    hbot homes correctly but prints mirrored ,
    8.8k
    • peter247undefined
      peter247 @tracar
      @tracar
      So we did it in the end ? .
      Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
      • tracarundefined
        tracar
        no
        homing x and y travels to the correct corner and has been fixed,
        the only thing that is wrong is the y axis movement, ONLY after it has been homed.
        peter247undefined 1 Reply Last reply Reply Quote 0
        • peter247undefined
          peter247 @tracar
          @tracar
          Have you done this to your homing file Y and All ?
          BOTH , Remove ALL the minus sign for Y
          eg G1 H1 Y-540 F1800 to just G1 H1 Y540 F1800
          Change all the positive Y to a minus
          G1 Y5 F800 to G1 Y-5 F800
          So really invert anything use the Y axis , ONLY THE Ys NOT THE X or Zs
          • tracarundefined
            tracar
            i have, problem is when i change thoes it messes with the direction of x, and no matter what direction i change the steppers via the switch x or y is always in the wrong direction
            • peter247undefined
              peter247 @tracar
              @tracar
              ONLY CHANGE Y .. Leave x and z alone .
              tracarundefined 1 Reply Last reply Reply Quote 0
              • tracarundefined
                tracar @peter247
                @peter247
                yes only changed all the y stuff
                • peter247undefined
                  peter247 @tracar
                  @tracar
                  and just Y motor direction ?
                  • tracarundefined
                    tracar
                    changing the y info only affects the homing direction of the y axis , yes
                    so changing it the way you want makes the y axis home away from the endstop
                    • tracarundefined
                      tracar
                      this would be so much easier if the x and y steppers were not working together to move the x/y "coreXY"
                      • peter247undefined
                        peter247 @tracar
                        @tracar
                        Changing the Home file swaps the direction and goes away from the end stop , so you change the direction of the motor to fix it.
                        The old homing file say move to the front , but the motor direction is wrong too , so to head to the back , which you call correct homing .
                        But you need to tell to head to the back and change the direction of the motors too , you need to change both at the same time.
                        • tracarundefined
                          tracar
                          the homing directions are all correct, its only after its homed that y motion is backwards,,, so when i am on the web gui and manually click on the y+ or - in the machine movement section the movement is opposite in only the y axis
                          • peter247undefined
                            peter247 @tracar
                            @tracar
                            So have you inverted all your homing files for y ?
                            eg G1 H1 Y-540 F1800 to G1 H1 Y540 F1800
                            • tracarundefined
                              tracar @peter247
                              @peter247
                              if i do that then y homing is reversed too, along with y manual travel
                              • tracarundefined
                                tracar
                                if i change a motor direction by the switch or cable conection, then it messes up x axis too
                                • peter247undefined
                                  peter247 @tracar
                                  @tracar said in hbot homes correctly but prints mirrored ,:
                                  yes so swap the motor direction ... Please read the last 10 post ?
                                  I REPEAT
                                  the old homing file say move to the front , but the motor direction is wrong too , so to head to the back , which you call correct homing .
                                  Change both !!!
                                  • tracarundefined
                                    tracar
                                    changed both stepper directions. now y is correct in every way and x is reversed with homing, and x manual travel is also reversed
                                    peter247undefined 2 Replies Last reply Reply Quote 0
                                    • peter247undefined
                                      peter247 @tracar
                                      @tracar
                                      Both stepper direction ... NO JUST Y .
                                      LEAVE X and Z alone .
                                        Follow this for testing corexy motor movement.
                                        https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Testing_motor_movement
                                        This is key for Corexy.
                                        Sounds like you got the endstops and homing directions working correctly. This last test will tell you how to get the motors going correctly. It's a bit different because of corexy using two motors together for motion.
                                        • peter247undefined
                                          peter247 @Phaedrux
                                          @Phaedrux
                                          So I'm lost about corexy , can he just change the y motor direction ?
                                          or is it me who is wrong ?
                                            Phaedrux Moderator @peter247
                                            @peter247 said in hbot homes correctly but prints mirrored ,:
                                            The link answers all.
