Sensorless homing
config g :
M569 P1 S0 ; physical drive 1 goes forwards
M569 P3 S0 ; physical drive 3 goes forwards
M92 X80.00 Y80.00 Z400.00 E633.00 ; set steps per mm
M203 X18000.00 Y18000.00 Z600.00 E3000.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
M906 X1200 Y1200 Z1200 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X310 Y310 Z400 S0 ; set axis maxima; Endstops
M574 X1 Y1 S3 ; set endstops controlled by motor stall detection
M564 H0; Z-Probe
M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
M557 X15:215 Y15:195 S20 ; define mesh grid -
homeall.g
M98 Phomex.g
M98 Phomey.g
M98 Phomez.ghomey.g
M400 ; wait til stuff stops
M574 X1 Y1 S3 ; use stall guard for endstops
M913 X30 Y30 ; drop motor currents to 30%
M201 X1000 Y1000 ; reduce acceleration on X/Y to stop false triggers
M915 P0:1 S3 R0 F0 H400; both motors because corexy; Sensitivity 4, don’t take action, don’t filter, 400steps/sec
G91 ; set relative
G1 Z5 F1200 S2
G1 S2 Y-350 F4000 ; move forward 250mm, stopping at the endstop
G1 Y10 F1200; move away from end
G1 Z-5 F1200 S2
G90 ; back to absolute positioning
M400 ; wait again
M913 X100 Y100 ; motor currents back to 100%
M201 X3000 Y3000 ; accel back to original
M574 X1 Y1 Z0 S0 ; set endstops back -
This post is deleted! -
increase sensitivity until you get wrong readings from the motor starting, then slowly reduce it again.
cheers i am guessing the sensitivity is this line...
M915 P0:1 S-5 R0 F0 H400;
even with s-5 motor keeps trying and not triggering
I do believe you can go all the way to -63. Speed, and motor current are also a factor when using the stall detection. it took me quite a bit to find the sweet spot where the stall detection wouldn't detect the ball screw but would detect it hitting the nozzle. I have also read that it works better at higher speeds but lower current settings. Best of luck.
The issue you might be having is that you are moving quite slowly at 1200mm/min compared to the number of steps you have set to be reliable. I think many corexy system will move 20mm in 1 full rotation of the motor which would be 400 steps with a 0.9degree motor so that might be your issue. Try lowering that number of steps its your H value in the M915. also try moving faster.
sorry is a Cartesian cr-10 belt driven
IF sensitivity still isn't getting you to stall detect, decrease current and increase speed.
Also review your H value in M915 as @baird1fa has said. Default values aren't going to work most likely, you will need to tune it.
https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing
