    Short to ground on drivers 0123
    63
    2.7k
    • Touchthebitumundefined
      Touchthebitum @droftarts
      @droftarts
      same results ... error on driver 0 and 1
      It's a nightmare
      I can't post anything since I don't have ethernet connection
      Sparkcube XL V 1.1 300x300x190, Radds, Raspberry, Keenovo silicone bedheat 220v, Big Booster Extruder, DIY building
      BLV Cube 665mm Direct Drive with Duet3/SBC (RPi 4) Mosquito Magnum/Bond Tech Extruder/Vanadium Nozzle, Keenovo silicone bedheat 220v
        A Former User @Touchthebitum
        @Touchthebitum said in Short to ground on drivers 0123:
        to the board in stand alone mode?
        Touchthebitumundefined 1 Reply Last reply Reply Quote 0
          Touchthebitum @A Former User
          @bearer
          No, I'm far from a router
            @bearer
            you can do all the tests over usb serial interface, or a direct (ethernet) connection to your computer with static ip addresses on both duet and computer when duet is in stand alone mode.
              @bearer
              Ok, what do you need as info or tests ?
                i suspect should repeat all the steps you did diagnosing the old board to see if the error persist when using the Duet as a stand alone board.
                you could also configure your raspberry pi to be a wifi to ethernet bridge , but imho its easier to set a static up for a direct ethernet connection but all three options would work.
                  @bearer
                  I have a connected laptop to my board but I don't know ho to connect
                    This is perplexing.
                    • Are there any other connectors in the leads that connect the motors to the Duet? If so, please post a photo of them.
                    • Please post a photo of the stepper motor wires where they go into the motor.
                    • Please use your multimeter to check that there is no continuity between any of the motor wires and the body of the motor.
                    • Use your multimeter to check that with the connectors fitted, the resistance across each phase is as expected (a few ohms, not a short circuit) and there is no continuity between the two motor phases. Your multimeter probes should be able to fit in the slots in the connector shells in order to make contact with the crimp pins inside.
                      A Former User
                      to set a static IP address on the Duet, you have two options, config.g or USB. Both cases involves M552 S1 P192.168.1.14 as shown in https://duet3d.dozuki.com/Wiki/Gcode#Section_M552_Set_IP_address_enable_disable_network_interface
                      then you need to configure the correct network interface for the computer to use an address in the same network range. probably best to ask google how to do this for your operating system and version/language.
                      if you use the example above for the duet, set the PC to be IP address 192.168.1.15 with netmask 255.255.255.0 and leave the other settings blank or at their defaults.
                      if you have trouble with the computer let us know what operating system/version/language it is and maybe someone can help
                        Touchthebitum @dc42
                        • No, it is direct wire from motor to the board
                        • motor connector.jpg list item
                        • I checked 10x and there is no continuity, resistance is ok
                        • I tested the motors plugged with the multimeter and it is the same result like unplugged
                        • no short between motor case and plugs
                          @bearer
                          Thanks, I used usb to make tests.
