    Possible PWM port issue & RRF3 Question
    1.4k
      @bearer said in Possible PWM port issue & RRF3 Question:
      heat and/or high currents are the common culprits with dead mosfets - usually a result of a short circuit somewhere.
      Connecting a fan the wrong way round (i.e. wrong polarity) can also cause a mosfet to blow, depending on the fan.
      jallen810undefined 1 Reply Last reply Reply Quote 0
      • jallen810undefined
        jallen810 @dc42
        @dc42 Okay. I was very diligent to mark + & - wires when extending my wiring and tested continuity to make sure, which is why the first test was fine. I had it correct.
        Then yesterday all of the sudden all three just stopped working, nothing in the wiring changed.
        So... I have a question, why are the PWM fan ports not protected by a fuse? The only issues I have ever had with this board has been these MOSFETs . I love this board, but this is a serious Debbie Downer...
        And my question still stands, if I blew the MOSFETs then why do I measure voltage change when I toggle the F0 or F1 ports with M126? Last time this happened to me with a clone board, I read 0 volts, and I learned my lesson to triple check everything before plugging back in and powering up
        What are my options here?
        1.) Could this be a bad board that I could get replaced under warranty? Purchase was in April2020 via Filastruder
        2.) Can a [DueX2 expansion](https://www.filastruder.com/collections/electronics/products/duex2-and-duex-5-expansion-board[link text](link url)) allow me to get PWM functionality back?
        3.) Or could just this Expansion Board give me a couple PWM ports back?
        4.) am I missing something else that's affordable?????
          Your easiest option would be as bearer suggested above and remap a spare heater output as a PWM fan control.
          If you have already upgraded to RRF3 it's quite easy. You'll need to identify what heater port you want to use, find it's pin name, and then use M950 to define that pin as a fan. Then your M106 fan command can refer to it.
          I think when you extended the wiring there was either a short or a change to polarity that caused the mosfet to fail. Perhaps at a crimp there was a stray wire?
          @jallen810 said in Possible PWM port issue & RRF3 Question:
          They are, but as described the fuse is much too slow to protect from the initial surge. Fuses are meant to protect from a short circuit drawing too much current and setting something on fire. The mosfets are unfortunately delicate, so great care must be taken with fan wiring. And even when great care is taken, I've even seen fans from amazon that had the black and red wires switched. Peeling back the label to show the fan PCB revealed that the black and red wired were swapped at the - + silk screen terminals.
            jallen810 @Phaedrux
            @Phaedrux Okay. I just finished the upgrade to RRF3.
            So by doing this M950+M160, I will be able to have a layer fan that is controllable by Gcode? and a thermostatically controlled HE fan?
            Lastly, now that I've finished my RRF3.1 upgrade I get these 2 issues:
            1.) My inductive probe (NC) isn't stopping now when I do a G30 and put a wrench under it
            2.) and when I try to home X or Y, the head moves 5-10 mm and stops?
            Can you point me to a page that explains the RRF settings for these sensors? It used to be this in my config.g for RRF2.x:
            M574 X1 Y1 S0                        		   ; set active low and disabled endstops (To enable Z-endstop add "Z1 or Z2" after y
            M574 Z1 S2                                         ; Define Z to use probe. S2=Home to min
            and  for my ABL:
            M307 H3 A-1 C-1 D-1      ; (Duet3d method)  disable Heater7 to free up PWM channel 5 on Duex board for BLTouch
            M558 P5 H5 F600 A1 I1	; GLH8 EndstopABL, Mode P=5, StartProbeH=5mm, Speed=600mm/min, #probes A=3, Invert signal for Endstop I=1
            A Former User? Phaedruxundefined 2 Replies Last reply Reply Quote 0
              A Former User @jallen810
              one of them if you have heater E1 unused; so I'd wire hotend to always on and layer to heater E1 output.
                jallen810 @A Former User
                @bearer okay so that works for me! I've already moved my HE fan to always on.
