Possible PWM port issue & RRF3 Question
@bearer As I am completely unfamiliar with RRF code, I'm reading through the Dokuzi looking for something but I guess what I'm asking is is there a way to do this to get me by? I have spare mosfets but the last time I tried this I melted the board so I am tempted to just buy a DueX and utilize those pwm fan ports instead. I just wish I knew why they all of the sudden are reading like the Mosfets are blown. they worked perfectly yesterday when I tested my wiring and nothing has changed.
Edit: when you say "external mosfet" do you mean there is a way to control PWM ports from a third party Mosfet? It would be wonderful if there way a fuse protected mosfet setup I could install instead..
Edit2: I decide to troubleshoot a bit, if I hook up an voltmeter and run:
M126 P1 S1 my voltage goes from 16v up to 23, so it seems I have some control?
M126 P0 S1 my voltage goes from 20v up to 24v, again seems I have control?
M126 P2 S1 no voltage change, seemed totally screwed
So... then I remapped RRF2.03 config.g to make my Tool0 use Fan1, and was able to measure voltage and change it on my panel due. So I plugged in a fan and turned it on but the fan won't move. And yes the fan works if I plug it into an ALWAYSon port. WTF?! how does this make sense? Is this a defective board or something? -
heat and/or high currents are the common culprits with dead mosfets - usually a result of a short circuit somewhere.
yes, you could wire pretty much any pin from a duet2 to the gate on a compatible mosfet and set it up as a fan with M950+M160. (pull up/down and series resistance as required, refer to the duet schmeatic for examples)
however its common for the mosfet to fail before a fuse, as the fuse just isn't fast enough to prevent the initial surge from a short circuit, its there to prevent damage from overloading the board or wires in the event of a prolonged fault current. that said its still a good idea to add a fuse.
@bearer said in Possible PWM port issue & RRF3 Question:
Connecting a fan the wrong way round (i.e. wrong polarity) can also cause a mosfet to blow, depending on the fan.
@dc42 Okay. I was very diligent to mark + & - wires when extending my wiring and tested continuity to make sure, which is why the first test was fine. I had it correct.
Then yesterday all of the sudden all three just stopped working, nothing in the wiring changed.
So... I have a question, why are the PWM fan ports not protected by a fuse? The only issues I have ever had with this board has been these MOSFETs . I love this board, but this is a serious Debbie Downer...
And my question still stands, if I blew the MOSFETs then why do I measure voltage change when I toggle the F0 or F1 ports with M126? Last time this happened to me with a clone board, I read 0 volts, and I learned my lesson to triple check everything before plugging back in and powering upWhat are my options here?
1.) Could this be a bad board that I could get replaced under warranty? Purchase was in April2020 via Filastruder
2.) Can a [DueX2 expansion](https://www.filastruder.com/collections/electronics/products/duex2-and-duex-5-expansion-board[link text](link url)) allow me to get PWM functionality back?
3.) Or could just this Expansion Board give me a couple PWM ports back?
4.) am I missing something else that's affordable????? -
Your easiest option would be as bearer suggested above and remap a spare heater output as a PWM fan control.
If you have already upgraded to RRF3 it's quite easy. You'll need to identify what heater port you want to use, find it's pin name, and then use M950 to define that pin as a fan. Then your M106 fan command can refer to it.
I think when you extended the wiring there was either a short or a change to polarity that caused the mosfet to fail. Perhaps at a crimp there was a stray wire?
@jallen810 said in Possible PWM port issue & RRF3 Question:
They are, but as described the fuse is much too slow to protect from the initial surge. Fuses are meant to protect from a short circuit drawing too much current and setting something on fire. The mosfets are unfortunately delicate, so great care must be taken with fan wiring. And even when great care is taken, I've even seen fans from amazon that had the black and red wires switched. Peeling back the label to show the fan PCB revealed that the black and red wired were swapped at the - + silk screen terminals.
@Phaedrux Okay. I just finished the upgrade to RRF3.
