    Duet 3 v1.0 Fault on SD slot
    674
    • Carloundefined
      Carlo
      Switched my machine on this morning and was unable to connect..did the usual check still nothing noticed no network activity on the board so erased and and opened bossa installed firmware install all OK but still no network activity so connected a Pi and network comes up
      and I can connect as usual through the Pi but as the Pi is not working with my board not much actual use the slot has always been a bit of a fiddle with it not latching 1st time but wasn't really a bother as don't remove the card that often.
      Any Advise?
      Cheers
      C
        T3P3Tony administrators
        please connect over USB (with a terminal like YAT) with an SD card in the socket and send M122
        Carloundefined 1 Reply Last reply Reply Quote 0
        • Carloundefined
          Carlo @T3P3Tony
          @T3P3Tony
          Hi Tony see below thanks.
          M122
          RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode)
          Board ID: 08DJM-956L2-G43S8-6J9DL-3SD6M-1S3UF
          Used output buffers: 1 of 40 (13 max)
          Static ram: 154604
          Dynamic ram: 161360 of which 20 recycled
          Exception stack ram used: 308
          Never used ram: 76924
          Tasks: NETWORK(ready,1972) HEAT(blocked,1416) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,204) MAIN(running,4528) IDLE(ready,76)
          Owned mutexes:
          Last reset 00:02:56 ago, cause: reset button
          Last software reset at 2020-08-10 18:57, reason: User, spinning module GCodes, available RAM 76172 bytes (slot 1)
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
          Error status: 0
          MCU temperature: min 39.1, current 39.7, max 39.8
          Supply voltage: min 23.9, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
          12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
          Driver 0: standstill, reads 20356, writes 0 timeouts 0, SG min/max not available
          Driver 1: standstill, reads 20356, writes 0 timeouts 0, SG min/max not available
          Driver 2: standstill, reads 20356, writes 0 timeouts 0, SG min/max not available
          Driver 3: standstill, reads 20356, writes 0 timeouts 0, SG min/max not available
          Driver 4: standstill, reads 20356, writes 0 timeouts 0, SG min/max not available
          Driver 5: standstill, reads 20356, writes 0 timeouts 0, SG min/max not available
          Slowest loop: 0.34ms; fastest: 0.14ms
          === Storage ===
          Free file entries: 10
          SD card 0 detected, interface speed: 12.5MBytes/sec
          === MainDDARing ===
          Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
          === AuxDDARing ===
          Bed heaters = -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is ready with "M122" in state(s) 0
          Aux is idle in state(s) 0
          Trigger* is idle in state(s) 0 0, running macro
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon* is idle in state(s) 0 0, running macro
          Aux2 is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 1.42ms; fastest: 0.01ms
          HTTP sessions: 0 of 8
          • Ethernet -
            State: disabled
            Error counts: 0 0 0 0 0
            === CAN ===
            Messages sent 0, longest wait 0ms for type 0
            === Linux interface ===
            State: 0, failed transfers: 0
            Last transfer: 140774ms ago
            RX/TX seq numbers: 0/1
            SPI underruns 0, overruns 0
            Number of disconnects: 0
            Buffer RX/TX: 0/0-0
            ok
          Cheers
          C
            @Carlo said in Duet 3 v1.0 Fault on SD slot:
            Although that is not a great speed it does appear to be working. please post your config.g thats on the SD card.
            Its saying SBC mode so is the Pi connected? I wonder if you get a different response with the Pi not connected.
            • Carloundefined
              Carlo
              Tony the Pi is not connected
              and it was working yesterday in stand alone mode
              Config.g
              ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon May 25 2020 14:05:35 GMT+0100 (British Summer Time)
              M550 P"Duet 3" ; set printer name
              M665 L440.47:440.47:440.47 R234.553 H410.523 B185.0 X 0.265°, Y 0.181°, Z 0.000° ; Set delta radius, diagonal rod length, printable radius and homed height
              M666 X-0.00 Y0.00 Z-0.00 A0.00 B0.00 ; put your endstop adjustments here, or let auto calibration find them
              ;M665 L438.767:438.767:438.767
              M552 P192.168.0.25 S1 ; enable network and set IP address
              M553 P255.255.255.0 ; set netmask
              M554 P192.168.0.254 ; set gateway
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              M569 P0.0 S0 ; physical drive 0.0 goes backwards
              M569 P0.1 S0 ; physical drive 0.1 goes backwards
              M569 P0.2 S0 ; physical drive 0.2 goes backwards
              M569 P0.3 S1 ;G5 ; physical drive 0.4 forwards for G5 flex
              M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping CHANGE G5 0.4G
              M350 E8 I0 ;G5 ; G5 configure 8 microstepping interpolation off
              M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
              M92 X160.00 Y160.00 Z160.00 E1900.00 ; G5 set steps per mm G5 1900
              M566 X1200.00 Y1200.00 Z1200.00 E6.00 ; G5 set maximum instantaneous speed changes (mm/min) 6
              M203 X12000.00 Y12000.00 Z12000.00 E2400.00 ; set maximum speeds (mm/min)
              M201 X1200.00 Y1200.00 Z1200.00 E120.00 ; set accelerations (mm/s^2)
              M906 X1050 Y1050 Z1050 E270 I50 ; set motor currents (mA) and motor idle factor in per cent
              M84 S45 ; Set idle timeout
              M208 Z-0.3 S1 ; set minimum Z
              M574 X2 S1 P"io4.in" ; configure active-high endstop for high end on X via pin io4.in
              M574 Y2 S1 P"io1.in" ; configure active-high endstop for high end on Y via pin io1.in
              M574 Z2 S1 P"io2.in" ; configure active-high endstop for high end on Z via pin io2.in
              M558 P8 R0.8 C"io3.in+io3.out" H5 F1200 T5000 ; set Z probe type to effector and the dive height + speeds
              G31 P500 X0 Y0 Z-0.12 ; set Z probe trigger value, offset and trigger height
              M557 R160 S20 ; define mesh grid
              M308 S0 P"temp0" Y"thermistor" T100000 B3950 ;B3950 C0 R4700 configure sensor 0 as thermistor on pin temp0
              M307 H0 A108.2 C457.9 D0.5 S1.00 V24.1 B0 ; disable bang-bang mode for the bed heater and set PWM limit
              M308 S1 P"spi.cs0" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs0
              M143 H1 S450 ; set temperature limit for heater 1 to 450C
              M307 H1 A512.3 C269.6 D3.6 S1.00 V24.0 B0 ; disable bang-bang mode for heater and set PWM limit
              M950 F0 C"out9" Q250 ; create fan 0 on pin out9 and set its frequency
              M106 P0 S0 H-1 C"Part Cooler" ; set fan 0 value. Thermostatic control is turned off
              M950 F1 C"out7" Q250 ; create fan 1 on pin out7 and set its frequency
              ;M950 F2 C"out8" Q100 ; set fan 2 value. Thermostatic control is turned off
              ;M106 P0 S0 I0 F500 H-1 L0.35 B2.5 ;Berd air pump settings
              M563 P0 S"E3D Brass 0.4" D0 H1 F0:2 ; define tool 0
              ; Custom settings
              ;Retraction settings
              M207 S1.50 F900 T550 Z0.3 ;G5 ; G5 retraction setting
              ;MCU Temp
              M912 P0 S-1.8 ; adjust MCU temp for correction at ambient
              ;M501 ; load saved parameters from non-volatile memory
              Cheers
              C
                T3P3Tony administrators @Carlo
                @Carlo Thanks
                So when connected in YAT, with the Ethernet plugged in if you send
                Does it work as expected?
                Another test is to send M665 with no parameters and see if the correct ones are displayed back.
                Basically trying to confirm if the SD card it being read or not.
                Laos if you have another SD card it would be worth testing that.
                • Carloundefined
                  Carlo @T3P3Tony
                  @T3P3Tony
                  Response from YAT
                  ok
                  Ethernet running, IP address = 192.168.0.25
                  M665
                  Error: M665: M665 parameters do not apply to Cartesian kinematics
                  ok
                  Still can't connect:
                  Your Duet rejected the HTTP request: page not found
                  Check that the SD card is mounted and has the correct files in its /www folder
                  First thing I tried of the usual thing was swap the card with a backup of all the folders
                  Before I re-flashed the firmware
                    It definitely seems like it's not reading the SD card. Not executing the config.g and can't read the /www folder.
                    Can you try sending M22 followed by M21? This should unmount and remount the SD card.
                    Also M122 P104, which should try to measure the write speed of the SD card.
                    • Carloundefined
                      Carlo @Phaedrux
                      @Phaedrux said in Duet 3 v1.0 Fault on SD slot:
                      M22
                      Yat output of M21/M22
                      M22
                      SD card 0 may now be removed
                      ok
                      M21
                      Error: M21: Cannot initialise SD card 0: Card is unusable
                      ok
                      I've tried a third card which this is output against, weirdly the SD slot is now latching 1st time?.
                      M122 P104
                      Error: Failed to create folder 0:/gcodes in path 0:/gcodes/test.tst
                      Error: M122: Failed to create file
                      ok
                      Cheers
                      C
                        When and where was the board purchased? There seems to be a fault in the SD card slot.
                        Can you post close up photos of the slot insides and the solder tabs?
                        • Carloundefined
                          Carlo @Phaedrux
                          @Phaedrux
                          Yeah Pic to follow
                          08/04/20 E3D
                          Cheers
                          C
                            Sorry, is that August 4th or April 8th? Not that it matters, either are within 6 months.
                            You can contact E3D and initiate a warranty exchange. Use this thread as authorization. I'm not sure what the current Duet3 stock status is due to the current manufacturing issue with driver diodes, so there may be a delay on replacement. At least in the meantime you can use SBC mode.
                            • Carloundefined
                              Carlo @Phaedrux
                              @Phaedrux
                              LoL no I can't use SBC mode it has never worked "under investigation"
                              Best I can get on my phone
                              I can't see anything obvious with the slot or pads?
                              Cheers
                              C
                                Right: https://forum.duet3d.com/topic/16191/duet3-pi-dwc-freezing/31?_=1597246408031
                                All the more reason to swap it out. Something is amiss.
                                • Carloundefined
                                  Carlo @Phaedrux
                                  @Phaedrux
                                  April
                                  Thanks as always appreciate your help.
                                  C
                                    It sounds like FW 3.2 beta1 is arriving shortly (maybe this week), if you still have the board when it lands, perhaps you can test it to see if it has an effect on your other SBC issue.
                                    • Carloundefined
                                      Carlo @Phaedrux
                                      @Phaedrux
                                      E3D is out of stock so I'll keep hold until I've tested 3.2.1beta may be helpful.
                                      Cheers
                                      C
                                        Do you happen to have a different pi to test SBC mode with?
                                        • Carloundefined
                                          Carlo @Phaedrux
                                          @Phaedrux
                                          Yeah tested it with 3 Pi's 2x 4b and 1 3b+ all exactly the same result with nothing else attached and even tried a new 26 pin cable still the same.
                                          • Carloundefined
                                            Carlo @Carlo
                                            @Carlo
                                            The freezing I sorted by not using duetPi and just adding DSF to another distro but thats a far as I could get I could do everything but print ..just went nuts on the purge line or first move
                                            actually damaged my print bite sheet rammed the head in to the bed bent the heat break
                                            but same files Iv'e printed many time in stand alone
