Could end up back to Buildtak, they do a 609x609. Not gonna cry for 1x1mm
            • chas2706undefined
              chas2706
              Have you tried searching for the two part magnetic surface in that size. I got one on one of my ender 3 pro's and you just lift the upper surface off to easily pull the print off.
              Hytekundefined 1 Reply Last reply Reply Quote 0
              • Hytekundefined
                Hytek @chas2706
                @chas2706 Yes, about a month ago I contacted Wham Bam and they said:
                Their system sounds good & well priced comparatively. Unfortunately they still don't offer any bigger than 500x500
                • Hytekundefined
                  Hytek
                  Just an update on this topic. The only place I have had any luck so far is on AliExpress. Though they do not list the size I required they were more than happy to accommodate. The process to finally order is a bit of a PITA as it is not a stock line in their store.
                  https://a.aliexpress.com/_dSRK8LJ?spm=a2g0s.imconversation.0.0.209a3e5fIe2hQc
                  I ended up purchasing 3 of these to get one complete set plus a spare print surface. This came to round figures $200 AUD which I think equates to $4 USD 🤥
                  Anyway, hope this will help someone else who has a large printer
                  Corexyundefined 1 Reply Last reply Reply Quote 0
                  • Corexyundefined
                    Corexy @Hytek
                    I've heard good things about this sellers build plates and his service, and am looking at one of these in 400x400 for my own upcoming build.
                    It will be good to hear how it works out for you.
                    • Hytekundefined
                      Hytek @Corexy
                      @Corexy As soon as I have a chance to test it I will update the post. Options seem to be pretty limited for larger format printers at the moment. Kind of a case of take what you can get.
                      • Corexyundefined
                        Corexy @Hytek
                        I'm kind of wishing I went with 300x300, but I did pull it up at 400x400 for just that reason.
                        Heater mats jump right up in price too.
                        • Hytekundefined
                          Hytek @Corexy
                          @Corexy 500x500 seems not TOO hard to find, even Wham Bam has a 500 available. Over that is a PITA to find anything for, especially if you don't want to pay $500
                          • Hytekundefined
                            Hytek
                            Magnetic print surface arrived today, looks good except for the damaged corner from shipping. It was packaged well so I guess one of the handlers thought it was a giant frizbee 😠
                            Once I get this straightened out (no pun intended) I have a decision to make, which I would appreciate any advice. Right now I have an 8mm aluminium bed with a buildtak surface on. The buidtak surface is in good condition except a small chip which I normally dodge in the slicer. Can't decide if I should say goodbye to the buildtak surface and apply the magnetic sticker directly to the aluminium plate or attach it to a piece of glass. Any thoughts?
                            Thanks in advance
                            • oliofundefined
                              oliof
                              attach it directly to the aluminum.
                              • Hytekundefined
                                Hytek @oliof
                                @oliof Yeah I figured that was going to be the best answer. Thanks for the reply
