    Impossible to set extruder micro stepping above 16ms
    39
    1.8k
    • JoergS5undefined
      JoergS5 @observatoer
      @observatoer you seem to use IdeaMaker, is there something in the startup code which could change E?
      https://forum.raise3d.com/viewtopic.php?t=12893
      https://support.raise3d.com/ideaMaker/5-1-3-13-gcode-15-445.html
      especially the "Extruder Switch GCode tab". Lot of places to change something...
      observatoerundefined 1 Reply Last reply Reply Quote 0
      • observatoerundefined
        observatoer @JoergS5
        @JoergS5 Thanks for the hint, but I have removed all the default settings in Ideamaker from the start code and call a start macro on the duet3. This is all that remains:
        M98 P"0:/sys/print/start.g" ; call start.g
        M290 R0 S0 ;reset babystepping
        M290 S-0.05 ; set babystepping height delta
        M572 D0 S0.025 ;set pressure advance
        And nothing in the extruder level. Totally empty.
        • JoergS5undefined
          @observatoer next I would check content of start.g and if babystepping or pressue advance change the E by disabling them.
            @JoergS5 Looks OK to me.
            G29 S1 P"heightmap.csv" ; Load the height map from file and activate bed compensation.
            G90 ; use absolute coordinates
            M83 ; extruder relative mode
            M98 P"0:/sys/G828.g" ; home if not homed
            M98 P"0:/sys/G832.g" ; if not already leveled, level bed and re-home Z
            ; prime nozzle
            G1 X0 Y0 F99999.0 ; Go home
            G1 Z0.15 ; lower extruder
            G1 X2 Y20 Z0.3 F5000.0 ; move to start-line position
            G1 X2 Y200.0 Z0.3 F1500.0 E15 ; draw 1st line
            G1 X2 Y200.0 Z0.4 F5000.0 ; move to side a little
            G1 X3 Y20 Z0.4 F1500.0 E30 ; draw 2nd line
            G92 E0.0
            And the two calls look clean, too:
            ; G828.g
            ; Conditional variant of G28 home command.
            ; Homes all axes if not already homed.
            if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
            G28
            ; G832.g
            ; Conditional variant of G32 bed command.
            ; Perform bed leveling if not already leveled.
            if move.calibration.numFactors == 0 ; if leveling has not yet been performed...
            G32 ; level bed
            G28 Z ; re-home Z
            else
            echo "Bed already leveled. Skipping..."
            • JoergS5undefined
              @observatoer then I have no more ideas at the moment. I would remove and disable or comment out all and readd step by step to find the reason. It is also possible that there is a bug somewhere, because you have a lot of settings, macros etc. To be sure it's not IdeaMaker I would try a different program and g-code file first.
                @JoergS5 Thank you for your time and hints!
                JoergS5undefined 2 Replies Last reply Reply Quote 0
                • JoergS5undefined
                  @observatoer sorry that I could not help. I think it's something trivial, a syntax error e.g., but I didn't see one.
                  Maybe M350 E16 I0 changing the E without interpolation behaves other than expected. You could try changing it to I1 as a test.
                  • JoergS5undefined
                    @observatoer I have one more idea: according the information in some threads like https://forum.duet3d.com/topic/4939/m350-not-working-wrt-m584/6 the order of the drives seem to play a role in the M584 command. In you config you have E first, so this may not be seen as an extruder drive in some code for other program parts. You could try changing
                    M584 E0 X1 Y2 Z3:4:5
                    to
                    M584 X1 Y2 Z3:4:5 E0
                      If anyone thinks that M350 is not behaving as described in the wiki GCodes page, please supply files that replicate the different behaviour.
                        @JoergS5 That would make sense and I will give it a try. Stii the change will be a bag of hurt to get the order of the z drives and the related measurements for ABL right.
                        Thank you very much for your help! I will report, how this turns out.
                          observatoer @dc42
                          @dc42 I guess, this tread is full of all related logs and describes the issue in detail. Still I understand, it's a pain to go thru the logs.
                            One of the reports says that the steps/mm changes when starting a print, but I didn't see a print file posted. Also, the config files have changed, so it's hard to be sure what the current ones look like.
                              observatoer @dc42
                              @dc42 Thank you, this was the right question.
                              Ideamaker is setting the E value to 822s/mm and writes this at the beginning of the code.
                              That was the reason, why this issue came up.
                              Thanks again and I guess, the solution is found.