                Just for future plans sake, if I decide I need more PWM fans, can I get either the expansion board with 2pwm ports or a Duex2/5 and restore my PWM function with those?
                Or does the main board damage prevent me from doing that?
                  can't say for sure but most likely that damage is isolated to the the mosfets for the fans (mosfets can be replaced, its a bit of a tight spot and some groundplanes, but with proper tools its perfectly doable; you can ask around locally or maybe https://forum.duet3d.com/topic/13875/community-repairs)
                  as for the expansion breakout i don't think you drive a fan off that directly. duex2/5 will be fine.
                    Phaedrux Moderator @jallen810
                    and  for my ABL:
                    The issue is probably the inversion in M558 for the probe trigger signal. I1 is replaced in RRF3 by using a ! in front of the pin name.
                    I suggest you use the configurator to generate a config for RRF3 and then compare the output to your own to see the differences.
                    https://configtool.reprapfirmware.org/Start
                    This document also has the best overview of the changes.
                    https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
                      jallen810 @Phaedrux
                      @Phaedrux that is the RRF Config output! Lol That’s why I was confused. I could have selected the wrong setting somewhere.
                      Thanks for the link, I’ll dig in after the kiddos go to bed.
                        jallen810
                        @Phaedrux When you tag into E1 heater and Heater 7, just to clarify, I would hook up to E1 to the positive lead to fan. Then I would hook up "13) heater4" (as an example) pin to the negative lead of the fan?
                          Post your config.g then. Maybe you had RRF2 selected?
                          I'm not sure what you mean by this.
                            jallen810 @Phaedrux
                            @Phaedrux I had a blonde moment, I can't use a normal 2pin fan can I?
                            I need a 3+ wire fan right? (sorry never actually used PWM function of fans before)
                            My artillery sidewinder specs:
                            Xaxis: homes at 0, left side (Panasonic GL8H optical NPN NC sensor)
                            Yaxis: homes at back, but 0 is actually at the front (Panasonic GL8H optical NPN NC sensor)
                            Z = Inductive ABL probe (Panasonic GXHL15A NPN NC sensor)
                            Lastly, here is my RRFconfigurator custom config.g for RRF3.1:
                            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Aug 15 2020 15:29:14 GMT-0400 (EDT)
                            G90                                                       ; send absolute coordinates...
                            M83                                                       ; ...but relative extruder moves
                            M550 P"Sidewinder X1 RRF3"                                ; set printer name
                            M552 S0
                            M552 S1 P192.168.1.50				   ; Assign fixed IP address
                            M553 P255.255.255.0				   ; Assign Netmask to match my network
                            M554 P192.168.1.1				   ; Assign Gateway IP address to match network
                            M552 S1                                                   ; enable network
                            M586 P0 S1                                                ; enable HTTP
                            M586 P1 S0                                                ; disable FTP
                            M586 P2 S0                                                ; disable Telnet
                            M569 P0 S1                                                ; physical drive 0 goes forwards
                            M569 P1 S0                                                ; physical drive 1 goes backwards
                            M569 P2 S0                                                ; physical drive 2 goes backwards
                            M569 P3 S0                                                ; physical drive 3 goes backwards
                            M584 X0 Y1 Z2 E3                                          ; set drive mapping
                            M350 X16 Y16 Z16 E16 I1                                   ; configure microstepping with interpolation
                            M92 X80.00 Y80.00 Z400.00 E415.00                         ; set steps per mm
                            M566 X900.00 Y900.00 Z60.00 E1200.00                      ; set maximum instantaneous speed changes (mm/min)
                            M203 X9000.00 Y9000.00 Z1500.00 E3000.00                  ; set maximum speeds (mm/min)
                            M201 X500.00 Y500.00 Z20.00 E166.67                       ; set accelerations (mm/s^2)
