    Duet WiFi with external antenna
    20
    2.5k
    • RCarlyleundefined
      RCarlyle
      Any thoughts on this being a regular product? I know people (like myself) have been interested in the past.
        T3P3Tony administrators @RCarlyle
        @rcarlyle we are considering it but it puts the cost up.
        Just out of interest we had a few of the previous pcb revision made up with the 07S and external antenna. We have listed those for sale until stocks run out:
        https://www.duet3d.com/DuetWifiSale
        • Biggsisundefined
          Biggsis
          Just curious, is this still the plan to offer Duets with better Wifi?
          I am sometimes experiencing some signal strength problems with the Wifi and you guys mentioned an option with ESP-07.
          We would require 2 Duet Wifi boards with external antenna too, since the boards would be within a metal case.
          We would anyway appreciate, if in the long term the Duet Wifi could be ordered with the ESP-07 as an option.
          Thanks in advance
          Hypercube Evolution User Group : https://www.facebook.com/groups/Hypercubeevolution/
          Kossel Delta XL / XXL User Group : [https://www.facebook.com/groups/KosselXXL/]
          • Wyvernundefined
            Wyvern
            I was having almost 0 connectivity with the ACM material over the board, it's fine without it so I had to print plastic covers.
            It would be great to a have a little IPX connector whip you can drill or stick to the outside of the printer, however it needs to be safeguarded from powering it on without a whip or a whip that has been compromised.
            I've got FPV background with 2.4/5.8ghz TX/RX's, 2.4ghz is a very unforgiving SOB- I've lost a $1700 custom build drone and $1000 camera in a lake due to a loose TX antenna- I don't fly photography tanks anymore because of that (can't afford to start again anyway)
            • pabomanundefined
              paboman
              Having the WiFi module on a socket will be a perfect solution, at least for me.
                We plan to offer the Duet WiFi in internal and external antenna versions. The external antenna version will cost a little more.
                pabomanundefined 1 Reply Last reply Reply Quote 0
                • pabomanundefined
                  paboman @dc42
                  @dc42 great news!
                  when do you plan to make it available for purchase?
                    dc42 administrators @paboman
                    @paboman said in Duet WiFi with external antenna:
                    @dc42 great news!
                    Currently we're trying to increase production rate (again!) to meet demand. The current bottleneck is testing, but our automated test equipment is nearly ready (I spent some of last week running rejected Duets through it). When we have some reserve stock of the standard Duet WiFi and Duet Ethernet, we'll add the Duet WiFi variant with external antenna as an additional stock item. Meanwhile it's available as a special order item for OEM bulk orders, but we have to tie such orders in with our production schedule because it isn't yet a stock item.
                    • PCRundefined
                      PCR
                      Converted a Duet 2 WiFi to ESP07s. Easy!
                      118435178_1502383686632392_8554751055714597104_n.jpg 118443304_362614461404305_7829147893996331746_n.jpg
                      whosrdaddyundefined 1 Reply Last reply Reply Quote 2
                      • whosrdaddyundefined
                        whosrdaddy @PCR
                        @PCR Nice work!
                        I suppose you did use hot air to remove the Wifi module?
                        • PCRundefined
                          PCR
                          Yep. Hot air gun.
                          But it should be possible with a thick copper wire too. See:
                          https://www.youtube.com/watch?v=CVsmwFAkf7I
                          • PCRundefined
                            PCR
                            I made and blog post about desoldering without a hotairgun
                            CLICK HERE
                            • mikestanley464undefined
                              mikestanley464
                              Duet2WiFi External Antenna
                              Powerful 32 Bit Processor.
                              Dedicated Wifi module.
                              Super quiet TMC2660 stepper drivers, up to 256 microstepping.
                              High speed SD card and support for a second SD external card if required.
                              VidMate VidMate app
                              Canli mac izle
                              • PCRundefined
                                PCR
                                @mikestanley464 said in Duet WiFi with external antenna:
                                😉 But some already have an duet 2 WiFi with the "normal" modul!
                                mikestanley464undefined 1 Reply Last reply Reply Quote 0
                                  mikestanley464 @PCR
                                  @PCR right 😛 my bad..... ..
                                  VidMate VidMate app
                                  Canli mac izle
                                  Exerqtorundefined 1 Reply Last reply Reply Quote 0
                                  • Exerqtorundefined
                                    Exerqtor @mikestanley464
                                    @mikestanley464
                                    OT, but: Wow, that's one hell of a response time 🤣🤣🤣
