    PrusaSlicer with enhanced precision and removal of odd flow math
    37
    3.6k
    • chas2706undefined
      chas2706
      @bot Yes I have the latest version of PS already installed but it still doesn't work.
      • chas2706undefined
        chas2706
        Forgot to mention, I also already have the Microsoft 2015 redistributable update installed on my system.
        • botundefined
          bot
          I wish I could help more but I do not have any idea why there is an issue.
          What version of windows are you using?
          *not actually a robot
          • chas2706undefined
            chas2706
            Windows 10 version 1909.
            • botundefined
              bot
              I just tested on my laptop with Windows 1903 and it worked. Can you try just putting that file into the directory? Search your computer for the missing dll file and drop it into the directory if you find it.
              • chas2706undefined
                chas2706
                I can only find vcruntime140.dll, windows is looking for vcruntime140_1.dll.
                vcruntime140.dll is in my prusaslicer folder!
                • botundefined
                  bot @chas2706
                  Here is the copy of the DLL from my computer.
                  Rename this from .stl to .dll
                  vcruntime140_1.STL
                  • chas2706undefined
                    chas2706
                    @bot said in PrusaSlicer with enhanced precision and removal of odd flow math:
                    Cheers, it is now working!
                    • NickNonsenseundefined
                      NickNonsense
                      Weird but when i open "prusa-slicer.exe" it opens but hangs immediately. As soon as i try and click anything i have a (Not Responding) error.
                      Anyone else have this issue?
                      • botundefined
                        bot @NickNonsense
                        That’s odd. What version of windows do you have?
                        • botundefined
                          bot
                          Okay, so I might have got ahead of myself when I said increasing the X/Y precision of GCode decimal output "completely alleviated" the inconsistent extrusion rate. It did that for many of the paths, especially the perimeters. However, parts of the infill are still erroneously inconsistent (to a fairly small degree).
                          So, I will seek to fix this. All of the different types of infill, and infill in general, have their own sections of code which seem to mess about with the flow rate and spacing as they see fit.
                          // calculate actual flow from spacing (which might have been adjusted by the infill
                          // pattern generator)
                          // if we used the internal flow we're not doing a solid infill
                          // so we can safely ignore the slight variation that might have
                          // been applied to f->spacing
                          I'll need to go through them all and see how I can ensure the same consistency in the flow rate calculation as the other paths.
                          [Edit: well, I got ahead of myself again! The error was in my spreadsheet, not the infill output! The infill extrusion rates are not quite as consistent as the perimeters, but they are definitely close enough! Teaches me to debug using manual calculations and crude spreadsheets rather than unit tests.]
                          • matt3oundefined
                            matt3o
                            this is very interesting, following this thread.
                            I'll have a look at your code soon and possibly compile it on Linux.
                            Keep up with the good work
                            • botundefined
                              bot @matt3o
                              Cool! Let me know how it goes with Linux. I've only tested this on Windows. There shouldn't be any changes that would interfere with a linux build, but who knows!
                              Exerqtorundefined 1 Reply Last reply Reply Quote 1
                              • Exerqtorundefined
                                Exerqtor @bot
                                @bot have you ran this by Merill on github regarding merging it to SuperSlicer ?
                                botundefined zaptaundefined 2 Replies Last reply Reply Quote 0
                                • botundefined
                                  bot @Exerqtor
                                  I know for sure he is against removing the flow math. He seemed quite angry at my first suggestion of it. 😛
                                  The other changes I have mentioned to him in passing. He says he has played with the RESOLUTION setting (the one I changed from 0.0125 to 0.001 -- thanks to @Edgars-Batna for tipping me off about that change. He is what started this rabbit hole I'm digging!) But I guess he says he "changed too much" and was having stability issues. He may try changing that again. That single change is good enough for most people.
                                  The decimal precision of GCode output isn't exactly necessary, except to "extract" the maximum accuracy and precision from the calculations. If slic3r was just modified to calculate extrusion based off the rounded X/Y points, the added decimal output would not be useful at all.
                                  But yeah, the flow math? I doubt he will remove that. I don't know if it has much effect except for the nagging feeling in the back of some people's minds that they can't directly control extrusion width. 😛
                                  theruttmeisterundefined 1 Reply Last reply Reply Quote 1
                                  • zaptaundefined
                                    zapta @Exerqtor
                                    @Exerqtor said in PrusaSlicer with enhanced precision and removal of odd flow math:
                                    Or the Super Slicer Plus. 😉
                                    BTW, if you increase the resolution in the gcode file, don't you hit the resolution limits of the printer? (discrete steps, play/backlash, etc).
                                    • botundefined
                                      bot @zapta
                                      @zapta said in [PrusaSlicer with enhanced precision
                                      BTW, if you increase the resolution in the gcode file, don't you hit the limits of the resolution of the printer? (discrete steps, play/backlash, etc).
                                      I think even without increasing resolution, we already reach the limits of the printer. The purpose of the increased resolution is really only for testing purposes, to see if having more consistent calculations helps certain hiccups I'm seeing in certain prints.
                                      Basically, I believe RRF and most other firmwares will calculate the extrusion rate based off the gcode. If the gcode is not providing consistent results of those calculations, due to limited precision of values (and some of the values being calculated from higher precision numbers) there may be an issue. I might be entirely wrong, but this is what I'm testing.
                                      I don't really care about increased precison, per se, beyond 3 decimal digits for X/Y and 6 decimal digits for E. I just increased them in order to extract that higher calculated precision.
                                      • UnderDoneSushiundefined
                                        UnderDoneSushi
                                        Hey bot, would this odd flow math be the cause for my problem?
                                        When changing layer heights from 0.2mm to 0.1mm, the first layer extrusion width doesn't stay the same. For example, I have the first layer set to 275% for 0.2mm but when I change to 0.1mm I have to bump it up to 400% to get a "large" first layer. I hope that makes sense...
                                        • botundefined
                                          bot @UnderDoneSushi
                                          Yes, that is exactly the type of thing this flow math changed.
                                          It literally sets the width of an extrusion based on the height of the layer. If the layer height changes, the extrusion width changes.
                                          UnderDoneSushiundefined 1 Reply Last reply Reply Quote 0
                                            UnderDoneSushi @bot
                                            @bot I literally was so confused when I first started using PrusaSlicer. You can clearly see the extrusion width change when you re-slice a model. I will read your entire thread and try your branch/edit of the software and report back!
                                            engikeneerundefined 1 Reply Last reply Reply Quote 1
