    Impossible to set extruder micro stepping above 16ms
    39
    1.8k
    • observatoerundefined
      observatoer @droftarts
      @droftarts OK. I refer to https://duet3d.dozuki.com/Wiki/Gcode#Section_M350_Set_microstepping_mode
      and this description:
      When M350 is processed, the steps/mm will be adjusted automatically to allow for any changes in microstepping. Therefore you can either:
      a) Set Steps/mm correctly for the default 1/16 microstepping, then set the microstepping to the desired amount using M350:
      M92 X80 Y80 Z400 ; set axis steps/mm
      M92 E420:430 ; set extruder 0 and 1 steps/mm
      M350 X128 Y128 Z128 E128:128 ; set microstepping
      or
      b) Set the microstepping using M350 and then set the correct steps/mm for that microstepping amount:
      M92 X640 Y640 Z3200 ; set axis steps/mm @128 microstepping
      M92 E3360:3440 ; set extruder 0 and 1 steps/mm
      Assuming that in the first example the microstepping was initially at the default x16, both the above examples result in the same steps/mm settings.
      Could you suggest me the two lines for M350 and M92 who will work?
      Edit: I have now played with every thinkable combination and variation of microsteppings. One common thing happens:
      Regardless of any previous setting (verified in the console), as soon as the print starts, the steps/mm for the extruder are reset to 822.
      All other steppers keep the right values as defined.
      PS: I got the hint regarding the adjustment of the micro stepping from dc42 posting in this forum.
        Here's how I do it to keep it simple
        M350 X16 Y16 Z16 E16 I1; set x16 microstepping with interpolation
        M92 X80 Y80 Z400 E411 ; steps per mm set as if for x16 microstepping
        M350 E64 ; alter microstepping for E axis
        firmware now correctly calculates the new steps per mm required.
        The key is to set everything for x16 first and don't change your M92, just have it set to work with x16. Then you can modify the microstepping after and it will correctly calculate.
        fcwiltundefined observatoerundefined 2 Replies Last reply Reply Quote 0
        • fcwiltundefined
          fcwilt @Phaedrux
          @Phaedrux said in Impossible to set extruder micro stepping above 16ms:
          That matches the documentation with the exception that the docs say that x16 is the default so the first M350 should not be needed.
          Are the docs in need of a correction?
            observatoer @Phaedrux
            I did exactly this and the machine reported exactly these values back which is correct. BUT, as soon as I start a print job, ONLY the value for the extruder E is reset to the 16 micro stepping value!
            I checked all possible macros who could alter the setting during start, but non of them includes M350 or M92 values.
            Something is definitely not working on my machine. I have changed the stepper already but as you see, same issue. I have also made a new sd card for the PI and did the latest test with these sw. I'm hesitant to build new config files at the moment.
            Still same status: This new setting is not working properly on my machine.
            • JoergS5undefined
              JoergS5 @observatoer
              @observatoer can you please check config-override.g and the start codes of the printed g-code file, maybe they are changing the E setting. Do the startup macros include M501 maybe?
              observatoerundefined 1 Reply Last reply Reply Quote 0
                observatoer @JoergS5
                @JoergS5 Did this in the beginning of the test already. I cleared the content of it and omitted the loading in config.g.
                • JoergS5undefined
                  @observatoer you seem to use IdeaMaker, is there something in the startup code which could change E?
                  https://forum.raise3d.com/viewtopic.php?t=12893
                  https://support.raise3d.com/ideaMaker/5-1-3-13-gcode-15-445.html
                  especially the "Extruder Switch GCode tab". Lot of places to change something...
                    @JoergS5 Thanks for the hint, but I have removed all the default settings in Ideamaker from the start code and call a start macro on the duet3. This is all that remains:
                    M98 P"0:/sys/print/start.g" ; call start.g
                    M290 R0 S0 ;reset babystepping
                    M290 S-0.05 ; set babystepping height delta
                    M572 D0 S0.025 ;set pressure advance
                    And nothing in the extruder level. Totally empty.
                    • JoergS5undefined
                      @observatoer next I would check content of start.g and if babystepping or pressue advance change the E by disabling them.
                        @JoergS5 Looks OK to me.
                        G29 S1 P"heightmap.csv" ; Load the height map from file and activate bed compensation.
                        G90 ; use absolute coordinates
                        M83 ; extruder relative mode
                        M98 P"0:/sys/G828.g" ; home if not homed
                        M98 P"0:/sys/G832.g" ; if not already leveled, level bed and re-home Z
                        ; prime nozzle
                        G1 X0 Y0 F99999.0 ; Go home
                        G1 Z0.15 ; lower extruder
                        G1 X2 Y20 Z0.3 F5000.0 ; move to start-line position
                        G1 X2 Y200.0 Z0.3 F1500.0 E15 ; draw 1st line
                        G1 X2 Y200.0 Z0.4 F5000.0 ; move to side a little
                        G1 X3 Y20 Z0.4 F1500.0 E30 ; draw 2nd line
                        G92 E0.0
                        And the two calls look clean, too:
                        ; G828.g
                        ; Conditional variant of G28 home command.
                        ; Homes all axes if not already homed.
                        if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
                        G28
                        ; G832.g
                        ; Conditional variant of G32 bed command.
                        ; Perform bed leveling if not already leveled.
                        if move.calibration.numFactors == 0 ; if leveling has not yet been performed...
                        G32 ; level bed
                        G28 Z ; re-home Z
                        else
                        echo "Bed already leveled. Skipping..."
                        • JoergS5undefined
                          @observatoer then I have no more ideas at the moment. I would remove and disable or comment out all and readd step by step to find the reason. It is also possible that there is a bug somewhere, because you have a lot of settings, macros etc. To be sure it's not IdeaMaker I would try a different program and g-code file first.
                            @JoergS5 Thank you for your time and hints!
                            JoergS5undefined 2 Replies Last reply Reply Quote 0
                            • JoergS5undefined
                              @observatoer sorry that I could not help. I think it's something trivial, a syntax error e.g., but I didn't see one.
                              Maybe M350 E16 I0 changing the E without interpolation behaves other than expected. You could try changing it to I1 as a test.
                              • JoergS5undefined
                                @observatoer I have one more idea: according the information in some threads like https://forum.duet3d.com/topic/4939/m350-not-working-wrt-m584/6 the order of the drives seem to play a role in the M584 command. In you config you have E first, so this may not be seen as an extruder drive in some code for other program parts. You could try changing
                                M584 E0 X1 Y2 Z3:4:5
                                to
                                M584 X1 Y2 Z3:4:5 E0
                                  If anyone thinks that M350 is not behaving as described in the wiki GCodes page, please supply files that replicate the different behaviour.
                                    @JoergS5 That would make sense and I will give it a try. Stii the change will be a bag of hurt to get the order of the z drives and the related measurements for ABL right.
                                    Thank you very much for your help! I will report, how this turns out.
                                      observatoer @dc42
                                      @dc42 I guess, this tread is full of all related logs and describes the issue in detail. Still I understand, it's a pain to go thru the logs.
                                        One of the reports says that the steps/mm changes when starting a print, but I didn't see a print file posted. Also, the config files have changed, so it's hard to be sure what the current ones look like.
                                          observatoer @dc42
                                          @dc42 Thank you, this was the right question.
                                          Ideamaker is setting the E value to 822s/mm and writes this at the beginning of the code.
                                          That was the reason, why this issue came up.
                                          Thanks again and I guess, the solution is found.
