    PS_ON not working?
    2.1k
    • joehsmashundefined
      joehsmash
      i have also measured with my meter, that i currently have 3.3v on the PSON connector that is feeding onto the DUET. i assumed that the duet would just ground that pin. but irregardless of m command it still retains the 3.3v.
      i also found a note in the forum from one of the duet employees that the GND isnt required so i have since removed it.
        joehsmash
        here is a copy of my config.g
        ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu May 07 2020 17:04:03 GMT-0600 (Mountain Daylight Time)
        M80 ; Turns on the ATX power supply
        M81 ; Turns off the ATX power supply
        M550 P"JoehBo3D" ; set printer name
        M552 S1 ; enable network
        M586 P0 S1 ; enable HTTP
        M586 P1 S0 ; disable FTP
        M586 P2 S0 ; disable Telnet
        M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm
        M566 X1020.00 Y1020.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
        M201 X9000.00 Y9000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
        M84 S30 ; Set idle timeout
        M208 X228 Y254 Z203 S0 ; set axis maxima
        M558 P1 H5 F-120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
        G31 P500 X-24 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
        M106 P0 S0 I0 F500 H1 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
        M106 P1 S1 I0 F500 H1:1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
        ; Custom settings
        Topherundefined 1 Reply Last reply Reply Quote 0
        • Topherundefined
          Topher @joehsmash
          @joehsmash according to your config.g your supply turns on then the next line it turns off
          joehsmashundefined 1 Reply Last reply Reply Quote 0
            joehsmash @Topher
            @LeckieTech good catch, it still doesnt activate the psu tho 😞
            Topherundefined 2 Replies Last reply Reply Quote 0
            • Topherundefined
              Topher @joehsmash
              @joehsmash With that output, you can't really read it with a voltmeter unless you add a pull-up resistor. You could use any resistor you have between 1k-100k ohms and pull up to 5 volts.
              Send M81 - you should read 5 volts on the middle pin.
              Send M80 - you should read 0 volts on the middle pin.
              (sorry for the horrible drawing)
              • Topherundefined
                Topher @joehsmash
                @joehsmash I suspect that the output is working but isn't one of 2 things.
                1. on the same ground plane as the PSU
                2. not providing a strong enough ground to the PSU
                  joehsmash
                  I didnt test the board, i tested the voltage of the pson of the psu to which i have 3.3v
                    joehsmash @Topher
                    @LeckieTech i had a ground hooked up to the gnd pin on that header and it still didnt work. So i doubt that its a grounding issue. At least initially.
                      joehsmash @joehsmash
                      @LeckieTech so if i understand you correctly, you want me to pull 5v from the fan header and send it over to the pson pin through a resistor than from the pson to the meter and back to ground?
                      • jjuuzziiundefined
                        jjuuzzii
                        Did anybody find a solution ?
                        I got the same Problem!!
                        • mitchundefined
                          mitch
                          @jjuuzzii , I wired up my soft power control a little different.
                          https://www.randoprojects.com/2020/07/30/duet-2-soft-power-control/
                          What kind of PSU are you using?