                            M906 X800 Y800 Z800 E800 I30                              ; set motor currents (mA) and motor idle factor in per cent
                            M84 S30                                                   ; Set idle timeout
                            M208 X0 Y0 Z0 S1                                          ; set axis minima
                            M208 X300 Y340 Z400 S0                                    ; set axis maxima
                            M574 X2 S1 P"xstop"                                       ; configure active-high endstop for high end on X via pin xstop
                            M574 Y2 S1 P"ystop"                                       ; configure active-high endstop for high end on Y via pin ystop
                            M574 Z2 S2                                                ; configure Z-probe endstop for high end on Z
                            M558 P1 C"zprobe.in" H5 F600 T6000                        ; set Z probe type to unmodulated and the dive height + speeds
                            G31 P1000 X40 Y-41 Z2.5                                   ; set Z probe trigger value, offset and trigger height
                            M557 X45:295 Y10:280 S40                                  ; define mesh grid
                            M308 S0 P"bedtemp" Y"thermistor" T100000 B4138            ; configure sensor 0 as thermistor on pin bedtemp
                            M950 H0 C"bedheat" T0                                     ; create bed heater output on bedheat and map it to sensor 0
                            M307 H0 B1 S1.00                                          ; enable bang-bang mode for the bed heater and set PWM limit
                            M140 H0                                                   ; map heated bed to heater 0
                            M143 H0 S130                                              ; set temperature limit for heater 0 to 130C
                            M308 S1 P"e0temp" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin e0temp
                            M950 H1 C"e0heat" T1                                      ; create nozzle heater output on e0heat and map it to sensor 1
                            M307 H1 B0 S1.00                                          ; disable bang-bang mode for heater  and set PWM limit
                            M950 F0 C"fan0" Q500                                      ; create fan 0 on pin fan0 and set its frequency
                            M106 P0 C"Layer Fan 1" S0 H-1                             ; set fan 0 name and value. Thermostatic control is turned off
                            M950 F1 C"fan1" Q500                                      ; create fan 1 on pin fan1 and set its frequency
                            M106 P1 C"HE Fan 2" S1 H1 T45                             ; set fan 1 name and value. Thermostatic control is turned on
                            M563 P0 D0 H1 F0                                          ; define tool 0
                            G10 P0 X0 Y0 Z0                                           ; set tool 0 axis offsets
                            G10 P0 R0 S0                                              ; set initial tool 0 active and standby temperatures to 0C
                            M575 P1 S1 B57600                                         ; enable support for PanelDue
                            M501                                                      ; load saved parameters from non-volatile memory
                            M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"        ; set voltage thresholds and actions to run on power loss
                            and for reference, here is the back up of the RRF2.03. config.g that I made just before updating to RRF3 this afternoon:
                            ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat Apr 11 2020 14:47:32 GMT-0400 (Eastern Daylight Time)
                            ; Revised by Jake Allen on 4.18.2020 @ 10:30am EST
                            ;-----General preferences-----------------------------------------------------------------------------------------------------------------
                            M550 P"Sidewinder X1"                              ; set printer name
                            ;-----Network----------------------------------------------------------------------------------------------------------------------------
                            M552 S0
                            ;M552 S1 P192.168.1.50				   ; Assign fixed IP address
                            ;-----Drives-----------------------------------------------------------------------------------------------------------------------------
                            M569 P0 S0 D2                                	   ; (X-Axis) drive 0 goes forwards (Jake wrong config M569 P0 S1)
                            M569 P1 S1 D2	 	                           ; (Y-Axis) drive 1 goes forwards
                            M569 P2 S1 D2                                      ; (Z-Axis) drive 2 goes forwards
