    PS_ON not working?
    2.1k
    • joehsmashundefined
      joehsmash @T3P3Tony
      @T3P3Tony i feel like im getting pretty close, i have come back to the original issue here is my M122 pre M80
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
      Board ID: 08DLM-996RU-N8PS4-7JKDA-3S86M-9BAZN
      Used output buffers: 3 of 24 (15 max)
      Static ram: 25712
      Dynamic ram: 93140 of which 0 recycled
      Exception stack ram used: 384
      Never used ram: 11836
      Tasks: NETWORK(ready,628) HEAT(blocked,1232) MAIN(running,3752) IDLE(ready,160)
      Owned mutexes:
      Last reset 00:08:16 ago, cause: power up
      Last software reset at 2020-05-07 00:48, reason: User, spinning module GCodes, available RAM 11780 bytes (slot 1)
      Error status: 0
      Free file entries: 9
      MCU temperature: min 29.9, current 30.3, max 30.5
      Supply voltage: min 0.6, current 0.7, max 0.7, under voltage events: 1, over voltage events: 0, power good: no
      Date/time: 2020-05-07 16:34:14
      Cache data hit count 1617214182
      Slowest loop: 1.16ms; fastest: 0.05ms
      Hiccups: 0, FreeDm: 158, MinFreeDm: 158, MaxWait: 0ms
      === DDARing ===
      Scheduled moves: 4, completed moves: 3, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      Segments left: 0
      Stack records: 1 allocated, 1 in use
      Movement lock held by http
      http is idle in state(s) 1 8
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 201.11ms; fastest: 0.08ms
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is running
        Failed messages: pending 0, notready 0, noresp 1
        WiFi firmware version 1.23
        WiFi MAC address bc:dd:c2:2d:64:61
        WiFi Vcc 3.38, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 23112
        WiFi IP address 192.168.1.44
        WiFi signal strength -45dBm, reconnections 0, sleep mode modem
      and here it is post M80
      M122
      Static ram: 25712
      Owned mutexes:
      Last reset 00:10:46 ago, cause: power up
      Error status: 0
      Free file entries: 10
      MCU temperature: min 30.1, current 30.8, max 30.8
      Date/time: 2020-05-07 16:36:45
      Cache data hit count 2209121988
      Slowest loop: 2.06ms; fastest: 0.05ms
      Hiccups: 0, FreeDm: 160, MinFreeDm: 158, MaxWait: 0ms
      === DDARing ===
      Scheduled moves: 4, completed moves: 4, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      === Network ===
      Slowest loop: 202.11ms; fastest: 0.08ms
      • WiFi -
        Failed messages: pending 0, notready 0, noresp 2
        WiFi Vcc 3.39, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 21648
        WiFi signal strength -44dBm, reconnections 0, sleep mode modem
      not much has changed
        joehsmash
        i cant find any reference to M80/81 in the config.g file, and i dont see it defined any where else,
          joehsmash
          i have now added the M80/81 commands at the beginning of the config.g and again no change
          M80 ; Turns on the ATX power supply
          M81 ; Turns off the ATX power supply
            joehsmash
            i have also measured with my meter, that i currently have 3.3v on the PSON connector that is feeding onto the DUET. i assumed that the duet would just ground that pin. but irregardless of m command it still retains the 3.3v.
            i also found a note in the forum from one of the duet employees that the GND isnt required so i have since removed it.
              joehsmash
              here is a copy of my config.g
              ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu May 07 2020 17:04:03 GMT-0600 (Mountain Daylight Time)
              M550 P"JoehBo3D" ; set printer name
              M552 S1 ; enable network
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm
              M566 X1020.00 Y1020.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
              M201 X9000.00 Y9000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
              M84 S30 ; Set idle timeout
              M208 X228 Y254 Z203 S0 ; set axis maxima
              M558 P1 H5 F-120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
              G31 P500 X-24 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
              M106 P0 S0 I0 F500 H1 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
              M106 P1 S1 I0 F500 H1:1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
              ; Custom settings
              Topherundefined 1 Reply Last reply Reply Quote 0
              • Topherundefined
                Topher @joehsmash
                @joehsmash according to your config.g your supply turns on then the next line it turns off
                joehsmashundefined 1 Reply Last reply Reply Quote 0
                  joehsmash @Topher
                  @LeckieTech good catch, it still doesnt activate the psu tho 😞
                  Topherundefined 2 Replies Last reply Reply Quote 0
                  • Topherundefined
                    Topher @joehsmash
                    @joehsmash With that output, you can't really read it with a voltmeter unless you add a pull-up resistor. You could use any resistor you have between 1k-100k ohms and pull up to 5 volts.
                    Send M81 - you should read 5 volts on the middle pin.
                    Send M80 - you should read 0 volts on the middle pin.
                    (sorry for the horrible drawing)
                    • Topherundefined
                      Topher @joehsmash
                      @joehsmash I suspect that the output is working but isn't one of 2 things.
                      1. on the same ground plane as the PSU
                      2. not providing a strong enough ground to the PSU
                        joehsmash
                        I didnt test the board, i tested the voltage of the pson of the psu to which i have 3.3v
                          joehsmash @Topher
                          @LeckieTech i had a ground hooked up to the gnd pin on that header and it still didnt work. So i doubt that its a grounding issue. At least initially.
                            joehsmash @joehsmash
                            @LeckieTech so if i understand you correctly, you want me to pull 5v from the fan header and send it over to the pson pin through a resistor than from the pson to the meter and back to ground?
                            • jjuuzziiundefined
                              jjuuzzii
                              Did anybody find a solution ?
                              I got the same Problem!!
                              • mitchundefined
                                mitch
                                @jjuuzzii , I wired up my soft power control a little different.
                                https://www.randoprojects.com/2020/07/30/duet-2-soft-power-control/
                                What kind of PSU are you using?