                          First test : psu on, no connected motors, no movements:
                          m122
                          RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (standalone mode)
                          Board ID: 08DJM-956L2-G43S8-6JKD6-3SJ6L-KA02G
                          Used output buffers: 1 of 40 (21 max)
                          Static ram: 154604
                          Dynamic ram: 162384 of which 44 recycled
                          Exception stack ram used: 308
                          Never used ram: 75876
                          Tasks: ETHERNET(blocked,472) NETWORK(ready,244) HEAT(blocked,1200) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,204) MAIN(running,4628) IDLE(ready,76)
                          Owned mutexes:
                          Last reset 00:14:54 ago, cause: power up
                          Last software reset at 2020-08-02 08:21, reason: User, spinning module LinuxInterface, available RAM 75776 bytes (slot 1)
                          Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0443c000 BFAR 0x00000000 SP 0xffffffff Task MAIN
                          Error status: 0
                          MCU temperature: min 30.0, current 30.7, max 30.7
                          Supply voltage: min 0.2, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                          12V rail voltage: min 0.1, current 12.1, max 12.4, under voltage events: 0
                          Driver 0: standstill, reads 42573, writes 11 timeouts 0, SG min/max 0/0
                          Driver 1: standstill, reads 42573, writes 11 timeouts 0, SG min/max 0/0
                          Driver 2: standstill, reads 42574, writes 11 timeouts 0, SG min/max 0/0
                          Driver 3: standstill, reads 42574, writes 11 timeouts 0, SG min/max 0/0
                          Driver 4: standstill, reads 42575, writes 11 timeouts 0, SG min/max 0/0
                          Driver 5: standstill, reads 42576, writes 11 timeouts 0, SG min/max 0/0
                          Date/time: 2020-08-02 21:35:01
                          Slowest loop: 4.89ms; fastest: 0.16ms
                          === Storage ===
                          Free file entries: 10
                          SD card longest read time 2.6ms, write time 0.0ms, max retries 0
                          === MainDDARing ===
                          Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                          === AuxDDARing ===
                          Segments left: 0
                          Movement lock held by null
                          HTTP is idle in state(s) 0
                          Telnet is idle in state(s) 0
                          File is idle in state(s) 0
                          USB is idle in state(s) 0
                          Aux is idle in state(s) 0
                          Trigger is idle in state(s) 0
                          Queue is idle in state(s) 0
                          LCD is idle in state(s) 0
                          SBC is idle in state(s) 0
                          Daemon is idle in state(s) 0
                          Aux2 is idle in state(s) 0
                          Code queue is empty.
                          === Network ===
                          Slowest loop: 5.26ms; fastest: 0.03ms
                          HTTP sessions: 1 of 8
                          • Ethernet -
                            State: active
                            Error counts: 0 0 0 0 0
                            === CAN ===
                            Messages sent 344, longest wait 0ms for type 0
                            === Linux interface ===
                            State: 0, failed transfers: 0
                            Last transfer: 894436ms ago
                            RX/TX seq numbers: 0/1
                            SPI underruns 0, overruns 0
                            Number of disconnects: 0
                            Buffer RX/TX: 0/0-0
                          Second test : psu on, no connected motors, movement on x through the panel Due:
                          Error: short-to-ground reported by driver(s) 0 1
                          8/2/2020, 9:36:51 PM Error: short-to-ground reported by driver(s) 0 1
                          8/2/2020, 9:36:47 PM m122
                          Used output buffers: 1 of 40 (22 max)
                          Static ram: 154604
                          Tasks: ETHERNET(blocked,436) NETWORK(ready,244) HEAT(blocked,1188) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1424) TMC(blocked,60) MAIN(running,4628) IDLE(ready,76)
                          Owned mutexes:
                          Last reset 00:16:39 ago, cause: power up
                          Error status: 0
                          MCU temperature: min 30.6, current 31.9, max 32.0
                          Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                          12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
                          Driver 0: short-to-ground standstill, reads 56010, writes 3 timeouts 0, SG min/max 0/8
                          Driver 1: short-to-ground standstill, reads 56009, writes 3 timeouts 0, SG min/max 0/8
                          Driver 2: standstill, reads 56013, writes 0 timeouts 0, SG min/max not available
                          Driver 3: standstill, reads 56012, writes 0 timeouts 0, SG min/max not available
                          Driver 4: standstill, reads 56013, writes 0 timeouts 0, SG min/max not available
                          Driver 5: standstill, reads 56013, writes 0 timeouts 0, SG min/max not available
                          Date/time: 2020-08-02 21:36:46
                          Slowest loop: 17.09ms; fastest: 0.21ms
                          === Storage ===
                          SD card longest read time 2.3ms, write time 12.3ms, max retries 0
                          Hiccups: 0(0), FreeDm: 375, MinFreeDm: 373, MaxWait: 984672ms
                          === MainDDARing ===
                          Scheduled moves: 1, completed moves: 1, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                          === AuxDDARing ===
                          Segments left: 0
                          === Network ===
                          Slowest loop: 19.59ms; fastest: 0.03ms
                          • Ethernet -
                            State: active
                            === CAN ===
                            Messages sent 422, longest wait 0ms for type 0
                            Last transfer: 999813ms ago
                            droftarts administrators @Touchthebitum
                            @Touchthebitum rather than using the PanelDue (try with it disconnected in case it’s causing the problem), send Gcode moves via USB. First set a position for the X and Y axis with G92 X0 Y0, then send G1 X10 F300. You will need motors connected to driver 0 and 1, or you’ll get an error.
