    PS_ON not working?
    2.1k
    • joehsmashundefined
      joehsmash @joehsmash
      i will try to redo the connectors tomorrow morning
        T3P3Tony administrators
        Hi @joehsmash thanks, looks correctly wired like this:
        32f4d43e-9a50-4dd8-83a6-9d905b17aed8-image.png .
        Assuming that wiring worked previously (the 5V SB goes to the correct place?) then it should work. please can you share your config.g just in case there is something odd going on that is interfering with M80/M81. Also please try the following tests:
        1. Once started up send M98 P"/sys/config.g" to run config.g again. sometimes errors in the config file are not reported in the console during startup so this will run it again and report any errors.
        2. send M122 and post the results here, see if they are any different before/after the M80 command
        P.S. You can cut and paste images into your post or use the "upload image" button to attach images.
        joehsmashundefined 2 Replies Last reply Reply Quote 0
          joehsmash @T3P3Tony
          @T3P3Tony here is my M122
          M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
          Board ID: 08DLM-996RU-N8PS4-7JKDA-3S86M-9BAZN
          Used output buffers: 3 of 24 (17 max)
          Static ram: 25712
          Dynamic ram: 93140 of which 0 recycled
          Exception stack ram used: 392
          Never used ram: 11828
          Tasks: NETWORK(ready,764) HEAT(blocked,904) MAIN(running,3824) IDLE(ready,160)
          Owned mutexes:
          Last reset 01:44:08 ago, cause: power up
          Last software reset at 2020-05-05 21:39, reason: User, spinning module GCodes, available RAM 11836 bytes (slot 1)
          Error status: 0
          Free file entries: 10
          MCU temperature: min 32.2, current 32.6, max 32.8
          Supply voltage: min 2.0, current 2.0, max 6.5, under voltage events: 0, over voltage events: 0, power good: no
          Driver 0: ok, SG min/max not available
          Driver 1: ok, SG min/max not available
          Driver 2: ok, SG min/max not available
          Driver 3: ok, SG min/max not available
          Driver 4: ok, SG min/max not available
          Date/time: 2020-05-06 15:21:01
          Slowest loop: 5.34ms; fastest: 0.05ms
          Hiccups: 0, FreeDm: 160, MinFreeDm: 159, MaxWait: 7ms
          === DDARing ===
          Scheduled moves: 10, completed moves: 10, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
          Heater 0 is on, I-accum = 0.1
          Heater 1 is on, I-accum = 0.0
          Segments left: 0
          Movement lock held by null
          http is idle in state(s) 0
          telnet is idle in state(s) 0
          file is idle in state(s) 0
          serial is idle in state(s) 0
          aux is idle in state(s) 0
          daemon is idle in state(s) 0
          queue is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 201.13ms; fastest: 0.08ms
          HTTP sessions: 1 of 8
          • WiFi -
            Network state is running
            Failed messages: pending 0, notready 0, noresp 2
            WiFi firmware version 1.23
            WiFi MAC address bc:dd:c2:2d:64:61
            WiFi Vcc 3.38, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 23184
            WiFi IP address 192.168.1.44
            WiFi signal strength -42dBm, reconnections 0, sleep mode modem
          it appears that i was using the stock connectors on the end stops and as such were wired up in 3.3v to gnd positions.
          i remade the connectors appropriately and the end stops are no longer causing me an issue.
          still have the PSON issue, but i have circumvented that by just shorting it on all the time now. i will come back to this one.
          current issue is VIN not in spec?
          joehsmashundefined 1 Reply Last reply Reply Quote 1
            @T3P3Tony It looks like i have a blown fuse on my board.
            the 7.5a mini blade fuse blew. i wonder what would have caused that. i know i head a kind of pop when i tried to turn on my hotend.
            im not sure what would have caused it if it was the hot end, i just replaced the heater, and the thermistor. i also have replaced the line going straight back to the duet. there's only one connector just before the hot end if i ever need to disconnect it.
              dc42 administrators @joehsmash
              @joehsmash said in PS_ON not working?:
              Most likely you has a short circuit in the hot end heater or in the wiring to it.
              joehsmashundefined 1 Reply Last reply Reply Quote 0
                joehsmash @dc42
                yes i discovered last night after i ripped my printer appart that there was indeed a short between the hotend wire and the heater cartridge. some kapton and a some silicone sleeves and all is well there!
