    Stuck in spin loop, spinning module G-Codes
    1.6k
    • Aitorundefined
      Aitor
      I have not tried to change the micro SD, but it is a bit extrange to have the micro SD card damaged in 4 duet in different machines, no?
      In one machine I introduce M122 and this is what appears: "hard fault, spinning module none". This worries me even more, since this one hasn't stopped for a few days.
      Any idea or recommendation to try to solve both problems (the stops and the last message)?
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later + DueX5
      Board ID: 08DLM-996RU-N85T0-6J9FA-3SD6R-1VS3N
      Used output buffers: 3 of 24 (24 max)
      Static ram: 27980
      Dynamic ram: 95924 of which 44 recycled
      Exception stack ram used: 592
      Never used ram: 6532
      Tasks: NETWORK(ready,268) HEAT(blocked,1124) DUEX(suspended,160) MAIN(running,1732) IDLE(ready,80)
      Owned mutexes: WiFi(NETWORK)
      Last reset 41:48:37 ago, cause: watchdog
      Last software reset at 2020-07-29 15:38, reason: Hard fault, spinning module none, available RAM 0 bytes (slot 3)
      Software reset code 0x4071 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x00000803 BFAR 0x8688b5b0 SP 0x2001ff7c Task MAIN
      Stack: 00452be1 00401cc8 01030000 00000006 2001ffb8 00000000 200088b0 2000565c 004569cd 20000088 20005894
      Error status: 0
      MCU temperature: min 35.6, current 40.2, max 49.6
      Supply voltage: min 23.7, current 24.1, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: standstill, SG min/max 0/1023
      Driver 1: standstill, SG min/max 0/1023
      Driver 2: standstill, SG min/max 0/580
      Driver 3: standstill, SG min/max 0/1023
      Driver 4: standstill, SG min/max 0/1023
      Driver 5: standstill, SG min/max 0/1023
      Driver 6: standstill, SG min/max not available
      Driver 7: standstill, SG min/max not available
      Date/time: 2020-07-31 09:28:20
      Slowest loop: 207.17ms; fastest: 0.14ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 5.0ms, write time 160.3ms, max retries 0
      Hiccups: 0(0), FreeDm: 169, MinFreeDm: 106, MaxWait: 59465336ms
      === MainDDARing ===
      Scheduled moves: 465950, completed moves: 465950, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
      === AuxDDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
      Heater 0 is on, I-accum = 0.0
      Heater 1 is on, I-accum = 0.5
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 206.20ms; fastest: 0.00ms
      HTTP sessions: 2 of 8
      • WiFi -
        Network state is active
        WiFi firmware version 1.23
        WiFi MAC address[0_1596182504353_My Config.zip](Uploading 100%)
        WiFi Vcc 3.40, reset reason Unknown
        WiFi flash size 4194304, free heap 20632
        WiFi IP address 192.168.1.139
        WiFi signal strength -73dBm, reconnections 1, sleep mode modem
        === DueX ===
        Read count 181584, 72.38 reads/min
      My SYS: (without firmware)
      bed.g
      cancel.g
      config.g
      config-override.g
      dwc2settings.json
      gfinal.g
      ginicioT0.g
      ginicioT1.g
      ginicioT2.g
      ginicioT3.g
      homeall.g
      homeu.g
      homex.g
      homey.g
      homez.g
      pause.g
      resume.g
      resurrect-prologue.g
      sleep.g
      stop.g
      tfree0.g
      tfree1.g
      tfree2.g
      tpost0.g
      tpost1.g
      tpost2.g
      tpre0.g
      tpre1.g
      tpre2.g
      trigger2.g
      trigger3.g
      • Aitorundefined
        Aitor
        Good morning,
        I just saw that the command G92 E0 is not responding, could this be what's causing the problem?
        • Aitorundefined
          Aitor @Phaedrux
          @Phaedrux said in Stuck in spin loop, spinning module G-Codes:
          It might be worth trying a fresh SD card.
          Four SD cards formatted and still stopping.
          As soon as I have a new card, I will try it.
          Any other ideas or suggestions?
          Many thanks in advance!
            Thanks for the additional information and config files. I haven't had a chance to dig into all of them yet. It may be beyond me to give you any resolution. DC42 may have to take a look when he returns next week. In the meantime please continue to report a M122 if it stops again.