                            M569 P3 S1 D2                                      ; (Extruder) drive 3 goes backward with Bondtech (titan = S0, Bondtech = S1)
                            M350 X16 Y16 Z16 E16 I1                            ; configure micro-stepping with interpolation
                            M92 X80.12 Y80.12 Z399.78 E415.0                   ; set steps per mm (from Jake's Marlin Setup) (titan=446mm)
                            M566 X800.00 Y980.00 Z60.00 E2500.00               ; set maximum instantaneous speed changes (mm/min) --> E180 to E2500, Z12 to Z60
                            M203 X9000.00 Y9000.00 Z1500.00 E3000.00           ; set maximum speeds (mm/min) --> X&Y from 6000 (100mm/s) to 9000 (150mm/s)
                            M201 X800.00 Y800.00 Z400.00 E10000.00               ; set accelerations (mm/s^2) E10000
                            ;-----Axis Limits------------------------------------------------------------------------------------------------------------------------
                            M208 X300 Y340 Z400 S0                             ; set axis maxima (Changed Y from 300 to 345 to compensate for offset)
                            ;-----Endstops---------------------------------------------------------------------------------------------------------------------------
                            ;-----Z-Probe (BLtouch)------------------------------------------------------------------------------------------------------------------
                            M558 P5 H5 F600 A1 I1	; GLH8 EndstopABL, Mode P=5, StartProbeH=5mm, Speed=300mm/min, #probes A=3, Invert signal for Endstop I=1
                            ;BLTOUCH; M558 P9 H5 F100 T9000  ; (Duet3D method) P=Select Z-probe mode=9 BLtouch. H=DiveHeight abv bed(mm), F=Speed bed moves, T=TravelSpeed btwn pts
                            G31 P25 X40 Y-41 Z1.385	   ; P=Z probe trigger value,X&Y=offset mount relative to nozzle (mm), Z=trigger height 1.84
                            ;(4020 Mosquito J&L Mount + HL15 Zoff=0.7mm, x=40, y=-41)
                            ;(M18 probe,z=1.85mm, x=40, y=-50)
                            ;Stock z-end=0.58
                            ; Change P500 to P25 and X&Y=0 to X=40 & Y=-38 for probe offset vs. nozzle (3DChanh X58 Y-36)
                            M557 X45:295 Y10:280 S40                    ; define mesh grid (S20 = 143 points, S45 = 36pts) (Prev: M557 X15:285 Y15:285)
                            					   ; Change X0:225 Y45:300 S45 to--> M557 X60:300 Y0:260 S20, S20=156pts, try S24 & S40 =100 & 36pts, Previously S=30
                            ;-----Heaters----------------------------------------------------------------------------------------------------------------------------
                            M140 H0                                            ; remap heated bed to heater 1
                            M305 P0 T100000 B4138 R4700                        ; set Bed thermistor + ADC parameters for heater 0
                            M143 H0 S125                                       ; set temperature limit for heater 0 to 125C
                            ;M305 P1 T100000 B4138 R4700                       ;104GT E3D thermistor set thermistor + ADC parameters for heater 1
                            M305 P1 T500000 B4723 C1.196220e-7 H20      	   ; Slice Engr 450°C thermistor Set thermistor +ADC parameters for H1
                            M143 H1 S320                                       ; set temperature limit for heater 1 to 300C
                            ;-----Fans--------------------------------------------------------------------------------------------------------------------------------
                            M106 P1 S0 H-1 C"Layer_Fan" F500			; Part Cool Layer Fan (8.14.20 blew Mosfets, some cntl Fan1 port so remapped)
                            ;M106 P1 S1 H1 T45 C"Heatsink_Fan" F500			; Hotend Heatsink Fan
                            ;M106 P2 S0.75 H0 T45 C"BoardCool" F500			; Ducted 4020 DuetBoard Cooling Fan, Bed=45c turn on fan 75%
                            ;-----Tools-------------------------------------------------------------------------------------------------------------------------------
                            M563 P0 S"HOTEND" D0 H1 F1                         ; define tool 0 (8.14.20 change from F0 to F1 bc of blown mosfet remap)
                            ;-----Miscellaneous-----------------------------------------------------------------------------------------------------------------------
                            T0                                                 ; select first tool
                              to use with E1 output? you can use 2 pin fan. 3pin fans have tachometer for RPM feedback, 4pin fans have PWM input but i'd hesitate to drive the PWM input from a pin on the duet without doin some research
                                @bearer okay so @Phaedrux said I can tag into the E1 heater for the 24v and then pick a heater pin on the expansion slot. My question is how do I actually physically wire this thing up?