                  joehsmash @T3P3Tony
                  @T3P3Tony i feel like im getting pretty close, i have come back to the original issue here is my M122 pre M80
                  M122
                  Used output buffers: 3 of 24 (15 max)
                  Static ram: 25712
                  Exception stack ram used: 384
                  Never used ram: 11836
                  Tasks: NETWORK(ready,628) HEAT(blocked,1232) MAIN(running,3752) IDLE(ready,160)
                  Owned mutexes:
                  Last reset 00:08:16 ago, cause: power up
                  Last software reset at 2020-05-07 00:48, reason: User, spinning module GCodes, available RAM 11780 bytes (slot 1)
                  Error status: 0
                  Free file entries: 9
                  MCU temperature: min 29.9, current 30.3, max 30.5
                  Supply voltage: min 0.6, current 0.7, max 0.7, under voltage events: 1, over voltage events: 0, power good: no
                  Date/time: 2020-05-07 16:34:14
                  Cache data hit count 1617214182
                  Slowest loop: 1.16ms; fastest: 0.05ms
                  Hiccups: 0, FreeDm: 158, MinFreeDm: 158, MaxWait: 0ms
                  === DDARing ===
                  Scheduled moves: 4, completed moves: 3, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                  Segments left: 0
                  Stack records: 1 allocated, 1 in use
                  Movement lock held by http
                  http is idle in state(s) 1 8
                  === Network ===
                  Slowest loop: 201.11ms; fastest: 0.08ms
                  • WiFi -
                    Failed messages: pending 0, notready 0, noresp 1
                    WiFi flash size 4194304, free heap 23112
                    WiFi signal strength -45dBm, reconnections 0, sleep mode modem
                  and here it is post M80
                  M122
                  Static ram: 25712
                  Owned mutexes:
                  Last reset 00:10:46 ago, cause: power up
                  Error status: 0
                  MCU temperature: min 30.1, current 30.8, max 30.8
                  Date/time: 2020-05-07 16:36:45
                  Cache data hit count 2209121988
                  Slowest loop: 2.06ms; fastest: 0.05ms
                  Hiccups: 0, FreeDm: 160, MinFreeDm: 158, MaxWait: 0ms
                  === DDARing ===
                  Scheduled moves: 4, completed moves: 4, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                  Segments left: 0
                  === Network ===
                  Slowest loop: 202.11ms; fastest: 0.08ms
                  • WiFi -
                    WiFi Vcc 3.39, reset reason Turned on by main processor
                    WiFi flash size 4194304, free heap 21648
                    WiFi signal strength -44dBm, reconnections 0, sleep mode modem
                  not much has changed
                    joehsmash
                    i cant find any reference to M80/81 in the config.g file, and i dont see it defined any where else,
                      joehsmash
                      i have now added the M80/81 commands at the beginning of the config.g and again no change
                      M80 ; Turns on the ATX power supply
                      M81 ; Turns off the ATX power supply
                        joehsmash
                        i have also measured with my meter, that i currently have 3.3v on the PSON connector that is feeding onto the DUET. i assumed that the duet would just ground that pin. but irregardless of m command it still retains the 3.3v.
                        i also found a note in the forum from one of the duet employees that the GND isnt required so i have since removed it.
                          joehsmash
                          here is a copy of my config.g
                          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu May 07 2020 17:04:03 GMT-0600 (Mountain Daylight Time)
                          M550 P"JoehBo3D" ; set printer name
                          M552 S1 ; enable network
                          M586 P0 S1 ; enable HTTP
                          M586 P1 S0 ; disable FTP
                          M586 P2 S0 ; disable Telnet
                          M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm
                          M566 X1020.00 Y1020.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
                          M201 X9000.00 Y9000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
                          M84 S30 ; Set idle timeout
                          M208 X228 Y254 Z203 S0 ; set axis maxima
                          M558 P1 H5 F-120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
                          G31 P500 X-24 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
                          M106 P0 S0 I0 F500 H1 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                          M106 P1 S1 I0 F500 H1:1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                          ; Custom settings
                          Topherundefined 1 Reply Last reply Reply Quote 0
                          • Topherundefined
                            Topher @joehsmash
                            @joehsmash according to your config.g your supply turns on then the next line it turns off
                              joehsmash @Topher
                              @LeckieTech good catch, it still doesnt activate the psu tho 😞
                              Topherundefined 2 Replies Last reply Reply Quote 0
                              • Topherundefined
                                Topher @joehsmash
                                @joehsmash With that output, you can't really read it with a voltmeter unless you add a pull-up resistor. You could use any resistor you have between 1k-100k ohms and pull up to 5 volts.
                                Send M81 - you should read 5 volts on the middle pin.
                                Send M80 - you should read 0 volts on the middle pin.
                                (sorry for the horrible drawing)
                                • Topherundefined
                                  Topher @joehsmash
                                  @joehsmash I suspect that the output is working but isn't one of 2 things.
                                  1. on the same ground plane as the PSU
                                  2. not providing a strong enough ground to the PSU
                                    joehsmash
                                    I didnt test the board, i tested the voltage of the pson of the psu to which i have 3.3v
                                      joehsmash @Topher
                                      @LeckieTech i had a ground hooked up to the gnd pin on that header and it still didnt work. So i doubt that its a grounding issue. At least initially.
                                        @LeckieTech so if i understand you correctly, you want me to pull 5v from the fan header and send it over to the pson pin through a resistor than from the pson to the meter and back to ground?
                                        • jjuuzziiundefined
                                          jjuuzzii
                                          Did anybody find a solution ?
                                          I got the same Problem!!
                                          • mitchundefined
                                            mitch
                                            @jjuuzzii , I wired up my soft power control a little different.
                                            https://www.randoprojects.com/2020/07/30/duet-2-soft-power-control/
                                            What kind of PSU are you using?