            • Aitorundefined
              Aitor
              This machine hasn't stopped for two days, but it's already stopped
              M122
              Used output buffers: 14 of 24 (24 max)
              Static ram: 27980
              Dynamic ram: 95524 of which 44 recycled
              Exception stack ram used: 264
              Never used ram: 7260
              Tasks: NETWORK(ready,348) HEAT(blocked,1224) DUEX(suspended,160) MAIN(running,1848) IDLE(ready,80)
              Last reset 00:27:19 ago, cause: software
              Last software reset at 2020-08-01 13:55, reason: Stuck in spin loop, spinning module GCodes, available RAM 6860 bytes (slot 3)
              Software reset code 0x4083 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x200042e4 Task IDLE
              Stack: 00454cdd 0045570a 61000000 a5a5a5a5 00454cdd a5a5a5a5 20004308 200041f8 00000002 2000517c 04c78fb0
              Error status: 4
              MCU temperature: min 40.1, current 40.5, max 40.8
              Supply voltage: min 24.1, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
              Driver 5: standstill, SG min/max not available
              Date/time: 2020-08-01 14:23:12
              Cache data hit count 2746906569
              Slowest loop: 6.07ms; fastest: 0.14ms
              === Storage ===
              SD card longest read time 3.7ms, write time 0.0ms, max retries 0
              Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
              === MainDDARing ===
              === AuxDDARing ===
              Heater 1 is on, I-accum = 0.0
              Segments left: 0
              === Network ===
              Slowest loop: 201.87ms; fastest: 0.09ms
              Responder states: HTTP(2) HTTP(2) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
              • WiFi -
                Failed messages: pending 0, notready 0, noresp 1
                WiFi MAC address
                WiFi Vcc 3.39, reset reason Unknown
                WiFi flash size 4194304, free heap 22376
                WiFi signal strength -74dBm, reconnections 0, sleep mode modem
                Socket states: 4 2 0 0 0 0 0 0
                === DueX ===
                Read count 0, 0.00 reads/min
                There is an issue when inputs connected to the DueX endstop or GPIO inputs pick up noise. Your config.g file indicates that you are using two DueX5 endstop inputs. Try using shielded cable to connect the switches to those inputs, or add pullup resistors of around 2K between each of those inputs and +3.3V.
                Aitorundefined 1 Reply Last reply Reply Quote 0
                • Aitorundefined
                  Aitor @dc42
                  Hello @dc42,
                  First of all, thank you so much.
                  I have made some tests with the changes that you recommend and everything is working well since I changed it.
                  I have changed the output "duex.e3stop" with "e1stop" , this endstop had 3 wires, but the "duex.e2stop" i have no change anything, this endstop (U axis) only has two wires, GND and "Z STOP" (input E2 STOP). Do you recommend to put the 2k resistance to the "Z STOP" although is not  failing?
                  Thanks a lot again!
                    2-wire normally-open endstop switches connected to a DueX are most likely to pick up noise and cause a problem. 2-wire normally closed endstop switches and 3-wire endstop switches connected to DueX would only be likely to pick up noise if they run very close to stepper motor cables for some distance and the cables are not twisted pairs.
                    Aitorundefined 2 Replies Last reply Reply Quote 0
                    • Aitorundefined
                      Aitor @dc42
                      Hello @dc42,
                      The endstop that I still have in the duex is a two wire sensor, normally closed. But may be problem if wires go on a chain carrier with the wires of the motor (wires that are not braids), better if I put a 2k resistance to isolate the wires of the endstop?
                      Thanks again!
                      • Aitorundefined
                        Aitor @dc42
                        Hello @dc42,
                        In the tests that i have done this days, i have seen that the machine did not stop printing as before, but now we have the problem with the endstop that is connected to the duex, sometimes it does not work well:
                        Sometimes the machine thinks that is always pressed (the axis does not go to home position), others as if it was never pressed (so the motor hits against the endstop but nothing happens).
                        Is happening in different machines equally assembled. I attached you a picture to show you how I put the 2k resistor. Any idea of what is happening or how to solve it?
                        I have seen in https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_RepRapFirmware_Num_3:
                        P"pin_name" Defines the pin name(s) that the endstop(s) for the specified axis are connected to, see Pin Names. Needed when S=1. May need it ! before pin name to invert signal, or ^ to enable the pullup resistor, for example on the Duex expansion board.
                        M574 U2 S1 P"^duex.e2stop"
                        Should I be using that way of the PIN output? If I do it, as soon as the machine touches the endstop, it gets blocked and does not recover until it stops touching the endstop. What is this for?
                        Thanks a lot again!
                          Can you try twisting the endstop wires?
                          • Aitorundefined
                            Aitor
                            Good morning,
                            I don't know what else to try, I've changed the endstop that was connected to the DUEX (U axis) and I put the Z endstop, but it still fails (Now, U axis that is in Duet 2 wifi, works well). This endstop is alone and is not near a motor wire. I tried to put it with a 2k resistor, also with the braided wires, but nothing, sometimes it does not detect it and others it thinks that it is always clicked (so the motor does not go to home position). Is a bit strange because the endstop is a normally closed sistem
                            Sometimes the limit switch doesn't detect it or it always does, the latter is the most common thing, which makes it stranger to me since it's a normally closed limit switch
                            What else can I try? Any suggestions?