                            Guide to setting up direct Ethernet connection here: https://duet3d.dozuki.com/Wiki/Setting_up_networking_on_Duet#Section_Wired_direct_connection
                            Edit: when the PanelDue is sending commands, they should be echoed on the USB (I think). If so, what command is being sent to move X?
                            Touchthebitumundefined 2 Replies Last reply Reply Quote 0
                              dc42 administrators @Touchthebitum
                              @Touchthebitum, thanks for answering my previous questions. Two more:
                              • what is the stepper motor model number?
                              • what resistance do you measure across each phase?
                                Touchthebitum @dc42
                                Motors are Blurolls 17HM19-2004S
                                I get 1.7 (stabilised) as resistance on every motor on both phase
                                I'll execute tests this morning
                                  @droftarts said in Short to ground on drivers 0123:
                                  G1 X10 F300
                                  No Panel Due Ethernet connection
                                  G92 X0 Y0
                                  G1 X10 F300
                                  03/08/2020 à 15:04:54 m122
                                  Used output buffers: 2 of 40 (11 max)
                                  Static ram: 154604
                                  Exception stack ram used: 272
                                  Never used ram: 75912
                                  Tasks: ETHERNET(blocked,436) NETWORK(ready,388) HEAT(blocked,1188) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1424) TMC(blocked,204) MAIN(running,4656) IDLE(ready,76)
                                  Owned mutexes:
                                  Last reset 00:02:33 ago, cause: power up
                                  Error status: 0
                                  MCU temperature: min 22.7, current 32.1, max 32.2
                                  Driver 0: short-to-ground standstill, reads 44551, writes 14 timeouts 0, SG min/max 0/8
                                  Driver 1: short-to-ground standstill, reads 44552, writes 14 timeouts 0, SG min/max 0/8
                                  Driver 2: standstill, reads 44556, writes 11 timeouts 0, SG min/max 0/0
                                  Driver 3: standstill, reads 44557, writes 11 timeouts 0, SG min/max 0/0
                                  Driver 4: standstill, reads 44558, writes 11 timeouts 0, SG min/max 0/0
                                  Driver 5: standstill, reads 44558, writes 11 timeouts 0, SG min/max 0/0
                                  Date/time: 2020-08-03 15:04:53
                                  Slowest loop: 29.12ms; fastest: 0.14ms
                                  === Storage ===
                                  SD card longest read time 2.3ms, write time 23.8ms, max retries 0
                                  Hiccups: 0(0), FreeDm: 375, MinFreeDm: 373, MaxWait: 134960ms
                                  === MainDDARing ===
                                  === AuxDDARing ===
                                  Segments left: 0
                                  === Network ===
                                  Slowest loop: 28.84ms; fastest: 0.01ms
                                  • Ethernet -
                                    State: active
                                    === CAN ===
                                    Messages sent 613, longest wait 0ms for type 0
                                    Last transfer: 153531ms ago
                                    Buffer RX/TX: 0/0-0
                                  I don't see anything regarding echo on the command
                                    @droftarts
                                    Hello
                                    Same results with YAT and USB commands without connected Panel Due. Error short on driver 0 1 ...
                                    I don't know what to say anymore....
                                      T3P3Tony administrators
                                      @Touchthebitum please email me info@duet3d.com and I will arrange a return directly
