    Duet WiFi with external antenna
    20
    2.5k
    • Wyvernundefined
      Wyvern
      I was having almost 0 connectivity with the ACM material over the board, it's fine without it so I had to print plastic covers.
      It would be great to a have a little IPX connector whip you can drill or stick to the outside of the printer, however it needs to be safeguarded from powering it on without a whip or a whip that has been compromised.
      I've got FPV background with 2.4/5.8ghz TX/RX's, 2.4ghz is a very unforgiving SOB- I've lost a $1700 custom build drone and $1000 camera in a lake due to a loose TX antenna- I don't fly photography tanks anymore because of that (can't afford to start again anyway)
      • pabomanundefined
        paboman
        Having the WiFi module on a socket will be a perfect solution, at least for me.
          We plan to offer the Duet WiFi in internal and external antenna versions. The external antenna version will cost a little more.
          pabomanundefined 1 Reply Last reply Reply Quote 0
          • pabomanundefined
            paboman @dc42
            @dc42 great news!
            when do you plan to make it available for purchase?
              dc42 administrators @paboman
              @paboman said in Duet WiFi with external antenna:
              @dc42 great news!
              Currently we're trying to increase production rate (again!) to meet demand. The current bottleneck is testing, but our automated test equipment is nearly ready (I spent some of last week running rejected Duets through it). When we have some reserve stock of the standard Duet WiFi and Duet Ethernet, we'll add the Duet WiFi variant with external antenna as an additional stock item. Meanwhile it's available as a special order item for OEM bulk orders, but we have to tie such orders in with our production schedule because it isn't yet a stock item.
              • PCRundefined
                PCR
                Converted a Duet 2 WiFi to ESP07s. Easy!
                118435178_1502383686632392_8554751055714597104_n.jpg 118443304_362614461404305_7829147893996331746_n.jpg
                whosrdaddyundefined 1 Reply Last reply Reply Quote 2
                • whosrdaddyundefined
                  whosrdaddy @PCR
                  @PCR Nice work!
                  I suppose you did use hot air to remove the Wifi module?
                  • PCRundefined
                    PCR
                    Yep. Hot air gun.
                    But it should be possible with a thick copper wire too. See:
                    https://www.youtube.com/watch?v=CVsmwFAkf7I
                    • PCRundefined
                      PCR
                      I made and blog post about desoldering without a hotairgun
                      CLICK HERE
                      • mikestanley464undefined
                        mikestanley464
                        Duet2WiFi External Antenna
                        Powerful 32 Bit Processor.
                        Dedicated Wifi module.
                        Super quiet TMC2660 stepper drivers, up to 256 microstepping.
                        High speed SD card and support for a second SD external card if required.
                        VidMate VidMate app
                        Canli mac izle
                        • PCRundefined
                          PCR
                          @mikestanley464 said in Duet WiFi with external antenna:
                          😉 But some already have an duet 2 WiFi with the "normal" modul!
                          mikestanley464undefined 1 Reply Last reply Reply Quote 0
                            mikestanley464 @PCR
                            @PCR right 😛 my bad..... ..
                            VidMate VidMate app
                            Canli mac izle
                            Exerqtorundefined 1 Reply Last reply Reply Quote 0
                            • Exerqtorundefined
                              Exerqtor @mikestanley464
                              @mikestanley464
                              OT, but: Wow, that's one hell of a response time 🤣🤣🤣