So by doing this M950+M160, I will be able to have a layer fan that is controllable by Gcode? and a thermostatically controlled HE fan?Lastly, now that I've finished my RRF3.1 upgrade I get these 2 issues:
1.) My inductive probe (NC) isn't stopping now when I do a G30 and put a wrench under it
2.) and when I try to home X or Y, the head moves 5-10 mm and stops?Can you point me to a page that explains the RRF settings for these sensors? It used to be this in my config.g for RRF2.x:
M574 X1 Y1 S0 ; set active low and disabled endstops (To enable Z-endstop add "Z1 or Z2" after y M574 Z1 S2 ; Define Z to use probe. S2=Home to min and for my ABL: M307 H3 A-1 C-1 D-1 ; (Duet3d method) disable Heater7 to free up PWM channel 5 on Duex board for BLTouch M558 P5 H5 F600 A1 I1 ; GLH8 EndstopABL, Mode P=5, StartProbeH=5mm, Speed=600mm/min, #probes A=3, Invert signal for Endstop I=1 -
one of them if you have heater E1 unused; so I'd wire hotend to always on and layer to heater E1 output.
@bearer okay so that works for me! I've already moved my HE fan to always on.
Just for future plans sake, if I decide I need more PWM fans, can I get either the expansion board with 2pwm ports or a Duex2/5 and restore my PWM function with those?
Or does the main board damage prevent me from doing that? -
can't say for sure but most likely that damage is isolated to the the mosfets for the fans (mosfets can be replaced, its a bit of a tight spot and some groundplanes, but with proper tools its perfectly doable; you can ask around locally or maybe https://forum.duet3d.com/topic/13875/community-repairs)
as for the expansion breakout i don't think you drive a fan off that directly. duex2/5 will be fine.
M574 X1 Y1 S0 ; set active low and disabled endstops (To enable Z-endstop add "Z1 or Z2" after y M574 Z1 S2 ; Define Z to use probe. S2=Home to min and for my ABL: M307 H3 A-1 C-1 D-1 ; (Duet3d method) disable Heater7 to free up PWM channel 5 on Duex board for BLTouch M558 P5 H5 F600 A1 I1 ; GLH8 EndstopABL, Mode P=5, StartProbeH=5mm, Speed=600mm/min, #probes A=3, Invert signal for Endstop I=1 The issue is probably the inversion in M558 for the probe trigger signal. I1 is replaced in RRF3 by using a ! in front of the pin name.
I suggest you use the configurator to generate a config for RRF3 and then compare the output to your own to see the differences.
https://configtool.reprapfirmware.org/Start
This document also has the best overview of the changes.
https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview -
@Phaedrux that is the RRF Config output! Lol That’s why I was confused. I could have selected the wrong setting somewhere.
Thanks for the link, I’ll dig in after the kiddos go to bed. -
@Phaedrux When you tag into E1 heater and Heater 7, just to clarify, I would hook up to E1 to the positive lead to fan. Then I would hook up "13) heater4" (as an example) pin to the negative lead of the fan?
Post your config.g then. Maybe you had RRF2 selected?
I'm not sure what you mean by this.
@Phaedrux I had a blonde moment, I can't use a normal 2pin fan can I?