                            droftartsundefined dc42undefined 2 Replies Last reply Reply Quote 0
                              droftarts administrators @Aitor
                              @Aitor I think your power wiring, both to the Duet and to the Duex, looks very thin. Is it of sufficient gauge to carry the current to supply the heaters, stepper motors and both Duet and Duex electronics? Also, you need a low resistance ground wire between the Duet and Duex to avoid crosstalk and the Duex using the ground wires in the ribbon cable for grounding (which may be causing your issue). So, ideally, use heavier gauge wiring on your power wiring, minimum 18AWG and preferably something bigger like 16 or 14AWG. Use the bootlace ferrules, too. See https://duet3d.dozuki.com/Wiki/Power_Wiring#Section_Main_power and https://duet3d.dozuki.com/Wiki/Duex2_and_Duex5_Features#Section_Wiring
                              Also, it looks like you wired the 2K resistor in line (is it under your fingers in the shrinkwrap in your earlier picture?) rather than between the endstop input and +3.3V.
                              Finally, it is not advisable to run wires near the Duet to Duex ribbon cable. The ribbon cable is unshielded, and can pick up interference.
                              • Aitorundefined
                                Aitor @droftarts
                                Hello @droftarts,
                                The wire that I am using to feed the motherboards is 18AWG with the splints on. I am going to order a 14AWG wire to test it (https://es.rs-online.com/web/p/conductores-de-interconexion-cables-para-equipos/6877607/)
                                How can I connect a ground wire between duet and duex? Can I use any free GND pin to connect them?
                                I have also tried to connect the ground I have in the chassis with a GND (green wire that you see in the image below connected to GND of always on fans) of the Duet 2 Wifi electronics, only in this one since I assume that the GND of both boards are connected, something that the polymeter tells me is correct, but this has not worked either
                                I have also removed the wire that was running through the flat wire in one of the machines, but others that didn't have it also fail. It doesn't matter what endstop I put in the duo that it will fail.
                                I have also tried to correct the pull up resistor connection, is it correct now?
                                With all this testing and changes, is still not working well, any other suggestion, idea or recommendation?
                                fcwiltundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                                  dc42 administrators @Aitor
                                  @Aitor said in Stuck in spin loop, spinning module G-Codes:
                                  To be clear, the 2K resistor should be connected between the STP and 3V3 pins of the endstop connector on the DueX. Is that what you did?
                                  • Aitorundefined
                                    Aitor @dc42
                                    Hello @dc42,
                                    Yeah, that's what I did.
                                    • fcwiltundefined
                                      fcwilt @Aitor
                                      @Aitor
                                      This is how I connected power to my Duet WiFi/Duex 5 setups.
                                      The two wires (red & black) connecting the two boards are SOLID 14 gauge.
                                      The two wires from the middle of the of the two solid wires are STRANDED 14 gauge and go directly to the power supply. Spade lugs are crimped onto the ends of the wires connecting to the power supply.
                                      The two stranded wires are soldered to the two solid wires.
                                      The black substance you see where the stranded wires join the solid wires is "liquid electrical tape", a sticky, thick liquid that dries to a tough rubbery covering.
                                      I've wired the Duet boards in all my printers using the approach and it has always proven to work.
                                        I am implementing a possible fix for this in RRF 3.2beta1, due out by the end of this week. I may be able to provide a firmware binary with the change before then.
                                        • Aitorundefined
                                          Aitor @dc42
                                          @dc42 thank you so much. I will be eagerly waiting for the new beta RRF to test it.
                                          Anyway, looking at the Duet, I have seen that I have the Zprobe signal free. Can I use it as an endstop and put there the endstop that I have in DUEX?
                                          If it is possible, how should I connect and program it?
                                            No, don't use a free ground pin. This may or may not be directly connected to the ground plane of the Duet PCB, so may or may not have sufficient copper trace to ground all current. As shown in the documentation https://duet3d.dozuki.com/Wiki/Duex2_and_Duex5_Features#Section_Wiring, use a short, thick wire from the VIN negative terminal of the Duet to the VIN negative terminal of the Duex.
                                            Do you have a ground wire going from the frame to the negative terminal on your PSU? If not, you risk destroying your Duet if you do this. If you have a short circuit to the frame, it may short through the ground pin of the Duet. You should tie all grounds together, and to the negative on your PSU.
                                            Once you have a ground wire from frame to PSU negative, it's also possible that you need to ground stepper motors to the frame. See https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Using_the_internal_drivers
                                            It is highly recommended that the stepper motor casings be grounded, especially in belt-driven printers. Otherwise, motion of the belts causes static charge to build up, which eventually arcs over to the windings. Filament motion in extruders can cause static charge to build up on the extruder drive motor too. If the motors are screwed to a metal frame, grounding the frame is sufficient.
                                            We generally recommend that you also connect mains ground to the V- output of your PSU. Check with the PSU manufacturer this is okay first, though. If you do this, watch out if you use a USB connection to the Duet, see the wiki page on USB ground loops. https://duet3d.dozuki.com/Wiki/USB_ground_loops
                                            It's difficult to know where the issue is coming from. As it's the same across all your machines, it doesn't seem like it's the Duet or Duex. It does seem more like a wiring issue.
