    The problem of connecting DuetWiFi to modern routers.
    873
    • Vetiundefined
      Veti
      what router do you have? you might be able to put openwrt on it.
      i0n1zeDundefined 1 Reply Last reply Reply Quote 0
      • i0n1zeDundefined
        i0n1zeD
        This post is deleted!
        • i0n1zeDundefined
          i0n1zeD @Veti
          @Veti Unfortunately, there are no third-party firmware for it yet 😞
            WPA2 PSK should work.
            • i0n1zeDundefined
              i0n1zeD @dc42
              @dc42 I tried it with WPA2 and WPA\WPA2 does not connect 😞
                What reason does the Duet give for failing to connect?
                  PS also, does it connect if you set the router to No Encryption? Perhaps the failure has nothing to do with encryption.
                  • i0n1zeDundefined
                    i0n1zeD @i0n1zeD
                    @dc42 said in The problem of connecting DuetWiFi to modern routers.:
                    When the network is open, there are no connection problems, everything is fine.
                    But this is not an option to leave the network open for me, I live in a very large house.
                    • Vetiundefined
                      Veti
                      looking at the code it seems CCMP is supported. i have connected several esp8266 boards to my network which forces ccmp.
                       * Return the encryption type of the networks discovered during the scanNetworks
                       * @param i specify from which network item want to get the information
                       * @return  encryption type (enum wl_enc_type) of the specified item on the networks scanned list
                      uint8_t ESP8266WiFiScanClass::encryptionType(uint8_t i) {
                          struct bss_info* it = reinterpret_cast<struct bss_info*>(_getScanInfoByIndex(i));
                          if(!it) {
                              return -1;
                          switch(it->authmode) {
                              case AUTH_OPEN:
                                  return ENC_TYPE_NONE;
                              case AUTH_WEP:
                                  return ENC_TYPE_WEP;
                              case AUTH_WPA_PSK:
                                  return ENC_TYPE_TKIP;
                              case AUTH_WPA2_PSK:
                                  return ENC_TYPE_CCMP;
                              case AUTH_WPA_WPA2_PSK:
                                  return ENC_TYPE_AUTO;
                              default:
                                  return -1;
                      • Vetiundefined
                        Veti
                        the duet has very weak antennas. it could be that the new router wireless signal is weaker and its not enough for the duet.
                        try moving closer to the router for a test.
                        • i0n1zeDundefined
                          i0n1zeD @Veti
                          @Veti I wrote above that without encryption, everything connects perfectly.
                          And yes, the router is 2 meters line of sight from the printer.
                          • Vetiundefined
                            Veti
                            can you tell use the model of the router?
                            • i0n1zeDundefined
                              i0n1zeD @Veti
                              @Veti MI Ax1800
                              I would leave the network open and whitelist, but part of my smart home uses 2.4 and cannot work with a network without encryption.
                              • i0n1zeDundefined
                                i0n1zeD
                                • Vetiundefined
                                  Veti
                                  enable ssh on the router and you can have a look at the wireless config. but i would suspect that tkip is enabled
                                  https://forum.openwrt.org/t/add-support-for-xiaomi-ax1800-wifi-6-router/66911
                                  edit: from the dump in the post
                                  nv_wifi_enc=mixed-psk
                                  • Vetiundefined
                                    Veti
                                    question in the picture you posted. you called your network Bazzinga, but in the log you are trying to connect to a DuetWiFi network
                                    • i0n1zeDundefined
                                      i0n1zeD @Veti
                                      @Veti The screen with the settings was for the sake of example, as one of attempts to change the name and password.
                                      They were always the same when trying, of course.
                                      I will try to change the region on my router.
                                      • i0n1zeDundefined
                                        i0n1zeD @Veti
                                        @Veti said in The problem of connecting DuetWiFi to modern routers.:
                                        Yes, I did it, changed the region to EU.
                                        And I also saw "nv_wifi_enc = mixed-psk"
                                        But that didn't solve the problem.
                                          droftarts administrators @i0n1zeD
                                          @i0n1zeD see my reply to this thread. There is a possible bug in the Expressif SDK used to build the Duet WiFi firmware, that seems to cause issues with newer routers. @dc42 is looking at it.
                                          i0n1zeDundefined 1 Reply Last reply Reply Quote 1
                                          • i0n1zeDundefined
                                            i0n1zeD @droftarts
                                            @droftarts
                                            Me and others who have similar problems can only wait or use other network equipment?