I need a 3+ wire fan right? (sorry never actually used PWM function of fans before)My artillery sidewinder specs:
Xaxis: homes at 0, left side (Panasonic GL8H optical NPN NC sensor)
Yaxis: homes at back, but 0 is actually at the front (Panasonic GL8H optical NPN NC sensor)
Z = Inductive ABL probe (Panasonic GXHL15A NPN NC sensor)Lastly, here is my RRFconfigurator custom config.g for RRF3.1:
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Aug 15 2020 15:29:14 GMT-0400 (EDT) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Sidewinder X1 RRF3" ; set printer name ; Network M552 S0 M552 S1 P192.168.1.50 ; Assign fixed IP address M553 P255.255.255.0 ; Assign Netmask to match my network M554 P192.168.1.1 ; Assign Gateway IP address to match network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S0 ; physical drive 1 goes backwards M569 P2 S0 ; physical drive 2 goes backwards M569 P3 S0 ; physical drive 3 goes backwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E415.00 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E1200.00 ; set maximum instantaneous speed changes (mm/min) M203 X9000.00 Y9000.00 Z1500.00 E3000.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E166.67 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X300 Y340 Z400 S0 ; set axis maxima ; Endstops M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop M574 Z2 S2 ; configure Z-probe endstop for high end on Z ; Z-Probe M558 P1 C"zprobe.in" H5 F600 T6000 ; set Z probe type to unmodulated and the dive height + speeds G31 P1000 X40 Y-41 Z2.5 ; set Z probe trigger value, offset and trigger height M557 X45:295 Y10:280 S40 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S130 ; set temperature limit for heater 0 to 130C M308 S1 P"e0temp" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 C"Layer Fan 1" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 C"HE Fan 2" S1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M575 P1 S1 B57600 ; enable support for PanelDue M501 ; load saved parameters from non-volatile memory M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss and for reference, here is the back up of the RRF2.03. config.g that I made just before updating to RRF3 this afternoon:
; Configuration file for Duet WiFi (firmware version 2.03) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat Apr 11 2020 14:47:32 GMT-0400 (Eastern Daylight Time) ; Revised by Jake Allen on 4.18.2020 @ 10:30am EST ;-----General preferences----------------------------------------------------------------------------------------------------------------- G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Sidewinder X1" ; set printer name ;-----Network---------------------------------------------------------------------------------------------------------------------------- M552 S0 ;M552 S1 P192.168.1.50 ; Assign fixed IP address M553 P255.255.255.0 ; Assign Netmask to match my network M554 P192.168.1.1 ; Assign Gateway IP address to match network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ;-----Drives----------------------------------------------------------------------------------------------------------------------------- M569 P0 S0 D2 ; (X-Axis) drive 0 goes forwards (Jake wrong config M569 P0 S1) M569 P1 S1 D2 ; (Y-Axis) drive 1 goes forwards M569 P2 S1 D2 ; (Z-Axis) drive 2 goes forwards M569 P3 S1 D2 ; (Extruder) drive 3 goes backward with Bondtech (titan = S0, Bondtech = S1) M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure micro-stepping with interpolation M92 X80.12 Y80.12 Z399.78 E415.0 ; set steps per mm (from Jake's Marlin Setup) (titan=446mm) M566 X800.00 Y980.00 Z60.00 E2500.00 ; set maximum instantaneous speed changes (mm/min) --> E180 to E2500, Z12 to Z60 M203 X9000.00 Y9000.00 Z1500.00 E3000.00 ; set maximum speeds (mm/min) --> X&Y from 6000 (100mm/s) to 9000 (150mm/s) M201 X800.00 Y800.00 Z400.00 E10000.00 ; set accelerations (mm/s^2) E10000 M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ;-----Axis Limits------------------------------------------------------------------------------------------------------------------------ M208 X0 Y0 Z0 S1 ; set axis minima M208 X300 Y340 Z400 S0 ; set axis maxima (Changed Y from 300 to 345 to compensate for offset) ;-----Endstops--------------------------------------------------------------------------------------------------------------------------- M574 X1 Y1 S0 ; set active low and disabled endstops (To enable Z-endstop add "Z1 or Z2" after y M574 Z1 S2 ; Define Z to use probe. S2=Home to min ;-----Z-Probe (BLtouch)------------------------------------------------------------------------------------------------------------------ M307 H3 A-1 C-1 D-1 ; (Duet3d method) disable Heater7 to free up PWM channel 5 on Duex board for