Unsolved The problem of connecting DuetWiFi to modern routers.
@dc42 I tried it with WPA2 and WPA\WPA2 does not connect
What reason does the Duet give for failing to connect?
PS also, does it connect if you set the router to No Encryption? Perhaps the failure has nothing to do with encryption.
@dc42 said in The problem of connecting DuetWiFi to modern routers.:
When the network is open, there are no connection problems, everything is fine.
But this is not an option to leave the network open for me, I live in a very large house.
looking at the code it seems CCMP is supported. i have connected several esp8266 boards to my network which forces ccmp.
/** * Return the encryption type of the networks discovered during the scanNetworks * @param i specify from which network item want to get the information * @return encryption type (enum wl_enc_type) of the specified item on the networks scanned list */ uint8_t ESP8266WiFiScanClass::encryptionType(uint8_t i) { struct bss_info* it = reinterpret_cast<struct bss_info*>(_getScanInfoByIndex(i)); if(!it) { return -1; } switch(it->authmode) { case AUTH_OPEN: return ENC_TYPE_NONE; case AUTH_WEP: return ENC_TYPE_WEP; case AUTH_WPA_PSK: return ENC_TYPE_TKIP; case AUTH_WPA2_PSK: return ENC_TYPE_CCMP; case AUTH_WPA_WPA2_PSK: return ENC_TYPE_AUTO; default: return -1; } }
the duet has very weak antennas. it could be that the new router wireless signal is weaker and its not enough for the duet.
try moving closer to the router for a test.
@Veti I wrote above that without encryption, everything connects perfectly.
And yes, the router is 2 meters line of sight from the printer.
can you tell use the model of the router?
@Veti MI Ax1800
I would leave the network open and whitelist, but part of my smart home uses 2.4 and cannot work with a network without encryption. -
This post is deleted! -
enable ssh on the router and you can have a look at the wireless config. but i would suspect that tkip is enabled
https://forum.openwrt.org/t/add-support-for-xiaomi-ax1800-wifi-6-router/66911
edit: from the dump in the post
nv_wifi_enc=mixed-psk
question in the picture you posted. you called your network Bazzinga, but in the log you are trying to connect to a DuetWiFi network
@Veti The screen with the settings was for the sake of example, as one of attempts to change the name and password.
They were always the same when trying, of course.
I will try to change the region on my router.
@Veti said in The problem of connecting DuetWiFi to modern routers.:
nv_wifi_enc=mixed-pskYes, I did it, changed the region to EU.
And I also saw "nv_wifi_enc = mixed-psk"But that didn't solve the problem.
@droftarts
Me and others who have similar problems can only wait or use other network equipment? -
@i0n1zeD see this post https://forum.duet3d.com/post/175584
This does seem to be a recent problem. There is an upcoming release but I donβt know what changes are being made yet. Until then, unfortunately yes, either wait or use other network equipment.Ian
@i0n1zeD said in The problem of connecting DuetWiFi to modern routers.:
@Veti MI Ax1800
I would leave the network open and whitelist, but part of my smart home uses 2.4 and cannot work with a network without encryption.Hi,
Can you setup multiple SSIDs on your router?
If so you could setup one without encryption just for the Duet until the problem is resolved.
Just FYI, AES works fine for me with my Duets and recent model EnGenius Access Points.
i just got a new router and set 802.11w to optional.
i had some old clients that could not connect to the wlan until i disabled it.
maybe that is what is causing the problems with new devices.
802.11w will be mandatory for wpa3 and newer devices need to support it.
