    Impossible to set extruder micro stepping above 16ms
    39
    1.6k
    • JoergS5undefined
      JoergS5 @observatoer
      @observatoer next I would check content of start.g and if babystepping or pressue advance change the E by disabling them.
      observatoerundefined 1 Reply Last reply Reply Quote 0
      • observatoerundefined
        observatoer @JoergS5
        @JoergS5 Looks OK to me.
        G29 S1 P"heightmap.csv" ; Load the height map from file and activate bed compensation.
        G90 ; use absolute coordinates
        M83 ; extruder relative mode
        M98 P"0:/sys/G828.g" ; home if not homed
        M98 P"0:/sys/G832.g" ; if not already leveled, level bed and re-home Z
        ; prime nozzle
        G1 X0 Y0 F99999.0 ; Go home
        G1 Z0.15 ; lower extruder
        G1 X2 Y20 Z0.3 F5000.0 ; move to start-line position
        G1 X2 Y200.0 Z0.3 F1500.0 E15 ; draw 1st line
        G1 X2 Y200.0 Z0.4 F5000.0 ; move to side a little
        G1 X3 Y20 Z0.4 F1500.0 E30 ; draw 2nd line
        G92 E0.0
        And the two calls look clean, too:
        ; G828.g
        ; Conditional variant of G28 home command.
        ; Homes all axes if not already homed.
        if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
        G28
        ; G832.g
        ; Conditional variant of G32 bed command.
        ; Perform bed leveling if not already leveled.
        if move.calibration.numFactors == 0 ; if leveling has not yet been performed...
        G32 ; level bed
        G28 Z ; re-home Z
        else
        echo "Bed already leveled. Skipping..."
        • JoergS5undefined
          @observatoer then I have no more ideas at the moment. I would remove and disable or comment out all and readd step by step to find the reason. It is also possible that there is a bug somewhere, because you have a lot of settings, macros etc. To be sure it's not IdeaMaker I would try a different program and g-code file first.
            @JoergS5 Thank you for your time and hints!
            JoergS5undefined 2 Replies Last reply Reply Quote 0
            • JoergS5undefined
              @observatoer sorry that I could not help. I think it's something trivial, a syntax error e.g., but I didn't see one.
              Maybe M350 E16 I0 changing the E without interpolation behaves other than expected. You could try changing it to I1 as a test.
              • JoergS5undefined
                @observatoer I have one more idea: according the information in some threads like https://forum.duet3d.com/topic/4939/m350-not-working-wrt-m584/6 the order of the drives seem to play a role in the M584 command. In you config you have E first, so this may not be seen as an extruder drive in some code for other program parts. You could try changing
                M584 E0 X1 Y2 Z3:4:5
                to
                M584 X1 Y2 Z3:4:5 E0
                  If anyone thinks that M350 is not behaving as described in the wiki GCodes page, please supply files that replicate the different behaviour.
                    @JoergS5 That would make sense and I will give it a try. Stii the change will be a bag of hurt to get the order of the z drives and the related measurements for ABL right.
                    Thank you very much for your help! I will report, how this turns out.
                      observatoer @dc42
                      @dc42 I guess, this tread is full of all related logs and describes the issue in detail. Still I understand, it's a pain to go thru the logs.
                        One of the reports says that the steps/mm changes when starting a print, but I didn't see a print file posted. Also, the config files have changed, so it's hard to be sure what the current ones look like.
                          observatoer @dc42
                          @dc42 Thank you, this was the right question.
                          Ideamaker is setting the E value to 822s/mm and writes this at the beginning of the code.
                          That was the reason, why this issue came up.
                          Thanks again and I guess, the solution is found.