BLTouch M558 P5 H5 F600 A1 I1 ; GLH8 EndstopABL, Mode P=5, StartProbeH=5mm, Speed=300mm/min, #probes A=3, Invert signal for Endstop I=1 ;BLTOUCH; M558 P9 H5 F100 T9000 ; (Duet3D method) P=Select Z-probe mode=9 BLtouch. H=DiveHeight abv bed(mm), F=Speed bed moves, T=TravelSpeed btwn pts G31 P25 X40 Y-41 Z1.385 ; P=Z probe trigger value,X&Y=offset mount relative to nozzle (mm), Z=trigger height 1.84 ;(4020 Mosquito J&L Mount + HL15 Zoff=0.7mm, x=40, y=-41) ;(M18 probe,z=1.85mm, x=40, y=-50) ;Stock z-end=0.58 ; Change P500 to P25 and X&Y=0 to X=40 & Y=-38 for probe offset vs. nozzle (3DChanh X58 Y-36) M557 X45:295 Y10:280 S40 ; define mesh grid (S20 = 143 points, S45 = 36pts) (Prev: M557 X15:285 Y15:285) ; Change X0:225 Y45:300 S45 to--> M557 X60:300 Y0:260 S20, S20=156pts, try S24 & S40 =100 & 36pts, Previously S=30 ;-----Heaters---------------------------------------------------------------------------------------------------------------------------- M140 H0 ; remap heated bed to heater 1 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M305 P0 T100000 B4138 R4700 ; set Bed thermistor + ADC parameters for heater 0 M143 H0 S125 ; set temperature limit for heater 0 to 125C ;M305 P1 T100000 B4138 R4700 ;104GT E3D thermistor set thermistor + ADC parameters for heater 1 M305 P1 T500000 B4723 C1.196220e-7 H20 ; Slice Engr 450°C thermistor Set thermistor +ADC parameters for H1 M143 H1 S320 ; set temperature limit for heater 1 to 300C ;-----Fans-------------------------------------------------------------------------------------------------------------------------------- M106 P1 S0 H-1 C"Layer_Fan" F500 ; Part Cool Layer Fan (8.14.20 blew Mosfets, some cntl Fan1 port so remapped) ;M106 P1 S1 H1 T45 C"Heatsink_Fan" F500 ; Hotend Heatsink Fan ;M106 P2 S0.75 H0 T45 C"BoardCool" F500 ; Ducted 4020 DuetBoard Cooling Fan, Bed=45c turn on fan 75% ;-----Tools------------------------------------------------------------------------------------------------------------------------------- M563 P0 S"HOTEND" D0 H1 F1 ; define tool 0 (8.14.20 change from F0 to F1 bc of blown mosfet remap) G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ;-----Miscellaneous----------------------------------------------------------------------------------------------------------------------- M501 ; load saved parameters from non-volatile memory M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss T0 ; select first tool -
I need a 3+ wire fan right? (sorry never actually used PWM function of fans before)to use with E1 output? you can use 2 pin fan. 3pin fans have tachometer for RPM feedback, 4pin fans have PWM input but i'd hesitate to drive the PWM input from a pin on the duet without doin some research
@bearer okay so @Phaedrux said I can tag into the E1 heater for the 24v and then pick a heater pin on the expansion slot. My question is how do I actually physically wire this thing up?
Red wire [from fan +V] ---> Heater4 (pin13)
Black wire [from fan -V] ----> E1+24v -
They are, on version 1.03 and later boards... but sadly fuses blow much more slowly than mosfets do.
On later production we've switched to mosfets with a higher peak current rating, although that's unlikely to help when the output is shorted.
Black wire [from fan -V] ----> E1+24vboth wires to E1 output if the fan is 24v.
red wire to Vin
black wire to E1-
(E1- is switched to ground when the output is enabled, to use heater4 or any of the other pins on the expansion you'll need an external mosfet to sink more current than the microcontroller can handle) -
Just in case it wasn't totally clear, both fan wires will go the the E1 heater connector.
Then in your config.g you would need the follow assuming you're going to use it as Fan0.
Where you have:
you would change it toM950 F0 C"e1heat" Q500
The pin name e1heat comes from this list: https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Pin_names_for_Duet_2_WiFi_Ethernet
@Phaedrux so I talked with @bearer and he explained this and we tested my wiring across E1vin and mains negative. Fan worked, wiring correct.
1.) Then I hooked up fan negative to E1negative and changed the config line u said above.
Powered up and nothing, using fan control on both DWC and PanelDue are non responsive. my E1 LED is not lighting up. It’s almost like we forgot to associate something? Ideas?2.) Also, we’re you able to see anything in the config I posted that would suggest why my probe isn’t working and why my homing isn’t working?
3.) Lastly, I’ve tested X,Y,Z movement. Y & Z work as expected. But X only moves in the negative direction (left as it is configured currently) it does not respond when asked to move +x. Does this mean I swapped one of my stepper wire pairs? How do i identify and test that without blowing something up?