                                Red wire [from fan +V] ---> Heater4 (pin13)
                                Black wire [from fan -V] ----> E1+24v
                                Like this:
                                  dc42 administrators @jallen810
                                  They are, on version 1.03 and later boards... but sadly fuses blow much more slowly than mosfets do.
                                  On later production we've switched to mosfets with a higher peak current rating, although that's unlikely to help when the output is shorted.
                                    both wires to E1 output if the fan is 24v.
                                    red wire to Vin
                                    black wire to E1-
                                    (E1- is switched to ground when the output is enabled, to use heater4 or any of the other pins on the expansion you'll need an external mosfet to sink more current than the microcontroller can handle)
                                      Just in case it wasn't totally clear, both fan wires will go the the E1 heater connector.
                                      Then in your config.g you would need the follow assuming you're going to use it as Fan0.
                                      Where you have: M950 F0 C"fan0" Q500 you would change it to M950 F0 C"e1heat" Q500
                                      The pin name e1heat comes from this list: https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Pin_names_for_Duet_2_WiFi_Ethernet
                                        jallen810 @Phaedrux
                                        @Phaedrux so I talked with @bearer and he explained this and we tested my wiring across E1vin and mains negative. Fan worked, wiring correct.
                                        1.) Then I hooked up fan negative to E1negative and changed the config line u said above.
                                        Powered up and nothing, using fan control on both DWC and PanelDue are non responsive. my E1 LED is not lighting up. It’s almost like we forgot to associate something? Ideas?
                                        2.) Also, we’re you able to see anything in the config I posted that would suggest why my probe isn’t working and why my homing isn’t working?
                                        3.) Lastly, I’ve tested X,Y,Z movement. Y & Z work as expected. But X only moves in the negative direction (left as it is configured currently) it does not respond when asked to move +x. Does this mean I swapped one of my stepper wire pairs? How do i identify and test that without blowing something up?
                                          Can you post the changes you've made for the fan?
                                          Well your probe settings from your 3.1.1 and 2.03 are very different. One is using probe type P1 and the other P5. What I'm not familiar with probe you list, but if it worked with P5 before it should work with P5 in RRF3. So try to compare and match your settings. The only major difference between RRF2 and RRF3 there is the pin name is now included in the M558.
                                          For your x movement problem, it could be a case of motor rotation direction or incorrect homing switch location.
                                          In your 2.03 config your endstops are configured as low end, but in your 3.1.1 config you have them listed as high end. Which is it?
                                            jallen810 @Phaedrux
                                            @Phaedrux i tested the TR8 mosfet for E1 and i only get 4.5v out of it. my guess it was also blown. @bearer is helping setup external mosfets to control my fans via the 50pin expansion header. I think i am set there.
                                            I played with the probe settings after noticing the same things u just mentioned.
                                            I tried both probe types 1 & 5, I tried inverting the signal with a "!" in front of the C var, i tried changing the end stops for XYZ from 0, 1, 2.
                                            Nothing works, the only thing i notice is the probe reading is 1000 for P1 and 983 for P5 when no metal is present (probe light off). When i put a metal object under it, the reading drops to ~20.
                                            It acts this way for every permutation of the above code changes.
                                            I know this, my optical sensors were wired in RRF2 to the same pin as they are now, just ~1m extra wire in between. These sensors have to run 5v+, not 3.3v per the way the OEM wired them. But if i download the sensor Mfgr's data sheet it says, it needs 12-24v in. GL_8H Sidewinder X1 Endstops Data Sheet.pdf
                                            Do you suppose the extra length of wire causes enough resistance that the 5v that previously worked, now is not sufficient? If so, i could re-wire to pull off the main's power in... just a lot of extra work that i may not need to do...
